Did my first ever rear differential oil change. (Have owned mostly front wheel drive)
I found it pretty easy to do. Bolts on cover broke free easily. Oil hole bolt took a little heat and liquid wrench.
I used some rtv for differentials to seal it back up and cleaned gears good with brake cleaner. Decided to use Mobil 1 75-90 in it.
I think this was the first change for it being the transmission fluid had never been changed.
