Which is more important for low wear HTHS or ZDDP?
by Building3
06/21/18 10:40 AM
Valvoline DuraBlend 80W-90
by dogememe
06/21/18 10:34 AM
Lifter Tick
by Delta
06/21/18 10:28 AM
I Got Locked Up Today
by Zee09
06/21/18 10:24 AM
GM new 2.7 turbo pick up motor
by ZZman
06/21/18 09:45 AM
PUP at Canadian Tire $33 CAN
by Snagglefoot
06/21/18 09:15 AM
How to use up a case of SF?
by atikovi
06/21/18 09:08 AM
Read The Fine Print- Credit Cards
by Zee09
06/21/18 09:06 AM
Employer Exit Interview.
by JustinH
06/21/18 08:53 AM
Ceratec vs. Archoil 9100
by Phishin
06/21/18 08:49 AM
Acclaim radiator ?
by urrlord
06/21/18 08:47 AM
Understanding Idle Control Circuit
by artbuc
06/21/18 07:59 AM
Annual drain on Mobil1 5w20 high mileage?
by ryan2022
06/21/18 07:36 AM
Best Oil For Late Model Toyota V6 Engines ?
by ChrisD46
06/21/18 06:58 AM
Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
95 registered (2015_PSD, 4WD, aquariuscsm, 28oz, andyd, Amenhotep, 8 invisible), 1507 Guests and 89 Spiders online.
65286 Members
67 Forums
285699 Topics
#4505177 - 09/02/17 08:23 AM Pennzoil platinum 5w-30 Euro L ? Dexos 2
Ammofirst Offline
Loc: Western usa
Vehicle : 2014 Buick Regal 2.0T : few questions : 1. Can I use this oil or does GM require only using Dexos 1 in a gas engine? 2. Has this oil passed any of the new lspi testing? : 3. Being C3 rated is the hths 3.5 > ? : 4. I believe this is a low saps oil, can it handle a 5k oci in a turbo application (60% hwy) ? Thanks.
#4505204 - 09/02/17 08:50 AM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
slacktide_bitog Offline
Loc: USA
dexos2 is the spec for gas (and diesel) engines in Europe, and since the Regal is a German car, it will probably be just fine for the OCI suggested by the OLM smile
#4505219 - 09/02/17 09:13 AM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
Trav Offline
Loc: MA, Mittelfranken.de
Dexos 2 is the spec oil for that engine in that car and its fine for 5K. I wouldn't even consider running lower HTHS Dexos 1 oil, these thiner oils are only for US fuel economy standards and offer only a minimum level engine protection in high output engines but enough to get through warranty.
#4505539 - 09/02/17 03:04 PM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Trav]
Ammofirst Offline
Loc: Western usa
I've been looking for a Dexos approved oil with a higher hths than the usual 3.0 / 3.1 : Mobil 1 10w-30HM is great but not dexos approved. Is this oil formulated to pass the new lspi testing ?
#4505611 - 09/02/17 04:41 PM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
Garak Offline
Loc: Regina, Saskatchewan, Canada
dexos2 is distinct from dexos1. If it's still under warranty, dexos1 would be the oil GM would recommend you use. dexos1 Gen 2 is reformulated for the LSPI business, apparently. I'm sure dexos2 would work just fine, but as already noted, watch your OCIs (and you'll be spending more on oil based on availability and container size), and it isn't the "exact" oil you're supposed to use. However, it would certainly work.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4505659 - 09/02/17 05:42 PM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
NH73 Offline
Loc: Pa, USA
The requirements of Dexos1 proably wouldn't allow for higher HTHS numbers. None of M1HM doesn't
carry the dexos, so it likely it doesn't pass the new lspi testing. I would say don't worry about the HTHS number and get something with DEXOS1 Gen 2 and Honda HT-6.
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
#4505675 - 09/02/17 06:05 PM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
SR5 Offline
Loc: Down Under
Dexos2 is very close to a Euro C3 oil with high HTHS (> 3.5 cP) and mid-SAPS. It should be fine for 5k miles and in Australia the smaller GM turbo engines, such as the Cruze 1.4 iTi and 1.6 iTi are specc'd Dexos2 by GM Australia.
Yes Dexos2 & C3 oils are suitable for both petrol (gas) and light duty diesel engines. It's Dexos1-Generaion2 that addresses LSPI.
When I enquired about using the low HTHS (~ 3.1 cP) Dexos1 oil in a Cruze 1.4 L & 1.6 L Turbo in Australia, I was told GM-Australia insisted that only the Dexos2 oil was used.
Sorry I have no knowledge of what GM-Homeland say to use in your 2.0 L Turbo. I feel confident it will be fine mechanically, but I don't know about their warranty.
Edited by SR5 (09/02/17 06:10 PM)
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4720840 - 04/08/18 06:27 PM Re: Pennzoil platinum 5w-30 Euro L ? Dexos 2 [Re: Ammofirst]
webfors Offline
Loc: Great White North.. eh
Manual for the 2.0T in the UK:
https://www.dropbox.com/s/olldig2c3k9v398/ATS_Manual_UK.png?dl=0
Dexos 2 required to keep warranty.
Same car, same engine.
17 Cadillac ATS 2.0T, Edge D1G2 5w30, XG10575
17 Dodge GC, VWB 5w30, Fram DL11665
15 DL650, Valvoline 20w50, KN-138
Small engines; RT5 10w30
