Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
How do I find out which Honda Engine?
by Gebo. 03/25/19 03:08 PM
Moltex increases their footprint, hiring
by OVERKILL. 03/25/19 02:53 PM
Rislone complete fuel system gas treatment
by Fitter30. 03/25/19 02:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
115 registered members (agpatel, ABerns, 77GrandPrix, Aero540T, anndel, 9 invisible), 2,001 guests, and 67 spiders.
Topics286,426
Posts4,908,079
Members67,622
Most Online2,967
Mar 10th, 2019
M1 10W30 vs. M1 5W30 Dexos 1 ? #4507421
09/04/17 05:33 PM
09/04/17 05:33 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
While both above oils are SN , starburst seal oils - only the M1 5W30 oil is Dexos 1 approved . I get that there is no need for a Dexos 1 approved M1 10W30 - mainly curious what the M1 10W30 may be missing in the way of ad pak , etc. as compared to the Dexos 1 approved M1 5W30 and if there is much difference in performance with the M1 10W30 ?
2017 Hyundai Sonata 2.4L GDI 4 cylinder
2010 Hyundai Elantra 2.0L 4 cylinder
2007 Kia Sedona 3.8L 6 cylinder
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507438
09/04/17 05:53 PM
09/04/17 05:53 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Probably nothing except the thicker wt on start.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507454
09/04/17 06:27 PM
09/04/17 06:27 PM
PA
umungus1122 Offline
umungus1122  Offline
PA
Most likely simply isn't tested and certified. That'd cost money.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'89 Jeep Comanche 4.0 278k - GC 0w-30, Bosch LongLife filter
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507462
09/04/17 06:36 PM
09/04/17 06:36 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
The 5w-30 has a higher HTHS (3.1 vs. 3.0) and a higher KV at 100c (11.0 vs. 10.1).
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507475
09/04/17 06:45 PM
09/04/17 06:45 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I believe it meets all dexos1 standards EXCEPT fuel economy. It's not missing anything.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507485
09/04/17 06:51 PM
09/04/17 06:51 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
I do not think that 10W30 is a dexos approved viscosity grade. Simple as that. If it was I'm sure M1 10W30 would pass Dexos approval.
I think GM are trying to simplify how much an average owner (non-BITOG) needs to think about oil. If it's Dexos it's good. By selecting 5W30 over 10W30 for the dexos 30 grade, it should work in all climates, including the very cold.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: 69GTX] #4507568
09/04/17 08:07 PM
09/04/17 08:07 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
The KV @ 100C. difference is interesting as the 5W30 is 11.0 vs. the 10.1 of the 10W30 .
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4507592
09/04/17 08:25 PM
09/04/17 08:25 PM
South La
passgas55 Offline
passgas55  Offline
South La
I would like to see the difference between Mobil 1 5/30 and Mobil 1 HM 10/30. I would pick the M1 HM 10/30
over the M1 5/30 even if it is DEXOS.
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: passgas55] #4507805
09/05/17 06:54 AM
09/05/17 06:54 AM
South East Asia
kr_bitog Offline
kr_bitog  Offline
South East Asia
Mobil1 HM 10w30 is a thick 30 oil, almost 40 weight with HTHS 3.8, where M1 5w-30 is thin oil with HTHS 3.0.
Recently I gave up with M1 non EP due to shear very fast, for HM I find it is great especially on the clean up effect.
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4508099
09/05/17 01:10 PM
09/05/17 01:10 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
1969 Ply GTX/RRs
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4508324
09/05/17 06:33 PM
09/05/17 06:33 PM
GA.
ChrisD46 Offline OP
ChrisD46  Offline OP
GA.
I was referring to M1 10W30 (not HM) which is a 3.1 HTHS
Re: M1 10W30 vs. M1 5W30 Dexos 1 ? [Re: ChrisD46] #4508863
09/06/17 09:37 AM
09/06/17 09:37 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
I was referring to the post directly above mine which stated M1 10w-30 HM has HTHS of 3.8...rather than 3.5.
1969 Ply GTX/RRs
