MC. FL910s 50 Hours on Kohler 33 HP- Napa 15w50 FS
MD
I cut this run short because of other issues. The filter looks new and I put 50 quick hours on it in the upper 90's heat.
I would easily run this out to a 100 hours and since it was under $3.50 I'd toss it after that. Why not????
Adam who?
Always wondered what 50hrs on a Kohler twin engine would look like. Easily 100 and maybe 200 hrs using a Fram Ultra. Thank you for sharing.
You could do that with the Motorcraft.
Originally Posted By: JohnnyJohnson
Is that Kohler a Natural gas unit or regular gasoline?
Regular gas model.
I do that with the FL910 on my Fusion with 10K OCIs, and have for many years. I also use the 910 on my Briggs 21HP for 1 1/2 year OCI. They always look great. Besides the oil you use is farrr more important than the filter you use.
Originally Posted By: SilverFusion2010
That filter looks barely used
Notice the filter media in picture two is light in color and darker in the third picture.
I assume the darker side was the side that got less air cooling as it was tight to a body panel.
No issue but it isn't the camera. The media was evenly oil soaked. Looks good.
Cleaning the shop after several months of bargain hunting - alongside of the FL910s are Mobil 1, Fram Ultra, and several Bosch DP's ... same deal, mower and Fusion share filters - eBoost and 5.3L now share filters - 4L60e & Chrysler 300 share filters - Cruze & Charger are cartridge ...
Looks good Jim
Dad runs SAE 30 DELO in his 69 SPEEDEX lawnmower as it doesn't have oil filter
Thank you Adam
I unloaded a new TG3614 on it and straight conv. 10w40.............. long story
In the future when they are a deal- under $4 I'll use the MC FL910s- I like WHITE and SADBV's
