Planes, smoke, pyrotechnics and lasers
by Shannow. 03/26/19 08:55 AM
Rust paint that works? Canada
by nobb. 03/26/19 07:19 AM
Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
bgm6881, machv5, freewayken, JustMatt, DCDMan
67626 Registered Users
91 registered members (ARCOgraphite, andyd, 2010Civic, Astro14, 11 invisible), 1,691 guests, and 70 spiders.
Topics286,446
Posts4,908,443
Members67,626
Most Online2,967
Mar 10th, 2019
2010 Mini Cooper valvetrain pics #4505924
09/03/17 12:32 AM
09/03/17 12:32 AM
Specific Ocean
Kibitoshin Offline OP
Specific Ocean
3 day weekend is here and the neighbors Mini Cooper is in the garage for misfire codes, EVAP codes and other emissions codes. First was to fix the misfiring issue. But upon pulling the ignition coils was oil pooling in the spark plug wells so new valve cover gaskets were in order. At the end of the day the low speed misfiring was gone and this buggah run smooth now.
89,990mi. For some reason this car is a blast to drive so I might "test drive" it to 90,000mi
I do not know the history of this engine but looks like it was well fed. Typical staining on the rear of the head since the PCV pulls blowby by the rear part of the valve cover/head.
Intake cam:
Exhaust cam:
Timing chain:
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4505932
09/03/17 01:29 AM
09/03/17 01:29 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
Maybe it is camera angle, but look at the sprockets on the cam, especially the exhaust camshaft. They look horribly worn. Like almost ready to jump time worn.
Rod
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4505933
09/03/17 01:30 AM
09/03/17 01:30 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
Rod
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4505935
09/03/17 01:39 AM
09/03/17 01:39 AM
Md, USA
montero1 Offline
montero1  Offline
Md, USA
I had a '10 Non-turbo Mini Cooper, it was a blast to drive. Sold it with over 110k on it, and it ran great. Only trouble I ever had with the car was around 88k, it had a leaking thermostat housing. It drank a quart of oil every 2k, but all in all, one of my favorite I've ever owned.
'07 Z4 3.0 SI
'08 GL1800
'10 Jeep Rubicon
'10 Corvette
'13 V-Star 1300 Deluxe (Hers)
'13 VFR1200F
'16 Harley Electra Glide Limited
'18 GMC Canyon Denali (Hers)
Re: 2010 Mini Cooper valvetrain pics [Re: ragtoplvr] #4505943
09/03/17 02:46 AM
09/03/17 02:46 AM
North Carolina
rooflessVW Offline
rooflessVW  Offline
North Carolina
Rod
No, they don't.
All is well.
"Zed's dead baby, Zed's dead."
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4505995
09/03/17 06:56 AM
09/03/17 06:56 AM
New York
NoNameJoe Online content
NoNameJoe  Online Content
New York
I see lint, were these parts toweled off? Usually when I take the valve covers off there's a lot more film than this. It would be disconcerting if this wasn't toweled off, was it sitting for weeks or something? Looks almost totally dry except for some pooling.
They look fine to me, not all cam sprockets or phasers have long teeth.
2015 Civic LX Coupe
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4506244
09/03/17 12:15 PM
09/03/17 12:15 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
Cool pictures. What's the spring-gizmos behind the intake cam? Some sort of variable lift device? I see cam phasers for variable timing.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: 2010 Mini Cooper valvetrain pics [Re: Kibitoshin] #4506331
09/03/17 02:21 PM
09/03/17 02:21 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
Some of the cam lobes appear to be worn with steps on the outer edges of the lobes. Is this accurate or just the angle of the photo?
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
Re: 2010 Mini Cooper valvetrain pics [Re: 2015_PSD] #4511259
09/09/17 12:51 AM
09/09/17 12:51 AM
Specific Ocean
Specific Ocean
Cam lobes felt smooth across the camshaft when I rubbed it with my finger.
Car is complete with new plugs, O2 sensor and DTML solenoid installed. Took it on a test drive to complete system readiness monitors and check for pending codes. EVAP monitor is two trip to complete test so tomorrow will be the final verdict whether all readiness monitors shows complete.
