White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
20 registered members (Char Baby, BretK, ChrisD46, billt460, c502cid, 4 invisible), 817 guests, and 34 spiders.
Topics296,866
Posts4,960,390
Members66,982
Most Online2,688
Jan 19th, 2019
Page 1 of 3 1 2 3
How much antiseize do you usually use? #4506720
09/03/17 07:42 PM
09/03/17 07:42 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
1. Just a dab on the item
2. Some rubbed into some of the threads on one side
3. A small amount all around the item
4. I slather it all over!
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: How much antiseize do you usually use? [Re: ZZman] #4506725
09/03/17 07:44 PM
09/03/17 07:44 PM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I chose #2 as I figured it would work around as it was tightened.
Re: How much antiseize do you usually use? [Re: ZZman] #4506736
09/03/17 07:54 PM
09/03/17 07:54 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
#3
2007 Ford Fusion 236,000 miles
M1 0-20 EP
2017 Ford Fusion 62K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: How much antiseize do you usually use? [Re: ZZman] #4506741
09/03/17 07:59 PM
09/03/17 07:59 PM
NC
BigD1 Offline
BigD1  Offline
NC
Spark plugs just two little tiny dabs 180 degrees apart at the beginning of the threads. All bolts get two big dabs 180 degrees apart at the beginning of the threads. Not saying that's the best way. Just the way I do it.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: How much antiseize do you usually use? [Re: ZZman] #4506751
09/03/17 08:08 PM
09/03/17 08:08 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
I put a dab then use a dry part of the brush to spread it all around the threads.
The only thing I put it on is O2 sensors.
I dont need any help pulling the threads out of a mod motor head.
And it makes wheel lugs feel grody and packed with [censored]
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: How much antiseize do you usually use? [Re: BigD1] #4506753
09/03/17 08:10 PM
09/03/17 08:10 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Usually none. Can't get it here.
I use various improvised substitutes like PTFE or polythene film, wax, grease, aluminium foil, or a rub with an old tyre weight, depending on the application.
I have a very small and locally irreplacable tube of Permatex Silver that I use very sparingly on critical applications like brake sliders.
Re: How much antiseize do you usually use? [Re: ZZman] #4506755
09/03/17 08:16 PM
09/03/17 08:16 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
Depends on how hard the bolt was to get out. Sometimes I just stick the bolt in my little tub of Permatex Copper.
Otherwise, just a dab with the brush.
I try to clean the threads before adding anti-seize too.
'90 Z32 - PP HM 10w30
'98 ZJ - PYB HM 10w40
'02 G20 - QS UD 5w30
'09 Matrix - QS UD 0w20
Re: How much antiseize do you usually use? [Re: ZZman] #4506765
09/03/17 08:30 PM
09/03/17 08:30 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
I use just enough to get it smeared everywhere including my face, pants, hands, and a dozen other places I can get it back on me throughout the day and all that takes is picking up the bottle. I smear everything up real good.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: How much antiseize do you usually use? [Re: ZZman] #4506818
09/03/17 09:27 PM
09/03/17 09:27 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
How much paint do you use when you put a coat of paint on something ? That's how much I use while applying anti-seize with an acid brush. I get the feeling a lot of people don't know what an acid brush is.
Re: How much antiseize do you usually use? [Re: ZZman] #4506823
09/03/17 09:33 PM
09/03/17 09:33 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
For exhaust studs I dab a liberal amount on the studs and face of the nuts. For O2 sensors a bead half a grain of rice amount pressed onto the threads. None on spark plugs.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: How much antiseize do you usually use? [Re: ZZman] #4506832
09/03/17 09:46 PM
09/03/17 09:46 PM
WI
HoosierJeeper Offline
WI
#2 or a little more bordering on #3, plus a generous coating on my clothes and tools and garage floor...it works, my pants nor tools have rusted to the garage floor. smile
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: How much antiseize do you usually use? [Re: Ducked] #4506836
09/03/17 09:50 PM
09/03/17 09:50 PM
USA
ArcticDriver Offline
USA
Taiwan is surrounded by ocean. Are you sure you can't get a "marine" grade at a boating supply?
Extraordinary.
Why would it not be available?
Multiple Diesel and Gasoline vehicles
Re: How much antiseize do you usually use? [Re: ZZman] #4506845
09/03/17 10:09 PM
09/03/17 10:09 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
If it's something heavily exposed to the elements like exhaust fasteners I'll slather it all over.
Most of it will get burned off but it provides better than nothing protection (even if it does little more than nothing). I find that the fasteners closest to the engine burn all but a small amount of the anti-seize (touching it will still transfer to hand) but the sacrificial metals remain to protect. The fasteners farthest from the engine like the muffler ones remain like they were just put on it, none of it appears to burn off since the muffler area is fairly cool compared to the cat at the front. I like having them slathered for protection. I have Fluid Film, might try slathering the stuff on the rear with that instead and just put AS on the threads.
If it's something sensitive like an A/F or O2 sensor placed before or between catalyst beds, where some metals can poison the catalyst, I put a super thin amount on the threads only.
2015 Civic LX Coupe
Re: How much antiseize do you usually use? [Re: ZZman] #4506892
09/04/17 12:14 AM
09/04/17 12:14 AM
The land of USA-made Subies!
SubieRubyRoo Offline
I just follow the directions... a bottle of ARP Ultra-torque I bought says to wipe an even amount on the threads, underside of the bolt head, and on the faces of the washer (if used). Considering they've invested more time, money, and brain power working on these things, I'll trust their recommendation.
Re: How much antiseize do you usually use? [Re: Merkava_4] #4506934
09/04/17 03:50 AM
09/04/17 03:50 AM
Phoenix, Arizona - USA
SirTanon Online content
SirTanon  Online Content
Au contraire. I have a big bag of those in my tool chest in my garage, and they are exactly what I use to apply anti-seize whenever I use it.
2010 Ford Fusion SE - 2.5 liter/6F35 Trans - 268,000mi
2014 Nissan Altima SL - 2.5 liter/CVT - 61,000mi
Page 1 of 3 1 2 3
