Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
79 registered members (beanoil, ARCOgraphite, avi1777, Bailes1992, BeerCan, Berny, 8 invisible), 1,639 guests, and 59 spiders.
Topics286,387
Posts4,907,333
Members67,614
Most Online2,967
Mar 10th, 2019
2001 Dodge 2500, 370k, 18k miles on RT6 #4504196
09/01/17 09:10 AM
09/01/17 09:10 AM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
Mid-OCI oil sample of RT6 CK-4.
From Polaris:
Truck Odometer: 370600 mi
Miles on oil: 18000
5 quarts of makeup oil added.
Fram Ultra filter.
Wear Metals:
(Element (ppm); 235k, 322k, 338k, 352k, 370k)
Iron; 42, 52, 30, 50, 38
Chromium; 3, 3, 1, 2, 1
Al; 4, 5, 3, 4, 3
Cu; 3, 4, 1, 2, 1
Lead; 9, 31, 4, 7, 2
Contaminants:
Silicon; 6, 13, 7, 9, 7
Sodium; 8, 6, 5, 4, 7
Potassium; 62, 0, 1, 1, 4
Multi-source metals:
Moly; 75, 76, 5, 4, 0
Boron; 83, 38, 112, 69, 106
Additive metals:
Mag; 1333, 1198, 179, 163, 94
Calcium; 960, 1111, 2174, 2198, 2053
Phos; 1138, 1104, 1012, 1048, 924
Zinc; 1439, 1471, 1277, 1271, 1143
Fuel Dilution; <1%, <1%, <1%, <1%, <1%
Soot; <0.1%, <0.1%, <0.1%, 0.4%, 0.3%
Water; <0.1%, <0.1%, <0.1%, <0.1%, <0.1%
KV100 (cSt); 15.1, 15.1, 15.3, 15.3, 15.4
TBN; 6.54, 6.99, 5.69, 4.27, 4.96
Oxidation; 15, 16, 14, 14, 13
Nitration; 10, 10, 9, 9, 8
Polaris Comments:
No abnormal findings. Resample at normal interval.
A pretty boring UOA, just the way I like it. Only thing is a developing trend with soot, but not a serious amount.
Corrected Iron wear rate is 3.1ppm per kmile. That's OK.
I changed the filter after taking the oil sample. Fram Ultra not available at WalMart, so I bought a Purolator Boss.
Plan to extend the OCI to 36,000 miles.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4504221
09/01/17 09:32 AM
09/01/17 09:32 AM
N.C.
gman2304 Online content
gman2304  Online Content
N.C.
"5 quarts of makeup oil added"
^ Does all the makeup oil skew your sample? What is the sump capacity?
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4504270
09/01/17 10:28 AM
09/01/17 10:28 AM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
Nice report.:) Sure gotta like the 6BT.:)
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: gman2304] #4504632
09/01/17 04:52 PM
09/01/17 04:52 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
Yes, makeup oil skews the sample. It dilutes the wear metals and contaminants, bolsters the TBN, but doesn't change the additive package if you use the same oil as the original fill. I run an 11 quart fill in the truck, and add oil when it gets 1 qt down, so the average fill is 10.5 quarts. Adding 5 qts over the sample interval has caused a dilution of 5/10.5, or 48%. So to find the actual wear metal concentration, you would have to multiply the UOA readings by 1.48 to get what the concentration would be if there had been no oil consumption. The number on Iron that I quoted was based on the UOA value of 38 multiplied by 1.48.
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4505325
09/02/17 11:05 AM
09/02/17 11:05 AM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
Not quite true. It is an exponential formula, of the form 1 - exp(-at), where t = hrs use and a = constant which includes rate of consumption.
If half the oil is replaced gradually over time, for example, about 69.3% of the sump is "original" oil, the other 30.7% is replaced oil of various ages.
The full formula is
OSF = (1/R) * (1 - exp(-Rt/V)) OSF = oil stress factor in kWh/gm, R = specific oil consumption in gm/kWh, t = total time in hrs of OCI, V = specific oil capacity in gm/kW
you calculate your kW not from peak hp but using mean fuel consumption, average speed (if vehicle has a nav computer!) and an educated guess at specific fuel consumption: 250gm/kWh for gasoline, 200gm/kWh for diesel. Diesel weighs 3300gm/US gal, gasoline 3000gm/US gal. My Unimog averages 36mph and 9mpg. So 4 gal/hr or 13200gm/hr. That comes out to 66kW average power (peak is 191)
My oil capacity is 29.6L, oil weighs ~860gm/L, so specific oil capacity 29.6*860/66 = 384 gm/kW.
