1991 Toyota Previa New JDM engine Redline
by Kurtatron
9 minutes 32 seconds ago
8 yr old channeling John Bonham
by Toy4x4
34 minutes 16 seconds ago
Traveller nlgi 2
by Spitter
Today at 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
Today at 05:08 PM
Any nano reefers here?
by RichardS
Today at 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
Today at 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
Today at 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
Today at 04:31 PM
help me choose...
by chaindrive
Today at 04:07 PM
France F1 Grand Prix
by DeepFriar
Today at 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
Today at 03:16 PM
Best additive in oil to clean sludge?
by ffgb
Today at 02:19 PM
Who is a Dirt Track regular?
by thooks
Today at 01:39 PM
eco plug oil plug video is restricted
by edwardh1
Today at 01:27 PM
Political comments
by ridgerunner
Today at 01:23 PM
My Ford orange turned pink
by BeerCan
Today at 12:45 PM
Any plants/garden experts?
by maverickfhs
Today at 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
Today at 12:23 PM
Brake fluid for a '03 Volvo S60
by earthworm
Today at 11:22 AM
Oil Weight Change - Mid Production Cycle
by PolarisX
Today at 11:20 AM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
112 registered (93cruiser, 5AcresAndAFool, andyd, 77GrandPrix, 97prizm, alphadog, 12 invisible), 1496 Guests and 38 Spiders online.
65286 Members
67 Forums
285727 Topics
Page 1 of 2 1 2 >
#4504468 - 09/01/17 02:04 PM When to change ATF/filter in 5.3
Speak2Mountain Offline
Loc: Mississippi
Son has '10 Avalanche w/94K miles. To my knowledge, its never been changed. He doesn't off road it or tow, but its creeping up on 100k.
#4504509 - 09/01/17 02:33 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
MolaKule Offline
Loc: Iowegia - USA
Change filter after doing a drain and refill two times.
I.e., change filter on the third drain-refill.
#4504605 - 09/01/17 04:25 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
slacktide_bitog Online   content
Loc: USA
Does that transmission have a drain plug? If it doesn't, get the Dorman pan that has one.
#4504675 - 09/01/17 05:31 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
barkingspider Offline
Loc: socal
Change the filter and Dex vi now
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
#4504793 - 09/01/17 07:25 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
gman2304 Online   content
Loc: n.c.
I should change the transmission filter on my 2005 avalanche. As far as I know its the original filter. Just rolled over 190,000 miles. I have siphoned and filled it several times . No transmission drain on my 2005. Does anyone have any experience with the Dorman pan? I might get around to it this winter.
#4504953 - 09/01/17 10:36 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
Loc: n.c.
The Dorman pans got middle of the road reviews on Amazon. Probably weld a drain plug in my pan when I do this job.
#4504967 - 09/01/17 11:02 PM Re: When to change ATF/filter in 5.3 [Re: gman2304]
4WD Offline
Loc: Texas
B&M aftermarket plug in my 4L60e pan - $10 or so - toss the nylon seal and use copper washers - on my ramps it drains 4 quarts clean and easy - once you put a new pan filter in - just do that a couple times and then once a year during oil change ...
#4505446 - 09/02/17 12:59 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
zuluplus30 Offline
Loc: Fly-over country
I generally do fluid every 50k and fluid/filter at every 100k. I tow quite a bit and the fluid always looks good. I could probably go closer to 75-100k but it makes me feel better. Cheapest Dex VI I can find (usually Supertech). Never had a trans problem ever.
#4505526 - 09/02/17 02:27 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
Loc: Mississippi
So would you guys pump it out and not bother with filter or change out everything.
#4506187 - 09/03/17 11:33 AM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
NYEngineer Offline
Loc: NY, NY
That truck has the six speed in it, correct? Not only should he change the fluid and filter, he should add an auxiliary trans cooler if it doesn't already have one.
My 2009 Suburban has had the fluid and filter changed at 9,000 miles (when I bought it), 50,000 miles and 100,000 miles. At around 125,000 miles, I found the fluid was brown and burned. I had the trans shop flush and service. Last month, at 139,000 miles, it wasw slightly burnt again. Shop flushed, serviced and added a factory cooler. Inside of the trans looked ok.
With the cooler, as small as it is, the trans temps are nice and low, like 174 degrees at 70 mph on a 78 degree day. Fluid seems to be lasting fine. We'll see as I rack up some miles.
I'd like to hold off on a rebuild if I can as it costs about 3500 dollars.
Also, tell him to drive that truck around in M5 and not D. It keeps the engine in V8 mode and not that stupid four cylinder thing that fails and destroys the cam. I drive mine in M5 all the time and it runs great.
My brother's 2007 Tahoe had one of those controlled intake lifters fail. It destroyed the cam. You have to remove the heads to change lifters in that engine so we swapped the entire engine. We replaced the four DOD lifters with regular intake lifters and he had the system programmed out of the computer. Truck has been stellar ever since. He drives it every day as it's his work/ family vehicle.
Edited by NYEngineer (09/03/17 11:36 AM)
#4506219 - 09/03/17 11:54 AM Re: When to change ATF/filter in 5.3 [Re: NYEngineer]
Loc: Mississippi
thx, by. Currently he's in an engineering program at M SU, and driving a ton. Anymore, insight will help
#4506518 - 09/03/17 06:29 PM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
NYEngineer Offline
Loc: NY, NY
The only other helpful thing I can think of is change the plugs and wires if it hasn't been done. The rear passenger side one is a beast but it really makes them run sweet.
Also, keeping a fresh air filter in it makes a small but noticeable difference.
#4602306 - 12/13/17 06:32 AM Re: When to change ATF/filter in 5.3 [Re: MolaKule]
Ether Offline
Loc: Europe
Sorry for resurrecting an old thread,but can anyone explain the merits of doing this please.I had heard of it before when changing the ATF in very old transmissions,but i don't recall the reasons as to why,or why not.(I am genuinely interested)
#4602421 - 12/13/17 09:23 AM Re: When to change ATF/filter in 5.3 [Re: Speak2Mountain]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
I, myself , have changed my policy after seeing too many good transmissions that were just disgusting with the metal sludge in the pan. Nothing was wrong with the transmissions. All went on to live long and healthy lives. It's just that over 80k+ miles, these things shed a lot of metal, and I'd rather clean all of that out than leave it running around in there.
Magnets need to be cleaned as well in order to stay effective. When you do a drain and fill, none of this is being taken care of.
#4602426 - 12/13/17 09:27 AM Re: When to change ATF/filter in 5.3 [Re: DoubleWasp]
kschachn Online   content
Loc: Upper Midwest
The “sludge” is metal? I thought that was clutch material?
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
Page 1 of 2 1 2 >
