Went to the dealer the other day to pick up a filter and drain plug for the GTI and curiosity got me. There is a ADB adapter on the filter housing that has 2 o-rings on it. Inquired about new o-rings as I figure it's a wear item like the bigger o-ring on the housing. Parts person indicated they didn't have the separate o-rings, but had the adapter pictured below.
Part#
Snaps into this filter housing (for both 1.8 and 2.0 Gen 3 turbo motors)
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/oil-filter-housing/06k115408/
Am I being too picky/paranoid about this? It's a $3 part, so cost is no issue. Haven't seen any post around the net about anybody changing them, but like I mentioned the o-rings have to be a wear item. If they don't seal all the oil will simply just drain into the pan, and that's not a good scenario. I figured I'd change it every other oil change. Didn't have a chance to talk to a technician on site to see if they replace it during their oil changes.
'17 VW GTI 2.0T - 6MT - 9K - Edge 0w40
'15 Camry SE - 2.5 - 20K - PP 0w20
'99 S10 - 2.2 5MT - 155K - T6 0w40
