Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
31 registered members (avi1777, Black_Thunder, Bailes1992, BlakeB, 4 invisible), 568 guests, and 53 spiders.
Topics286,171
Posts4,903,546
Members67,572
Most Online2,967
Mar 10th, 2019
My favorite radiator shop #4506128
09/03/17 10:16 AM
09/03/17 10:16 AM
California
Stelth Offline OP
Stelth  Offline OP
California
I recently bought a '94 Dodge Ram 2500 4x4 with a utility bed and pipe rack, a combination that I like, as this will be the truck I drive to work. I have the receipts for the remanufactured engine and transmission, and I thought this truck would be less trouble than it has been so far. I noticed that it has a tendency to run a little on the hot side, so I figured eventually I would have to do some work on the cooling system.
As you probably know, it's been stupid hot in So Cal for a couple of weeks now, with the result that I've been driving this truck with the heater on full blast to keep it from overheating. Driving with the heater on in 100+ degree weather can be a little... uncomfortable. Yesterday, after I worked a few hours, the radiator guy said he could fit me in, even though it was 11:00 am, and he closes at 1:00 on Saturdays.
Cut to the chase, this is a small outdoor shop, and I was able to watch the guy do the radiator work. I've never seen anyone do such thorough work on anything. It's a plastic/aluminum radiator, so he took one of the tanks off after flow-testing the radiator, and began rodding it. The guy doing the work, who has been there at least 20 years, brought the radiator over to show me. His English wasn't good, and my Spanish isn't great, but I understood that he was showing me that the core was clogged with silicone, presumably left over from the engine assembly. It was pretty large, hardened bits, i.e., the silicone wasn't introduced into the radiator in an uncured state, but washed into it from the engine. He was able to restore approx. 90% flow, which is plenty to prevent overheating. The boss told me it was about 55% clogged when he started. Even though it was after closing by this time, the technician continued blowing out and flushing the radiator until he was satisfied, dried it with an enormous torch, painted the tank he had removed, then reassembled the radiator, leak tested it, dried it again, and painted the entire assembly. They also cleaned out my recovery tank (looks new), and fixed a leak on the coolant recovery hose.
I've been using this shop for well over 20 years, and I don't know why I'd go anywhere else for cooling system work. Prices aren't cheap, but they are very fair, IMO. The cost for the above, including removal and re-installation in my truck was $255.00. For another $160 he would have re-cored the radiator, but the core and tanks (Modine) looked pretty good to me.
It's going to be nice to be running the AC instead of the heat.
Experts are often wrong, but rarely in doubt.
Re: My favorite radiator shop [Re: Stelth] #4506150
09/03/17 10:39 AM
09/03/17 10:39 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
255$ is chump change compared to a serious over heat repair.
Thick oil is better grin2
Re: My favorite radiator shop [Re: Stelth] #4506183
09/03/17 11:31 AM
09/03/17 11:31 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
You have a metal radiator in that truck? I wonder where he is getting a core for $160or less? My cost on a core is in the $300+ range..just for fun you can see me @:14 https://youtu.be/5yG4zxz8CvE
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: My favorite radiator shop [Re: Stelth] #4506221
09/03/17 11:56 AM
09/03/17 11:56 AM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I'm amazed for the amount of time invested in cleaning that core out they didn't just offer the replacement core right off the bat.
Truck runs better anyway. Never understood how anyone builds anything with all that silicone.
Re: My favorite radiator shop [Re: Stelth] #4506249
09/03/17 12:26 PM
09/03/17 12:26 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
Most all of the local radiator shops have closed down around here, but there is one still open that is getting a lot of business because he simply gets the job done and his prices are reasonable. The last work that I had him do was a full re-core for a '71 Chevy C90 with a Detroit 6-71. He also gets all of the area ag business. This guy is also skilled enough that he completely hand-built a radiator for a Ford car that predates the Model A and Model T and was shipped off to California resident who now has the car in a museum.
Re: My favorite radiator shop [Re: Stelth] #4506275
09/03/17 01:01 PM
09/03/17 01:01 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Guy has niche. Fixing Farm machinery. Last all metal radiator, I bought new was around 300$, 20 yrs ago. I stopped using RTV after I found it in the radiator. Earliest Ford production car was a Model N and very scarce.
Re: My favorite radiator shop [Re: andyd] #4506322
09/03/17 02:11 PM
09/03/17 02:11 PM
Kansas
Kruse Offline
Kruse  Offline
Kansas
It has been a couple of years since he mentioned it to me and I don't recall the model. I did see his work and it was museum quality, though.
Re: My favorite radiator shop [Re: Chris142] #4506487
09/03/17 05:56 PM
09/03/17 05:56 PM
Leamington, ON, Canada ..... r...
Papa Bear Offline
Papa Bear  Offline
Are you standing on a box of dynamite ?? ..... LOL
2016 Dodge GC Deep Cherry 5W-30 Dino
2013 SYM Wolf Classic 150 T4 15W-40
2009 V-Star 250 Black Cherry 20W-50 Dino
https://www.hogsforhospice.com/
Friend of Bill W. since '89
Re: My favorite radiator shop [Re: Chris142] #4506602
09/03/17 07:35 PM
09/03/17 07:35 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Have you guys ever made a 2 or 3 row radiator with an internal ATF and engine oil cooler?
I can think of one local radiator shop here.. Seems to stay pretty busy.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: My favorite radiator shop [Re: Stelth] #4506692
09/03/17 08:20 PM
09/03/17 08:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Which engine does your 1994 Dodge Ram 2500 have ?
NAPA has four radiators for that truck and the most expensive one is $252.89.
Re: My favorite radiator shop [Re: Merkava_4] #4506724
09/03/17 08:44 PM
09/03/17 08:44 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
God bless common sense.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: My favorite radiator shop [Re: Charlie2015] #4506790
09/03/17 09:55 PM
09/03/17 09:55 PM
Tasmania, Australia
hpb Offline
hpb  Offline
Tasmania, Australia
That was my thought too - wouldn't a new radiator have been less expensive?
MY16 Mitsubishi Outlander 2.2 diesel, 57,000km - Castrol 5w30
2006 Ford Falcon 4.0, 140,000km - Valvoline Engine Armour 15w40, Ryco filter
Re: My favorite radiator shop [Re: Charlie2015] #4506805
09/03/17 10:10 PM
09/03/17 10:10 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Thank You! I need all the blessings I can get. grin2
Re: My favorite radiator shop [Re: dlundblad] #4506840
09/03/17 10:55 PM
09/03/17 10:55 PM
Chris142 Offline
Chris142  Offline
many gm trucks use that setup. New tanks are getting hard to find.
Re: My favorite radiator shop [Re: Chris142] #4506967
09/04/17 06:45 AM
09/04/17 06:45 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Can old tanks be re-used?
