Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
49 registered members (alarmguy, 97K15004WD, 2015_PSD, 87sammy, 77GrandPrix, aba4430, 3 invisible), 707 guests, and 47 spiders.
Topics286,220
Posts4,904,535
Members67,579
Most Online2,967
Mar 10th, 2019
napa 7124 filter for trans filter #4505973
09/03/17 05:28 AM
09/03/17 05:28 AM
NH
budvoss Offline OP
budvoss  Offline OP
NH
New member here ..I recently bought a used 89 ford E350 class c motor home 460 engine with a aftermarket trans filter kit with a temp prob. The filter was so rusty that i could not pull any numbers off it. After tons of searching i was led here and found a list of #s that would fit the base and none would fit that i tried.. Well it turned out i have a 3/4 20 pitch thread . The ph8a would start to screw on but that was it. The filter that i finally found that fit was a napa gold 7134. I'm adding this here in hopes it helps someone else searching for a 3/4 20 pitch thread filter.
Not sure if this is right filter for trans application as it is a engine oil filter but its on there . If anyone knows the correct filter please let me know.
thanks all
Re: napa 7124 filter for trans filter [Re: budvoss] #4505979
09/03/17 05:51 AM
09/03/17 05:51 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Wix 57701 & Napa 7701 Trans Filter
Re: napa 7124 filter for trans filter [Re: Trav] #4506012
09/03/17 08:04 AM
09/03/17 08:04 AM
NH
budvoss Offline OP
budvoss  Offline OP
NH
Thanks so much for the reply. I will change it asap
Re: napa 7124 filter for trans filter [Re: budvoss] #4506235
09/03/17 12:06 PM
09/03/17 12:06 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Congratulations on the new to you motor home. The 460 is a fantastic engine for that application. What transmission is in it? I'm guessing it is likely a C-6, if so you really have a fantastic nearly bulletproof engine and transmission combination.
Luke
Re: napa 7124 filter for trans filter [Re: FlyNavyP3] #4507453
09/04/17 06:25 PM
09/04/17 06:25 PM
NH
budvoss Offline OP
budvoss  Offline OP
NH
Thanks,The wife and i love it. It has the c6 and plenty of power. Believe it or not only 36000 miles. I car faxed it and all checks out. The thing was in a enclosed garage and dusty as heck... I put new tires and fluids including flush brake fluid and had to flush fuel system... Yep the wife is happy and that makes me real happy
Re: napa 7124 filter for trans filter [Re: budvoss] #4536847
10/08/17 07:45 AM
10/08/17 07:45 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Mind your fuel filtration. System won't have loved all of that non use.
