What new make/model is easiest to work on?
by AshleyQuick
03/21/18 07:18 PM
Compact Spare Tire Air Pressure
by das_peikko
03/21/18 07:05 PM
[Cut Open] Denso 150-2006 - Virgin
by DuckRyder
03/21/18 07:00 PM
What additives in oil are bad for wet clutches?
by ZZman
03/21/18 05:48 PM
Tire wear - is this usual?
by mjk
03/21/18 05:38 PM
GM 3800 Traction Control Reduced power
by clarkflower
03/21/18 04:40 PM
Uncharted territory for oils in odd weights
by Marco620
03/21/18 04:39 PM
I got the leak on my cruze 1.4T fixed for free
by 901Memphis
03/21/18 04:36 PM
Longer spring hangers for landscape trailer
by motor_oil_madman
03/21/18 04:30 PM
My ATF never gets Hot?
by Gebo
03/21/18 03:59 PM
**FREE** Case of DENSO 150-2006 oil filter
by Hootbro
03/21/18 03:56 PM
Draining water heater - tips?
by HawkeyeScott
03/21/18 03:38 PM
Harley oil in Kawasaki?
by mvent
03/21/18 03:28 PM
Anyone used Meguiars DA Power System?
by Stewie
03/21/18 02:18 PM
Cars CR Thinks Will Last 200K Miles
by knerml
03/21/18 02:04 PM
How to get unavailable original recordings
by grampi
03/21/18 01:37 PM
How much snow you got?
by car51
03/21/18 01:36 PM
Update: Internet Plans - The Good, Bad, Ugly !?!?
by GemStater
03/21/18 01:11 PM
2012 Porsche Cayenne 3.6 V6 Oil Choices
by csufl
03/21/18 01:05 PM
Properly ventilating a Pole Barn
by SOHCman
03/21/18 12:54 PM
john19718, junp, hbsprite, tomcor, csufl
64521 Registered Users
104 registered (1JZ_E46, 4WD, 901Memphis, 2K2AcuraTL, 14Accent, 14 invisible), 1663 Guests and 95 Spiders online.
64521 Members
68 Forums
280200 Topics
#4504889 - 09/01/17 09:09 PM Knock sensor location
otis24 Offline
Loc: South Dakota
1996 Mercury Villager,3.0 V6 engine. Where is the knock sensor located? Vehicle in question runs great. It has 239k miles. Probably needs a timing belt too. How long can I go before replacing the knock sensor?
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2016 Dodge Grand Caravan
(3.6 V6) 46500 miles
#4504904 - 09/01/17 09:28 PM Re: Knock sensor location [Re: otis24]
CT8 Offline
Loc: Idaho
When the knock sensor quits working then change it.
Artificial intelligence is no match for natural stupidity, we shall prevail
#4504921 - 09/01/17 09:45 PM Re: Knock sensor location [Re: CT8]
Merkava_4 Offline
Loc: Clovis, CA
Wait! What!? grin
#4504927 - 09/01/17 09:49 PM Re: Knock sensor location [Re: Merkava_4]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
Wait! What!? grin
dont borrow trouble
02 Wrangler super-s 10w30
87 F250 proline 15w40
04 Tahoe super-s 10w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4504929 - 09/01/17 09:54 PM Re: Knock sensor location [Re: otis24]
john_pifer Offline
Loc: Nashville, TN via Memphis
Yeah, don't fix what ain't broke.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 198K
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
#4505004 - 09/02/17 01:10 AM Re: Knock sensor location [Re: otis24]
B320i Offline
Loc: Australia
Knock sensors don't always throw a CEL when they go bad. There can be electrical deterioration (No, I don't understand how or why, but it happens), or the sensor can go "deaf," in which you'll start hearing the engine pinging under some loads.
If visibly cracked and deteriorated, you should replace them - as this is one way they can "go deaf." If the vehicle has developed a pinging issue - replace.
'93 BMW 320i 217,000km - Valvoline Engine-Armour 15w40, Mann Filter.
#4505043 - 09/02/17 04:37 AM Re: Knock sensor location [Re: otis24]
FowVay Offline
Loc: Southeastern USA
The knock sensor on this engine is between the cylinder banks below the lower intake manifold. If it fails it will not set a DTC on this particular engine.
This picture shows the location with the heads and manifold removed.
Quaker State across the board.
