VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
32 registered members (CB900F2, bubbatime, 4WD, Burks21, A1O, 5 invisible), 573 guests, and 54 spiders.
Topics286,267
Posts4,905,525
Members67,589
Most Online2,967
Mar 10th, 2019
Oil filter, what is it? - 1952 Chevy DeLuxe #4506851
09/03/17 11:27 PM
09/03/17 11:27 PM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
The DeLuxe is here, and it needs an oil change in the worst way.
I'm struggling to figure out which oil filter it needs. The filter itself measures 3.875" in diameter, and is 4.625" high.
It looks like the Fram C4 in style, but the C4 seems to be bigger than this filter, from all of the dimensions that I've seen for it.
The only thing that I saw on the old filter was "Made in Israel"... which is of no use.
Any ideas?
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4506857
09/03/17 11:33 PM
09/03/17 11:33 PM
Virginia
mattwithcats Offline
Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4506874
09/04/17 12:14 AM
09/04/17 12:14 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
2004 Corolla 130017
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: JohnnyJohnson] #4506891
09/04/17 01:13 AM
09/04/17 01:13 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Interesting:
"Uses cellulose and glass blended media to provide 3x more engine protection than the average of leading economy filters"
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4507042
09/04/17 09:22 AM
09/04/17 09:22 AM
GA
drtyler Offline
drtyler  Offline
GA
Can you post a picture of the canister? I think you can look up filters by dimensions on Wixfilters.com.
My '54 uses a Wix 51100 or Fram C4, but my car has the AC filter canister.
Any ideas?
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4507061
09/04/17 09:42 AM
09/04/17 09:42 AM
PimTac Offline
PimTac  Offline
I see that these filters are accessed from up above. My Dad had a Chevy 4 door with the canister filter down under. That canister was a real PITA because the o-ring seal would twist and pop out while installing it. It took many try's until it was set.
Cannot see signatures any longer so it doesn’t matter.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: JohnnyJohnson] #4507096
09/04/17 10:11 AM
09/04/17 10:11 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
It looks like that, but the listed dimensions are too big to be the correct replacement.
That's the issue.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mattwithcats] #4507103
09/04/17 10:12 AM
09/04/17 10:12 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
Originally Posted By: mattwithcats
It looks like that, but the listed dimensions are too big.
That's the issue.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: drtyler] #4507105
09/04/17 10:14 AM
09/04/17 10:14 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
I think we're getting somewhere here.
What other brand of canister might it be? Where should I look for markings/stampings?
By the listed dimensions of the C4 filter, it's not going to fit into the canister that I have.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4507133
09/04/17 10:48 AM
09/04/17 10:48 AM
ME
eljefino Offline
eljefino  Offline
ME
Can we back up a bit? Did 52 chevys have filters stock, or could this be an aftermarket thing?
Wixfilters.com lists dimensions as well on their lookup.
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: eljefino] #4507155
09/04/17 11:12 AM
09/04/17 11:12 AM
Wet side WA
Wet side WA
Yes the had filters stock. So did my 49.
2004 Corolla 130017
2006 Duramax 74725
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4507177
09/04/17 11:34 AM
09/04/17 11:34 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
The small block didn't have a filter when first introduced, but one was added after the first year ('55). All Chevy OHV 6's had filters.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: Johnny2Bad] #4507361
09/04/17 04:11 PM
09/04/17 04:11 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Originally Posted By: Johnny2Bad
... All Chevy OHV 6's had filters.
That far back? I thought the one on our '54 was a factory option, but could be mistaken. The canister housing was mounted up high, clamped to the intake manifold, and connected through hoses to the block. My father made quite a ritual of syringing the old oil out of the housing and wiping its interior clean.
After that car was old, I replaced the oil filter hoses, for fear the old ones might burst. A few miles later, one of my brand new hoses blew apart at speed on the Interstate, making quite a mess.
2011 Toyota Prius now at 97K
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4507375
09/04/17 04:35 PM
09/04/17 04:35 PM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
This company lists several kinds. Don't know why so many. Maybe the filter housing was made by different vendors. I picked the 217 six. The oil filter was optional, maybe not on all series.
http://productguide.luber-finer.com/home...p;productTypes=
Re: Oil filter, what is it? - 1952 Chevy DeLuxe [Re: mrsilv04] #4510424
09/07/17 09:05 PM
09/07/17 09:05 PM
PA
dnastrau Offline
dnastrau  Offline
PA
This site should be a good resource:
https://www.stovebolt.com/techtips/engines/oil%20filters/
Based on information listed there, an oil filter was never "standard" on the 216/235/261 stovebolt 6 through '63 even though most had one - either as a factory or dealer installed option. Are there any stickers or numbers on the housing?
Andrew S.
