48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
105 registered members (64bawagon, A310, ammolab, 1foxracing, 14 invisible), 1,851 guests, and 41 spiders.
Topics295,213
Posts4,930,096
Members66,716
Most Online2,553
Oct 27th, 2018
Copper Grease vs Permatex Silver Anti seize? #4504652
09/01/17 04:13 PM
09/01/17 04:13 PM
VA
maverickfhs Offline OP
VA
So I am planning to do some maintenance for EXUP valves on the motorcycle and many links are suggesting to use copper grease.
I have some Permatex silver anti seize laying around. Can I use it?
Thanks for the help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504665
09/01/17 04:22 PM
09/01/17 04:22 PM
California
nthach Offline
nthach  Offline
California
The copper grease seems to hold up to heat better, but I would use what you got unless you can wait for Amazon to bring you some C5-A.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: nthach] #4504668
09/01/17 04:26 PM
09/01/17 04:26 PM
VA
VA
Thanks, yeah one I have can go up to 1600 and C5-A is 1800 degrees.
Any idea if I can C5-A or similar locally at Walmart or AAP or even pep Boys?
Thanks
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504679
09/01/17 04:32 PM
09/01/17 04:32 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I prefer Gold anti seize ROFL
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504765
09/01/17 05:58 PM
09/01/17 05:58 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Thanks
Sure! You should be able to find the Permatex version of copper antiseize locally. It is also good up to 1800 F. Check NAPA if no one else has it.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504826
09/01/17 07:02 PM
09/01/17 07:02 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Copper and Aluminum are on opposite sides of the electro-negativity chart. One acts like a battery anode, and the other acts like a battery cathode. Put them together and you get major corrosion. Not a good idea.
Copper based anti-seize grease used on steel or iron is probably a good idea, but I would not use it on anything with Aluminum.
In basic Chemistry the teacher told a story about someone who used brass pipe fittings on the cooling connections on a very expensive Aluminum mold. After about a year the corrosion at the brass (brass has copper in it) and Aluminum connections was soooooo bad that the entire mold had to be scrapped.
Also, nail up copper gutters with Aluminum roofing nails and in a year or so the gutters will fall down.
Do not use copper based anti-seize on an Aluminum head.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Copper Grease vs Permatex Silver Anti seize? [Re: JimPghPA] #4504828
09/01/17 07:04 PM
09/01/17 07:04 PM
VA
VA
That's where I am planning to use : https://www.tapatalk.com/groups/fazer1000/exup-valve-maintenance-t1524.html
What should I use? Silver Permatex or Copper anti seize?
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504835
09/01/17 07:12 PM
09/01/17 07:12 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Those parts should be steel, so it should not matter as much.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504840
09/01/17 07:16 PM
09/01/17 07:16 PM
JimPghPA Offline
JimPghPA  Offline
BTW, Aluminum melts at 1220.58 degrees Fahrenheit, so if your motorcycle has Aluminum heads why would you be worried about using an anti-seize that is ONLY good up to 1600 F.
JimPghPa
Re: Copper Grease vs Permatex Silver Anti seize? [Re: JimPghPA] #4504841
09/01/17 07:17 PM
09/01/17 07:17 PM
VA
VA
Honestly, I have no clue. In the link I posted above it say to use copper and I only have silver one.
Hence I asked the question, so I should be good to go with silver Permatex anti seize and lubricant, right?
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504842
09/01/17 07:20 PM
09/01/17 07:20 PM
MI
doitmyself Offline
doitmyself  Offline
MI
What has always been brought up at this point is that Permatex actually states on their web site about copper antiseize: "Suggested Applications: Spark plug threads installed in aluminum". Go figure. It leaves anyone knowledgeable about galvanic corrosion scratching their head.
https://www.permatex.com/products/lubric...eize-lubricant/
Re: Copper Grease vs Permatex Silver Anti seize? [Re: JimPghPA] #4504843
09/01/17 07:22 PM
09/01/17 07:22 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Do not drop a penny in the bilges of your aluminium sailboat either.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: maverickfhs] #4504885
09/01/17 08:06 PM
09/01/17 08:06 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
“Galvanic corrosion does not occur when dissimilar metals are completely dry,”.....water needs to be present for galvanic corrosion to occur.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: philipp10] #4505045
09/02/17 03:46 AM
09/02/17 03:46 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Yeh. So only usually a problem on Planet Earth.
Re: Copper Grease vs Permatex Silver Anti seize? [Re: Ducked] #4506068
09/03/17 08:18 AM
09/03/17 08:18 AM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
not in this application. Water is not hanging around these areas typically.
