Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
Interesting FaceBook argument
by ad_infinitum. 03/18/19 04:36 PM
2000 Silverado Power Steering Pump
by Gito. 03/18/19 04:35 PM
New Full Synthetic Oil from Dollar General
by TheLawnRanger. 03/18/19 04:31 PM
Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
MadMikesMech, Indyfordfan, toplscuda, swrve, TomRx
67549 Registered Users
115 registered members (69GTX, 2012AccentSE, 853okg, ad_infinitum, addyguy, 13 invisible), 2,373 guests, and 63 spiders.
Topics286,023
Posts4,900,991
Members67,549
Most Online2,967
Mar 10th, 2019
06 Sonata shaking on acceleration #4506645
09/03/17 07:58 PM
09/03/17 07:58 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
My 06 sonata with v6 3.3 L and 5 speed automatic transmission has developed a bade shake on acceleration after 5 minutes of driving-the whole car shakes bad enough that I can see the passenger seat rocking and steering wheel is too. then it stays on for a few minutes then disappears but noticed lately it's staying longer which is a sign of deterioration. rotated and balanced the tires with no improvement.
Jacked the car up and found what seems to be passenger axle and transmission joint leak which doesn't seem to be fresh fluid
and this but have no idea what that torn boot is either
any insight is appreciated
Keep the crankcase full.
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506654
09/03/17 08:05 PM
09/03/17 08:05 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Something fell off causing something to be out of balance is what I'm thinking.
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506657
09/03/17 08:07 PM
09/03/17 08:07 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Cv joint?
Re: 06 Sonata shaking on acceleration [Re: Merkava_4] #4506658
09/03/17 08:08 PM
09/03/17 08:08 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
Tire shop balanced tires and said they were not bad at all to begin with. doesn't sound like just out-of-balance wheel to me but can't figure it out..I like the car and it drives great otherwise
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506661
09/03/17 08:09 PM
09/03/17 08:09 PM
Reunion Island
Superflan Offline
Superflan  Offline
Reunion Island
I had this happen on 3 different FWD cars. Each time, this wobbled appeared on acceleration, I mean when there was torque applied (heavy accel, hill, or engine breaking). Barely noticeable at steady speed on flat roads.
Each time it was the longer cv-joint axle that went nuts. The 3 cars were auto-trans (1 conventional and 2 dsg), 2 remaps and 1 full atock, all turbo diesel.
Peugeot Partner 1.9 D, 5W40 C3, 245000 Km, running on WVO
Wife's Mitsubishi Outlander PHEV, dealerís overfilled, 16000 Km
Re: 06 Sonata shaking on acceleration [Re: danez_yoda] #4506664
09/03/17 08:09 PM
09/03/17 08:09 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
Originally Posted By: danez_yoda
Cv joint?
I highly suspect that though it's not clicking and the CV boots are intact .
Re: 06 Sonata shaking on acceleration [Re: Superflan] #4506676
09/03/17 08:14 PM
09/03/17 08:14 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
Hmmm, Yes Acceleration initiated the problem every time it occurred.
Don't really know if it's something a local mechanic can do or I need the dealership though I had a painful experience with they Hyundai Dealership near me.
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506687
09/03/17 08:19 PM
09/03/17 08:19 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Any decent mechanic can check out a CV joint and replace if needed. You will probably need a front alignment if a new joint is installed. Ed
CX5 Touring 2.5L :-)
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506702
09/03/17 08:26 PM
09/03/17 08:26 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
What's that torn boot ?..it's not the axle ..it's something going up inside the car towards the steering wheel?
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506756
09/03/17 09:16 PM
09/03/17 09:16 PM
Rochester, MI, US, World
Klutch9 Offline
Klutch9  Offline
Cv joint?
A bad inner CV joint will cause vibrations under load, and will not click when turning. I just had this happen with my van, and I had a bad inner joint. Boot still looked perfect too. The joints that click when they go bad are the outer CV joints, that go through the hub.
It's not a hard job to do yourself. Just make sure you either get a good rebuilt unit, or a brand new OEM unit. In my experience, new aftermarket CV axles are [censored]. Even bad out of the box sometimes.
'11 Fusion SE 2.5L - 83k miles - HK 0w20 syn, Wix XP filter
'08 Sedona LX LWB 3.8L - 129k miles - Havoline HM 5w20, Auto7 filter
Re: 06 Sonata shaking on acceleration [Re: Klutch9] #4506781
09/03/17 09:49 PM
09/03/17 09:49 PM
The South
Azeem Offline OP
Azeem  Offline OP
The South
Cv joint?
How shall I isolate which side is at fault if I were to do the job myself..Thanks
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506815
09/03/17 10:22 PM
09/03/17 10:22 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Tire shop balanced tires and said they were not bad at all to begin with. doesn't sound like just out-of-balance wheel to me but can't figure it out..I like the car and it drives great otherwise.
That's not what I was thinking. I was thinking something else that's rotational. Some people say a CV shaft can do that, but I've never experienced it. I replaced my CV shafts because the boots were torn and slinging grease everywhere.
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506960
09/04/17 06:35 AM
09/04/17 06:35 AM
PA
123Saab Offline
123Saab  Offline
PA
Is the check engine light on? I would check for misfires and bad motor mounts too.
Anything can happen
The tallest towers be overturned
Those in high places be daunted
Those overlooked regarded
- Seamus Heaney
Re: 06 Sonata shaking on acceleration [Re: Azeem] #4506998
09/04/17 08:01 AM
09/04/17 08:01 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
thats a bad inner cv joint.
and the source of your vibration.
Re: 06 Sonata shaking on acceleration [Re: kc8adu] #4506999
09/04/17 08:05 AM
09/04/17 08:05 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
Originally Posted By: kc8adu
edit.missed that this is on the steering.its shot and its bad news when it lets go.
