Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
102 registered members (2010Civic, 77GrandPrix, 65convertible, Ablebody, Astro14, 10 invisible), 1,763 guests, and 48 spiders.
Topics290,762
Posts4,849,873
Members66,034
Most Online3,590
Jan 24th, 2017
Evaporation of gasoline in engine oil #4506615
09/03/17 07:41 PM
09/03/17 07:41 PM
Danh Offline OP
Danh  Offline OP
It obvious, of course, that gasoline in an open container will evaporate quickly while gasoline in a sealed container will not.
So, if a sump (a closed system) of gasoline-contaminated oil were exposed to air would the gasoline evaporate as well? Or would gasoline's miscibility with engine oil make this not possible?
I ask the question because when I withdraw the dipstick on my fuel-diluting Honda K24W I'm usually hit with a strong gasoline odor. So one wonders if the oil could be "cleansed" of its gasoline contamination by pulling the dipstick while the car was parked. I realize this could take a very long time, but is it conceptually possible?
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506624
09/03/17 07:45 PM
09/03/17 07:45 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That's a good question; I've often wondered that as well.
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506631
09/03/17 07:49 PM
09/03/17 07:49 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The PCV system pulls fresh air through the crankcase constantly when the engine is running. Pulling the dipstick isn't going to move much air and since gas vapors are heavy anyway...
I wouldn't do it. Too easy to forget and coat the engine bay with a fine mist of oil.
Used oil will always have a hydrocarbon fuel smell to it. It gets contaminated by blow-by and fuel when the engine runs. It's normal. The best thing to do is drive it on the highway for an hour and let the oil get up to 100C
The gas will evaporate and be drawn back into the intake by the PCV system.
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506632
09/03/17 07:49 PM
09/03/17 07:49 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
If it smells like fuel when checking the oil, then even if it evaporated through use, it sounds like more fuel is being added, so it technically will always be there.
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506643
09/03/17 07:56 PM
09/03/17 07:56 PM
Danh Offline OP
Danh  Offline OP
Yes, these Hondas dilute fuel even during highway driving, so getting the oil up to operating temperature isn't a cure as new fuel dilution occurs despite some vapors presumably being boiled- off.
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506648
09/03/17 07:59 PM
09/03/17 07:59 PM
NY, USA, etc.
oilpsi2high Offline
oilpsi2high  Offline
NY, USA, etc.
In that case I'd get a Blackstone analysis and find out the best time to change the oil to minimize wear.
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506663
09/03/17 08:09 PM
09/03/17 08:09 PM
Crawfordville FL
Crawfordville FL
I have read that running higher octane fuel can reduce dilution as the ecu can run a leaner mixture. High compression GDI on 87 run rich mixtures to control knock, which contributes to dilution
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506669
09/03/17 08:10 PM
09/03/17 08:10 PM
Soviet State of Washington
PimTac Online content
PimTac  Online Content
There would be some evaporation or vaporization when the engine is running due to the splash effect and all the moving parts.
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506670
09/03/17 08:11 PM
09/03/17 08:11 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Aquarium pump. Bubble filtered (and ideally dried) air through it. But it wont shift much of the heavy end, and it might increase your oil oxidation rate a little.
Get into home brewing/moonshining on a large scale and you could bubble CO2 through it, but you'd have to dry it.
Re: Evaporation of gasoline in engine oil [Re: Ducked] #4506672
09/03/17 08:13 PM
09/03/17 08:13 PM
Crawfordville FL
Crawfordville FL
That would mess up the air/fuel ratio if the PCV started sucking up CO2
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506704
09/03/17 08:27 PM
09/03/17 08:27 PM
USA
ArcticDriver Offline
USA
But greater fuel dilution occurs at cold starts? For example, if a person is taking numerous short duration trips then is there a greater amount of fuel dilution than if they are commuting 40-60 minutes at a time?
If so, then the question becomes at what rate does the fuel get returned through the PCV vs the rate it is getting past the rings on a highway trip.
I have a CRV with 170K miles and my typical commute is 40 miles. I don't have a gas smell at my dipstick.
That is the reason I am asking about this.
Thanks
Multiple Diesel and Gasoline vehicles
Re: Evaporation of gasoline in engine oil [Re: SilverFusion2010] #4506712
09/03/17 08:34 PM
09/03/17 08:34 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Not sure if you're serious (not sure if I am either) but this would be for static use in your garage with the engine off.
In another thread on this topic steam stripping was suggested, I think for while the engine was running and at operating temperature.That would require the temperature to be kept high to avoid condensation accumulation.
Re: Evaporation of gasoline in engine oil [Re: Danh] #4506713
09/03/17 08:35 PM
09/03/17 08:35 PM
SilverFusion mentioned reading about some success with running higher octane fuel. I have also heard this and some have commented here and on a Mazda forum I lurk in that it does work.
Next time you change your oil, why not start running premium fuel? Yes it's expensive but it would be a good opportunity for you to compare and then share your findings.
Re: Evaporation of gasoline in engine oil [Re: PimTac] #4506721
09/03/17 08:43 PM
09/03/17 08:43 PM
Danh Offline OP
Danh  Offline OP
It does seem to help and I'll give it another try. At its most extreme, fuel dilution shows up in my Honda as an increase in oil level. Interestingly, this typically occurs at Interstate speeds driving into a stiff headwind. With the very high gearing and the good amount of frontal area on these cars it's possible preignition is occurring and fuel enrichment, rather than retarding spark, is the PCM's solution. So premium may help.
Evaporation would still be a nice solution...
Re: Evaporation of gasoline in engine oil [Re: ArcticDriver] #4506726
09/03/17 08:46 PM
09/03/17 08:46 PM
Danh Offline OP
Danh  Offline OP
Thanks
I'll guess your CRV is a 2014 or earlier? Honda switched CRVs to direct injection in 2015 which is the cause of fuel dilution.
