Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
27 registered members (Black_Thunder, AnthemBassMan, Brad_C, 555, BrianF, AndyB, 3 invisible), 475 guests, and 65 spiders.
Topics286,262
Posts4,905,488
Members67,589
Most Online2,967
Mar 10th, 2019
Honda vs Acura K24 oil specs. #4504816
09/01/17 07:46 PM
09/01/17 07:46 PM
Dallas,Tx USA
aquariuscsm Offline OP
Dallas,Tx USA
I saw this today. K24 engine in an Acura. It says "5W30" on the oil cap. The Acura oil chart is also interesting. It first specs 5W30,then 5W20,then next says 0W20 "ok" and "acceptable". First of all,why does Acura spec 5W30 for the K24 when Honda specs 5W and 0W20 only? Is the engine identical in both Acura and Honda cars? Per the Acura chart,is it saying the 20wts are a compromise in protection by saying it's ok and acceptable?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4504829
09/01/17 08:07 PM
09/01/17 08:07 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
The high output versions of the K engines had called for 30
There's no replacement...'scosity for natural viscosity
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4504878
09/01/17 09:00 PM
09/01/17 09:00 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Just go with the thicker oil, Acura is just another Honda. Its all a game, the engine wouldn't mind a bit if you put some 0w40 in it in fact it might have less wear and be quieter.
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4504914
09/01/17 09:38 PM
09/01/17 09:38 PM
USA
slacktide_bitog Offline
USA
They are slightly different, as Peter alluded to. The engines are not identical.
The TSX K24 has a higher compression ratio (10.5:1 vs 9.6:1), 200 hp instead of 160, uses premium not regular.
Re: Honda vs Acura K24 oil specs. [Re: slacktide_bitog] #4504966
09/01/17 11:01 PM
09/01/17 11:01 PM
Trav Offline
Trav  Offline
Its still a Honda K24 just with higher compression, its identical otherwise in every way. The engine is sold in Europe as a Honda (acura doesn't even exist as a brand) in all variants and all use the same oil.
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505111
09/02/17 07:16 AM
09/02/17 07:16 AM
NC
Vladiator Offline
Vladiator  Offline
NC
And on the other side of the pond all Hondas that I know ride on nothing but 10w40/5w40/0w40 synthetics. From Europe to Siberia. I use the same regime on this side of the pond as well. Except 10w40 tho. My honda purrs like a kitten on w40 oils and so did all previously owned hondas.
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505121
09/02/17 07:22 AM
09/02/17 07:22 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
splitting hairs again?
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505173
09/02/17 08:20 AM
09/02/17 08:20 AM
OH
fdcg27 Offline
fdcg27  Offline
OH
If you'd rather use a 5W-30, then just go ahead and do it.
Certainly won't do any harm.
A quick calculation in my head indicates that if I drive 1500 miles a month, which our K24 is now seeing, I might save an entire gallon of gas using a 0W-20 rather than a 5W-30.
Not enough to worry about if you're inclined to use a 5W-30.
Go for it and let us know what the impact on willingness to rev and fuel consumption is. I'd bet you'll see no discernable difference and I'd also bet that the engine will seem smoother and quieter.
18 Accord Hybrid FF
17 Forester 18K VME 0W-20
12 Accord LX 96K SSO 0W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505176
09/02/17 08:22 AM
09/02/17 08:22 AM
WI.
dblshock Offline
dblshock  Offline
WI.
alot smoother.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505281
09/02/17 10:22 AM
09/02/17 10:22 AM
Cali's Central Coast Wine Coun...
SLO_Town Offline
SLO_Town  Offline
Folks:
I drive a bought new by me 2010 Honda Element SC. I have 158K miles on it now. The K24 motor has always sounded "industrial", like a tractor. It's always been noisiest when cold, with what sounds like piston slap.
Honda specs 5W-20 (and later back spec-ing 0W-20). I've used those two viscosities, Mobi1 1 and Castrol, the Extended Performance versions. One time I tried German Castrol 0W-30 to see if that would quiet down the motor. It didn't. The last year or so I've been using Castrol Extended Performance 5W-30. The motor remains as noisy as it was on 5W-20.
My point is that anyone who claims that a thicker oil will quiet down the K24, well, it didn't quiet mine down.
Just an FYI. I'm not picking a fight.
Scott
03 BMW E46 330Ci ZSP (Euro Castrol 0W-30)
10 Honda Element SC (Kendall GT1 Max 5W-30)
11 BMW E90 328i M-Sport (Euro Castrol 0W-30)
16 VW Passat VR6 3.6L SEL Premium (Euro Castrol 0W-30)
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505351
09/02/17 11:22 AM
09/02/17 11:22 AM
Dallas,Tx USA
Dallas,Tx USA
Mine purrs like a happy kitty on PP 0W20!! From cold start to hot start,it's smooth and silent. I'm just like the rest of everyone here,always curious and on the quest for ultimate engine lubrication. After all,that's what brought us all here in the first place laugh If we weren't all oil nerds and car freaks,we wouldn't be here.
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505853
09/02/17 10:03 PM
09/02/17 10:03 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
+1
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505917
09/02/17 11:58 PM
09/02/17 11:58 PM
Pennsylvania
K23Turbo Offline
K23Turbo  Offline
Pennsylvania
I had a K20Z3 in a Civic Si specd for 5W30. It loved the stuff and didn't matter which brand. Also had a RDX which required synthetic 5W30. M1 and PP at the time. For a K24 motor I'd run a synthetic 5w30, 10W30, 0W30 or 0W40 European Formula.
Re: Honda vs Acura K24 oil specs. [Re: aquariuscsm] #4505934
09/03/17 01:38 AM
09/03/17 01:38 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Just to add to the discussion, the same base engine when used as an outboard (BF135) specifies 10W30.
https://www.northeastmarine.net/images/products/manuals/honda/bf135-manual.pdf Page 69.
and FC-W
https://www.nmma.org/assets/cabinets/Cabinet456/FC-W%20Combined%20Certification%20Procedure%20Manual%20(3%2016)%201.pdf
which specifies a post shear test HTHS of 3.3.
If all this "flow" was good, why doesn't Honda spec for "flow" ???
Re: Honda vs Acura K24 oil specs. [Re: Shannow] #4505939
09/03/17 02:09 AM
09/03/17 02:09 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Much more effort and rpms required of an outboard. 4 wheels roll a lot easier than a bass boat running 4000-5500 rpms most of the time. So I can see why a thicker oil is required for outboards.
