Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Good Dealers
by HowAboutThis. 09/22/18 09:12 AM
electric brakes rely on heat to work?
by motor_oil_madman. 09/22/18 09:09 AM
help please 7.25 briggs idle too fast
by edwardh1. 09/22/18 08:49 AM
Java update and Flash not working
by JLTD. 09/22/18 08:47 AM
Bought a Giulia
by RamFan. 09/22/18 08:38 AM
by gordond. 09/22/18 08:37 AM
Mobil 1 Extended Protection High Mileage Test
by njohnson. 09/22/18 07:57 AM
WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
79 registered members (Astro14, Aero540T, A310, 14Accent, aquariuscsm, 10 invisible), 1,829 guests, and 46 spiders.
Topics290,821
Posts4,850,961
Members66,040
Most Online3,590
Jan 24th, 2017
question about a RMS leak #4505902
09/02/17 11:29 PM
09/02/17 11:29 PM
Long Island, NY
Why_Anything Offline OP
Long Island, NY
Well its more of a weep.
Anyway, i picked up this 2010 Ford Transit Connect, with the 2.0 gas motor and an auto. Doing an Inspection i noticed some dampness and on tiny drip of oil forming around the area you would associate with a rear main seal leak. right at the bottom lowest point between the motor and tranny.
I cleaned it off with some parts cleaner and went for a 25 mile drive, i noticed a very slight weeping of oil, not a leak or a drop yet. But i would assume after lets say 500 miles it will be a drip for sure
My question is how long do you guys think i can let this do what it does before i have to rip the tranny out and fix this issue? I only need the van for a few months for a job, then ill see it on to the next guy. It leaves no drips or spots on the drive way after 100 miles of driving, there is no evidence of oil that has been blown under the van or anything like that, that would signify a serious leak.
Do you think some snake oil or a HM oil will tackle this?
I did some reading and see its a known issue to have this leak with the Ford focus of the same years, and in the end the Transit connect is a ford focus.
Re: question about a RMS leak [Re: Why_Anything] #4505905
09/02/17 11:37 PM
09/02/17 11:37 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Doesn't sound like anything to worry about. Just check the oil every once in a while.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: question about a RMS leak [Re: Why_Anything] #4505909
09/02/17 11:40 PM
09/02/17 11:40 PM
Long Island, NY
Long Island, NY
yeah its more of seepage than a leak really
Re: question about a RMS leak [Re: Why_Anything] #4505931
09/03/17 01:29 AM
09/03/17 01:29 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
On a past vehicle, I pretty much just lived with a slow RMS leak for 40k miles. I tried the usual stuff like AutoRX, HM oil, ATP 205.. at most these stopped the leak temporarily but it would always come back.
I just ended up leaving a metal catch pan in the garage where I parked and that was it.
Re: question about a RMS leak [Re: Why_Anything] #4505960
09/03/17 04:51 AM
09/03/17 04:51 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
I would drive it & check the oil every time I put gas in the tank .
Sounds like a very minor leak , compared to some cars back in the old days .
Shot in the dark , check the PCV system to see if the internals of the engine are not being " pressurized " .
Wyr
God bless
Re: question about a RMS leak [Re: Why_Anything] #4505968
09/03/17 05:19 AM
09/03/17 05:19 AM
NY
demarpaint Offline
demarpaint  Offline
NY
I bet there are a lot of cars on the road with the exact same problem that people aren't even aware of. They drive them until they sell or dispose of the car w/o repairing it. As mentioned keep an eye on the oil level, and park it over a catch pan, if oil loss increases, or the spot on the catch pan gets bigger then deal with it.
God Bless Our Troops
Re: question about a RMS leak [Re: Why_Anything] #4505975
09/03/17 05:34 AM
09/03/17 05:34 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I never mess with a weeping seal, at best the snake oils may slow or stop it temporarily or it might turn into a full blown leak. This engine probably uses a teflon rear seal which are known for slight weeping and rarely develop into a leak, it probably got stretched a bit too much when it was assembled which is no big deal.
If it is teflon it is impervious to esters and solvents anyway but the rest of the engine gaskets and seals are not.
Re: question about a RMS leak [Re: Why_Anything] #4506011
09/03/17 08:02 AM
09/03/17 08:02 AM
Texas
4WD Offline
4WD  Offline
Texas
My 5.3L has had seepage for years along with many others. A seal can be come "steady state" like that - and the tiny amount of weeping is ideal to keep it wet. I always have the grunge on the metal - but none on my driveway ...
Re: question about a RMS leak [Re: Why_Anything] #4506045
09/03/17 08:42 AM
09/03/17 08:42 AM
PA
copcarguy Offline
copcarguy  Offline
PA
Try some MaxLife if it'll make you sleep better.
Re: question about a RMS leak [Re: Why_Anything] #4506134
09/03/17 10:23 AM
09/03/17 10:23 AM
midwest
JamesBond Online content
JamesBond  Online Content
midwest
Several years ago I had a small rear main seal leak that would leave a spot on the ground, it didn't bother me so I wasn't trying to fix it. I used many different oils including HM oils with no change, until I tried regular Pennzoil and the leak slowed and then eventually stopped leaving a spot on the ground. There were no other changes made to the vehicle. I stuck with Pennzoil in that car from then on.
Get a new motorcraft pcv valve, don't use any separate leak stoppers.
Re: question about a RMS leak [Re: Why_Anything] #4506191
09/03/17 11:38 AM
09/03/17 11:38 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
The RMS and cam seal in my Rav4 have been weeping for the past 100k miles. I use HM oil and haven't tried any magic RMS stop leak yet. Might try some magic stuff if it starts to drip. No way I'm paying to repair it.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
Re: question about a RMS leak [Re: Why_Anything] #4506240
09/03/17 12:09 PM
09/03/17 12:09 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
My 1985 Ford pickup has been leaking from the RMS since I bought it in 2013. I've put almost 50k on since then and it hasn't gotten any worse. It does leave drips, so I'm careful not to park it anywhere where oil stains would be a bother. I don't think yours will get worse, especially being so new.
I once tried to replace the RMS through the oil pan (rear main seal is under the rear-most main bearing cap) and I got the lower half replaced. I could not move the crank enough to replace the upper half of the seal. It still leaks, so I essentially spent 2-3 days under the truck for nothing. If you're not dumping quarts of oil in to keep it going, I would save your money until it gets bad enough that you have to-- don't mess with it right now.
1985 F-250HD 7.5L 4x4 135k- Maxlife 15w-40 HDEO
04 Odyssey EX 182k PUP 0w-40
96 Maxima GLE 250k QS Defy 5w-30
07 Chrysler Pacifica Limited 129k PUP 5w-40
Re: question about a RMS leak [Re: Why_Anything] #4506274
09/03/17 01:01 PM
09/03/17 01:01 PM
USA
Reddy45 Offline
Reddy45  Offline
USA
Sounds like it's time someone like Dorman made a fireproof 'automotive diaper' that we can just wrap up against the engine! LOL
Re: question about a RMS leak [Re: Reddy45] #4506285
09/03/17 01:20 PM
09/03/17 01:20 PM
Long Island, NY
Long Island, NY
LOL!
Re: question about a RMS leak [Re: Reddy45] #4507124
09/04/17 10:32 AM
09/04/17 10:32 AM
NJ
Leo99 Offline
Leo99  Offline
NJ
My wife refers to the pan under her car as a wee wee pad.
It's there to catch the gear fluid that leaks from the transfer case.