Oil consumption is 1L/2500mi or 860gm/4583kWh = 0.18765 gm/kWh.
I just went an OCI of 703 hrs (25600mi)
1/R = 5.33 kWh/gm of oil
The exponential is 0.71, so multiply 1 - 0.71 = 0.29 x 5.33 = 1.54 to give the oil stress factor. For NO oil consumption the formula reduces to OSF = t/V, in my case 1.83. So I reduced my OSF by about 16% with makeup oil during my recent OCI. Definitely different than one's "linear estimate" of 10/29.6 = 33.8%
Source CIMAC paper #21 2004 "Oil stress Investigations in Shell's medium speed laboratory engine"
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4505724
09/02/17 07:04 PM
09/02/17 07:04 PM
Michigan
A_Harman Offline OP
A_Harman  Offline OP
Michigan
I think you are over-complicating the correction to a relatively simple problem in the calculation of concentration of a solution, and are introducing factors which you have no way of accurately calculating. You cannot use 200 g/kW*hr as an average for fuel consumption for a diesel engine. Yes, that is a good estimate for a diesel running at peak torque, but is not accurate for engines running at less than full load.
But you may be right that I am oversimplifying the correction factor for my contaminant concentration. I am looking for a correction factor to account for the makeup oil added prior to an oil sample so I can accurately assess the concentration of contaminants measured in the sample. If I were to keep running on an OCI until I added 11 quarts, there would still be 50% original oil in there, and 50% oil of varying ages. Maybe my linear calculation doesn't account for this.
How about this:
Concentration of contaminants = 1-(number of makeup quarts/(base oil fill volume + number of makeup quarts))
The series would go like this:
1 quart added: 1-(1/12)=.916
2 qts added: 1-(2/13)=.846
3 qts added: 1-(3/14)=.785
4 qts added: 1-(4/15)=.73
5 qts added: 1-(5/16)=.688
11 qts added: 1-(11/22)=.50
So at 5 quarts added, the reported concentration of Iron in my oil sample is diluted to 68.8% of what it would have been. Translating that sentence into an algebraic equation:
Reported concentration = .688 x Corrected concentration
So to get the Corrected concentration, the reported concentration has to be divided by the correction factor:
Corrected concentration = Reported concentration / .688
Corrected concentration = 38 ppm Iron/.688 = 55 ppm Iron
Have I gone wrong somewhere in my train of logic?
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4505851
09/02/17 10:01 PM
09/02/17 10:01 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
How about this:
Yes, you are still oversimplyfying.
Because as oil gets consumed, both "original" oil and and added oil get consumed. If oil is consumed continuously and added continuously, the solution involves an exponential. If it is done in relatively small steps it still approximates an exponential solution. Applying the exponential approximation to the problem of an 11 qt pan and 11 qts of makeup oil, the "corrected ppm" goes up by 1/(ln 2) = 1/.693 ~ 1.4.
And there is another consideration. There are 2 reasons for UOA: Figure out what's happening in the motor, and seeing if oil is still OK for longer OCI next time. "Correcting" numbers is reasonable for the 1st reason but not for the second.
Changing the fuel consumption coefficient will obviously change results somewhat. But continuous mixing problems are always differential equations and the solution involves integration, so an exponential solution is very likely in any sort of continuous mixing problem.
Charlie
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4505863
09/02/17 10:22 PM
09/02/17 10:22 PM
Delaware
GeeTeeEyeGuy Offline
Delaware
This is why I failed Calculus the first time.
2016 GTI
2015 Golf Sportwagen TDI
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4505864
09/02/17 10:23 PM
09/02/17 10:23 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
The accurate "correction factor" is (Rt/V)/(1 - exp (-Rt/V)). In other words "no oil consumption OSF" divided by "real OSF".
Charlie
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4529036
09/29/17 05:43 AM
09/29/17 05:43 AM
Monroe,CT
Bambam Offline
Bambam  Offline
Monroe,CT
crzy
07 DMAX CC 4x4 ~ Synthetics in the driveline, Delo XLE 15w40 in the sump.
Dirt Bikes and a Harley for the summer!
Ski-Doo for the winter.
Re: 2001 Dodge 2500, 370k, 18k miles on RT6 [Re: A_Harman] #4532107
10/02/17 02:47 PM
10/02/17 02:47 PM
Venezuela, South America
Emanuel Offline
Emanuel  Offline
This debate is awesome
