Tire on Church 15 Passenger Van
by Gebo
06/20/18 11:58 AM
Battery Disconnect Switch?
by Pike51
06/20/18 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
06/20/18 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
06/20/18 11:08 AM
2006 Prius
by Kira
06/20/18 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
06/20/18 10:18 AM
Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
93 registered (billt460, ARB1977, BillyTheKid, 2015_PSD, Bjornviken, 28oz, 14 invisible), 1660 Guests and 43 Spiders online.
65276 Members
67 Forums
285649 Topics
Page 1 of 2 1 2 >
#4505920 - 09/03/17 12:03 AM AC fixed but still not blowing cold air
gallydif Offline
Loc: Little Havana, Miami
Things that have been done recently to the roadmaster-
New: ac drier, hose assembly, condenser, orifice tube.
System was vacuumed out and charged. Oil in. It is leak free
Compressor only has 66k miles on. Doesnt make any wierd noises. Still engages.
After all of this my ac comes out lukecool at best. This cars ac used to be freezing! Any input appreciated.
96 fleetwood 63k dd- MaxLife 5w30, AC Delco pf52
95 Caprice 67k LT1 dd- Mag1 dino 5w30, same ^
84 Caprice Landau 14k- MS5K 5w30, AC D pf454
96 Buick Roadmaster 65k- RIP 17
00 Town Car- RIP 16
#4505925 - 09/03/17 12:43 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
Nick1994 Online   content
Loc: Phoenix, AZ
Fan clutch?
My grandparent's Trailblazer had lousy a/c for years, even after recharging the system it wasn't very good. Replaced the fan clutch and crzy it blows ice cold!
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4505930 - 09/03/17 01:17 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Is the temperature adjustment working, or is something there stuck?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4505955 - 09/03/17 04:45 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
Merkava_4 Offline
Loc: Clovis, CA
You can tell a lot by hooking up a set of manifold gauges; most importantly, if the shop cheated you on refrigerant.
#4505956 - 09/03/17 04:46 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
WyrTwister Offline
Loc: Texas
Is the vapor / low pressure line going to the accumulator getting cold ?
Wyr
God bless
#4506009 - 09/03/17 08:00 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
spasm3 Offline
Loc: North Carolina
Yes you need gauges on it. Could be a gummed up orifice tube, if someone used stop leak in it.
13 elantra 68k 5w30 QSUD
03 chevy avalanche76k synpwr 10w30
01 saturnsc1 185k synpwr rebuilt
17 mazda cx-5 3900 miles m1 0w20/0w40 mix
#4506061 - 09/03/17 09:11 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
Chris142 Offline
Loc: Deplorable in apple valley, ca
Is the suction line cold? Whats the pressures?
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4506127 - 09/03/17 10:16 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
CharlieW618 Offline
Loc: Herrin, Illinois
Evidently it ain't fixed.
Formally Charlie1935
Du Quoin, Il.
#4506181 - 09/03/17 11:25 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
Eddie Offline
Loc: Florida, Cape Coral
The air blend door sticking will cause this problem.
CX5 Touring 2.5L :-)
#4506192 - 09/03/17 11:39 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
gallydif Offline
Garak- the temp adj is working
Wyr- the low pressure line to the drier is getting cold
Chris142- with the gauges on, thr guy at the shop told me the pressure needs to be between 40-50. Was at 40 and he put some more refridgerant in there to be at 45.
The car was on for about an hour today and driven at the ac's highest fan mode and lowet temp. For about 2 minutes i got the tease of it blowing almost as cold as it used to. Then went right back to lukecool. Blend door problem?
00 Town Car- RIP 16
#4506212 - 09/03/17 11:50 AM Re: AC fixed but still not blowing cold air [Re: gallydif]
WyrTwister Offline
Loc: Texas
The basics of refrigeration is temperatures and pressures .
I try to run the evaporator coil at around 35F to avoid freezing the coil .
That , under perfect conditions , with R-134a , to 30.5 psi . So , for me , he has too much refrigerant in your system .
But , if the suction / low pressure line is cool , you should be at least be getting some cool air . If not cold .
So , I am still thinking a problem with a blend door or the control problem .
Edited by WyrTwister (09/03/17 12:02 PM)
Wyr
God bless
#4506238 - 09/03/17 12:08 PM Re: AC fixed but still not blowing cold air [Re: gallydif]
mk378 Offline
Loc: USA
If the suction line is much colder than the air from the vents, there is a blend door problem.
Charging by pressure, and watching only one gauge at that, is the wrong way to do it. There's a good chance he didn't bother to use a vacuum pump either, which means the refrigerant is contaminated with air and will need to be replaced to get full performance.
#4506288 - 09/03/17 01:22 PM Re: AC fixed but still not blowing cold air [Re: gallydif]
mk378 Offline
Loc: USA
Also if you're saying it was cold for 2 minutes when you first started the car, then warmed up, that really suggests the heater core is fighting the A/C.
#4506298 - 09/03/17 01:33 PM Re: AC fixed but still not blowing cold air [Re: Merkava_4]
555 Offline
Loc: New England
Yup! That's a possibility, been there, chased that problem.
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
#4506449 - 09/03/17 05:21 PM Re: AC fixed but still not blowing cold air [Re: gallydif]
WyrTwister Offline
Loc: Texas
Good point about the A/C fighting the heater . Put a water valve in the heater hose & shut it off . Does it have a mechanical , vacuum or electronic gizmo to modulate coolant flow to the heater core ?
Edited by WyrTwister (09/03/17 05:29 PM)
Wyr
God bless
Page 1 of 2 1 2 >
