Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
03 Accord V6 'brake' light on after brake work...
by columnshift. 09/23/18 11:29 AM
Why does Redline Motor oil quiet lifter noise
by Onetor. 09/23/18 11:11 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
104 registered members (Ablebody, 55hambone, anndel, 2015Corolla, AandPDan, 2009Edge, 9 invisible), 1,797 guests, and 32 spiders.
Topics290,901
Posts4,852,155
Members66,047
Most Online3,590
Jan 24th, 2017
VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles #4505551
09/02/17 03:23 PM
09/02/17 03:23 PM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
This oil is still in service in my 4Runner as I type this. Since I was mailing off a transmission fluid sample I decided to check in on how the SAE 30 was doing. The comments about silicon suspicions were due to me letting Blackstone know that during this oil the valve cover was off for a gasket replacement which included the use of silicone sealant on the end plugs. I'm a little disappointed that both the VWB and PYB SAE 30 add packs are kinda boring and weak, typical SN add packs, I was honestly hoping for something better.
Iron has been higher than I'd like in the last several samples and on my next oil change I'll be either using Delo 15w30 SD or Rotella 10w30 CJ-4/SM to see if the better add pack brings down the Iron some. If not than I'll just assume that the higher iron is a result of lots of idling and 95% in town driving and short trips that this truck sees.
No makeup oil was added and I'll dump this fill somewhere between a few weeks and a few months depending on time, somewhere between now and 5,000 miles on the fill. The truck is still running very well and the engine still hasn't been rebuilt at 331,111 miles.
Enjoy.
Luke
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505613
09/02/17 04:42 PM
09/02/17 04:42 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Does look as if iron is rising a bit.
What's the engine oil brand history? Used VWB all along or has it been a mix?
(apology if you've noted this somewhere else I haven't seen it)
Thick vs Thin test: 15k / 43k miles complete
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: Kuato] #4505636
09/02/17 05:08 PM
09/02/17 05:08 PM
Jacksonville, FL
Jacksonville, FL
Oil changes lest to right are..
Current sample SAE 30 VWB
BLEND: 2 quarts Valvoline 10w40 Motorcycle 2 quarts Napa Synthetic 0w20 (blended and shaken in LiquiMoly jug to get some of the moly that had settled out on the bottom of the jug)
BLEND: 2 quarts Valvoline 10w40 MaxLife 1 qt Valvoline Durablend 2 quarts Napa Synthetic 0w20 (blended and shaken in LiquiMoly jug to get some of the moly that had settled out on the bottom of the jug)
LiquiMoly 10w40 MOS2 (the pre blended MOS2 enhanced oil)
SuperTech conventional 5w30 (Warren blended)
Delvac 1300 15w40
Also, apparently this is my 1,000th post. Woo hoo!
Last edited by FlyNavyP3; 09/02/17 05:10 PM. Reason: Celebrate 1000 posts, woo hoo!
Luke
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505669
09/02/17 05:53 PM
09/02/17 05:53 PM
OH
fdcg27 Offline
fdcg27  Offline
OH
Looks okay.
Unless you see a huge spike, there is no real difference.
Remember, we're looking at PPM with measurement less exact than what we might like to think.
A few PPM in a commercial UOA is nothing of any significance.
17 Forester 12K MSS 0W-20
12 Accord LX 92K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505671
09/02/17 05:55 PM
09/02/17 05:55 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
how bout trying some DELO 10w30 or some ST 15w40?
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: 53' Stude] #4505695
09/02/17 06:26 PM
09/02/17 06:26 PM
Jacksonville, FL
Jacksonville, FL
I'm thinking that my Rotella 10w30 CJ-4/SM will go in next. Either that or Delo 15w30 SD since those are already both purchased and here at the house.
I could also use some Napa All Fleet 15w40 if I wanted to try another SAE 40. But I'm inclined to stick with 30 for now.
Luke
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505710
09/02/17 06:41 PM
09/02/17 06:41 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Too bad you don't have Rural King as I nabbed 3 gallons of 15w40 for the VW RABBIT diesel hatchback for $9~ gallon smile
I'm no Rotella fan so I'll stick with my DELO 10w30 CJ4/SM
PP 5w30 and TG 4967
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505722
09/02/17 07:03 PM
09/02/17 07:03 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Iron is high due to slow pumpability and metal on metal cold starts (ducks).
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: bubbatime] #4505767
09/02/17 07:59 PM
09/02/17 07:59 PM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
In Florida ?
Seriously...where's the bearing metals?
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: bubbatime] #4505818
09/02/17 09:11 PM
09/02/17 09:11 PM
Jacksonville, FL
Jacksonville, FL
Not likely. Iron has been trending up for the past few oil changes. My Lexus over the same interval didn't show elevated iron. We'll see how it does with HDEO next time.
Luke
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4505904
09/02/17 11:36 PM
09/02/17 11:36 PM
Texas
FZ1 Offline
FZ1  Offline
Texas
Minor differences. Looks good.
Re: VWB SAE 30 3720mi 1987 4Runner @ 331,111 miles [Re: FlyNavyP3] #4506196
09/03/17 11:42 AM
09/03/17 11:42 AM
Jacksonville, FL
Jacksonville, FL
Trend analysis is difficult with using so many different oils. I'm going to try a few runs with HDEO next and see if the iron comes down or not. I'm not concerned enough to tear into the engine by any means. Oil pressure is excellent and the camshaft looked spectacular when I adjusted the valves about 3,000 miles ago. I don't have any worry that something is terribly wrong but I'd like to get back to single digit iron numbers over ~3000 miles or around 10ppm @ 5,000 miles.
Luke
