Thoughts on new AMAZON branded oil...?
by PantherFan88. 09/25/18 10:47 PM
Clutch kit?
by andrewp1998. 09/25/18 10:34 PM
Galaxy S8+ weird app when clearing storage
by KrisZ. 09/25/18 10:18 PM
Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
53 registered members (carlprop, 10WSmuckers, AVB, advocate, boulderdentist, 7 invisible), 801 guests, and 33 spiders.
Topics291,025
Posts4,854,646
Members66,070
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
Is ZERO oil consumption the ultimate goal?? #4504214
09/01/17 09:25 AM
09/01/17 09:25 AM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Is the ultimate goal to find an oil/wt that doesn't burn?
I just recently serviced my 2 trucks with full synthetic 10w30. One is carbed, one fuel injected.
My driving has lots of cold starts. wife drives 7500 miles a year and i do maybe 5500.
The carbed truck would burn a qt every 3 months. so far nothing.
The FI truck seems to like the thinner 10wt also as it burns 10w40 and 5w30 like crazy. the 10w30 seemed to stop it all together.
I don't mind checking oil levels but it would be nice to only add .5 quart per interval or none @ all.
Our prius goes 7.5k and only consumes a pint.id be more then happy with that consumption.
Supertech Junky
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504226
09/01/17 09:36 AM
09/01/17 09:36 AM
The Motor City
Kestas Offline
Kestas  Offline
The Motor City
Zero?... won't happen. For starters, the valve stem seals our company produces are designed to bleed a little oil to lubricate the valve guides. Also, low tension piston rings allow more oil to be burned.
Certainly oil loss is kept to a minimum in modern engine design. None of the engines I take care of need topping off between oil changes. Barring unforeseen new designs, there will always be oil loss designed into engines.
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504228
09/01/17 09:36 AM
09/01/17 09:36 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
My past 3 cars('12 Accord, '14 Accord, '17 Mazda6) have not had any drop on the stick during an OCI. I wished they did as I like to replenish additives. My '05 Rainier would use 1/2 quart in 10k miles.
My E450 used a quart in a 5k interval using 5w-20 but my switch to a heavy 30 grade shows little drop so far in 3k miles. I'm showing no difference in mileage since switching to an A3/B4 oil.
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504232
09/01/17 09:42 AM
09/01/17 09:42 AM
MIchigan
Warstud Offline
Warstud  Offline
MIchigan
What brand of oil are you using?
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504235
09/01/17 09:46 AM
09/01/17 09:46 AM
Charlotte, NC
Oldmoparguy1 Offline
Charlotte, NC
We have 2 vans that use no oil between changes. My wifes 2013 Dodge GC with 3.6 pentastar and 75K and my sons 2006 Chrysler T&C with 3.3 and 221K. Both get 10K oci.
A Randomly Selected Thought For The Day:
If Noah had used Zip, he could have used a smaller boat.
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504237
09/01/17 09:46 AM
09/01/17 09:46 AM
AZ
leroyd92 Offline OP
leroyd92  Offline OP
AZ
Supertech FS 10w30
Supertech Junky
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504275
09/01/17 10:30 AM
09/01/17 10:30 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
I have two V6 Camrys, one with 200 K on the clock, which burn no oil between changes.
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504280
09/01/17 10:34 AM
09/01/17 10:34 AM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
It depends on the break-in. If it was run hard and the rings wore into the bore properly you'll have very little consumption. Assuming your PCV system is working correctly
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504287
09/01/17 10:44 AM
09/01/17 10:44 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Zero oil consumption would be a beautiful thing. Stem seals and rings let us down, along with high Noack #s.
Also, you could take two of the exact same engine off the production line and their oil usage:viscosity ratios would be different just because of tolerance & clearance, plus different break in & usage patterns amplinfy these differences so their is no set rule or ratio.
Experiment with different brands and viscosities until you find the oil that suits your engine best. I burn measurable amounts of grp.1/2/3 but immeasurable on the dipstick with Redline (same viscosity throughout)
Cable ties should hold it
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504291
09/01/17 10:49 AM
09/01/17 10:49 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
If you are not burning some oil, you are not driving hard enough. smile
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504296
09/01/17 10:55 AM
09/01/17 10:55 AM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
Nope, I use quality clearance oil, if it needs some top off, so be it.
My Sonata seems to like this Mobil 1 more than the Pennzoil Ultra though, about 1/2 the consumption, which wasn't much to begin with.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504300
09/01/17 10:57 AM
09/01/17 10:57 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Mine doesn't use enough to add between changes. At change time it might be a cup low... but that's about it.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504307
09/01/17 11:02 AM
09/01/17 11:02 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Not a goal of mine grin
Re: Is ZERO oil consumption the ultimate goal?? [Re: mightymousetech] #4504319
09/01/17 11:09 AM
09/01/17 11:09 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
To be more correct, you're not engine braking your Honda enough wink
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
Re: Is ZERO oil consumption the ultimate goal?? [Re: leroyd92] #4504320
09/01/17 11:09 AM
09/01/17 11:09 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
In 10K miles with my 4Runner and lots of desert driving the V8 burns about a half a quart as measured on the dipstick. The half quart is just an estimate meaning half way between the high and low marks. That could be a bit more, I don't know. The oil is Red Line 0w-30.
I don't think there's such a thing as no oil consumption and the dipstick is not really accurate when it comes to small measurement differences.
Page 1 of 3 1 2 3
