Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
33 registered members (CR94, carlprop, d00df00d, c502cid, bbhero, Brad_C, 2 invisible), 807 guests, and 59 spiders.
Topics286,170
Posts4,903,526
Members67,572
Most Online2,967
Mar 10th, 2019
Simple mixing question #4506766
09/03/17 09:31 PM
09/03/17 09:31 PM
texas
danez_yoda Offline OP
texas
2014 sienna takes 6.4 quarts of 0w20. I have a 5 qt jug of 0w20 (PP) and a partial jug of 5W30(PP).
If I put 5qt of 0w20 and and 1.4QT of 5W30 PP what would the equivalent viscosity be? Something in the 5w20 range?
Re: Simple mixing question [Re: danez_yoda] #4506770
09/03/17 09:37 PM
09/03/17 09:37 PM
New York
pbm Offline
pbm  Offline
New York
I don't know what the viscosity would be but I think it would be fine for use in Texas....especially since they are from the same oil family (similar additive package)....
'Journalism is Dead'
Re: Simple mixing question [Re: danez_yoda] #4506773
09/03/17 09:40 PM
09/03/17 09:40 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I guessed it wouldn't be, and it isn't.
It can't be calculated, but will be skewed toward the lower viscosity component.
Re: Simple mixing question [Re: danez_yoda] #4506775
09/03/17 09:41 PM
09/03/17 09:41 PM
PimTac Offline
PimTac  Offline
At that ratio it would be pretty close to 0w-20. The difference will be very small.
Cannot see signatures any longer so it doesn’t matter.
Re: Simple mixing question [Re: danez_yoda] #4506779
09/03/17 09:47 PM
09/03/17 09:47 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
PP 5W30 is 10.3cSt
PP 0W20 is 8.3cSt
~78% 0W20
Mix is 8.7cSt, or in 20 grade range.
The W rating is harder to calculate becuase they are done at different temperatures.. IT may or may not fail a 0W test run in a lab. My gut instinct is that it would be super border on 0W/5W
Ref:
http://www.pennzoil.com/en_us/products/f...c-Motor-Oil.pdf
http://www.widman.biz/English/Tables/J300.html
http://www.widman.biz/English/Calculators/Mixtures.html
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: Simple mixing question [Re: danez_yoda] #4506797
09/03/17 09:57 PM
09/03/17 09:57 PM
Danh Offline
Danh  Offline
You can Google "Widman Calculator" to determine the viscosity of a blend of two oils. You'll have to know the product specs to do this, but you can find them on Pennzoil's website.
But, as Pennzoil motor oils tend to be on the light side of a viscosity range, the mixture you're talking about will almost surely be in the 20- weight grade at 100C. Keep in mind that a viscosity specification allows a range of viscosities to qualify. For example, a 20-weight oil at 100C can have a viscosity of between 6.9 and 9.2 cenistokes (cSt), but most oils are in the 8.0-9.0 range. I'd guess your proposed mixture would wind up at around 8.6, or about like a typical 20-weight.
Re: Simple mixing question [Re: Ducked] #4506895
09/04/17 01:19 AM
09/04/17 01:19 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Shannow posted something a couple months ago.
Apparently, it gets skewed to the high viscosity components.
Re: Simple mixing question [Re: Colt45ws] #4506896
09/04/17 01:20 AM
09/04/17 01:20 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
He's in Texas.... Effectively, he can ignore the W numbers. Even on those cold snap days up in the panhandle that happen a few days each winter.
Re: Simple mixing question [Re: Colt45ws] #4507113
09/04/17 10:20 AM
09/04/17 10:20 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
PP 5W30 is 10.3cSt
PP 0W20 is 8.3cSt
~78% 0W20
Ref:
Sorry, I shouldn't have said it can't be calculated, but its my understanding that for multigrades it can't be calculated with much confidence in the accuracy of the result.
Re: Simple mixing question [Re: danez_yoda] #4507118
09/04/17 10:23 AM
09/04/17 10:23 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
You will end up with a blend of 5 qts 0W-20 and 1.4 Qts of 5W-30.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Simple mixing question [Re: danez_yoda] #4507122
09/04/17 10:30 AM
09/04/17 10:30 AM
Texas,USA
ATex7239 Offline
ATex7239  Offline
Texas,USA
Oil is cheap, engines aren't. I don't think 1 or 2 quarts of full synthetic is going to sway anyone's finances one way or another, but a damaged engine might.
I used to mix oils all the time. But now with modern engines, I don't think it's worth the risk.
'12 Buick Enclave 150,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 54,xxx
Oil � Don't know
Filter � Don't care
Re: Simple mixing question [Re: Linctex] #4507125
09/04/17 10:36 AM
09/04/17 10:36 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
That's the sort of thing I could get the wrong way around, but I doubt Molakule would be agreeing with me if I did.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4279826/Ducked#Post4279826
Re: Simple mixing question [Re: danez_yoda] #4507142
09/04/17 10:57 AM
09/04/17 10:57 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Approximately 1.09w22.18. grin
Just run it.
Thick vs Thin test: 15k / 43k miles complete
Re: Simple mixing question [Re: danez_yoda] #4507152
09/04/17 11:07 AM
09/04/17 11:07 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Use the right oil and save the partial oil for your mower.
2015 Ford F250 w/Powerstroke
Re: Simple mixing question [Re: danez_yoda] #4507359
09/04/17 04:09 PM
09/04/17 04:09 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
While there is no way of really knowing, my guess is that you'll end up with an oil that'll be of the 5W-20 grade.
Many of us were adamantly opposed to mixing until Sonofjoe posted a reply in another thread that put most of our concerns to rest.
Nothing weird will happen with this mix and it seems convenient for you.
It's not as though a 0W qualified oil is needed in Texas or just about anywhere else in the lower forty eight.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
