Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
Food Safety - If You Have Children
by Zee09
06/23/18 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
06/23/18 05:02 PM
Chain cleaning and lube
by dadinfo
06/23/18 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
06/23/18 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
06/23/18 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
06/23/18 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
06/23/18 04:30 PM
mobil 1 rebate check
by Fitter30
06/23/18 03:52 PM
Cab mount failure
by ram_man
06/23/18 03:31 PM
02 Saab aero oil?
by Newuser
06/23/18 03:00 PM
Extend wifi range
by clarkflower
06/23/18 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
06/23/18 01:57 PM
Lease Buyout by Dealer
by Throt
06/23/18 01:52 PM
13 Ford Escape
by RedOak
06/23/18 01:10 PM
New washer pump leaking fluid
by llmercll
06/23/18 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
06/23/18 12:10 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
80 registered (2004tdigls, 2009Edge, 10WSmuckers, advocate, Aero540T, 9 invisible), 1531 Guests and 46 Spiders online.
65303 Members
67 Forums
285870 Topics
#4504183 - 09/01/17 09:02 AM VWB vs PYB vs Castrol GTX: Synthetic content?
HoosierJeeper Offline
Loc: WI
It seems like VWB and Castrol GTX are starting to use synthetic blends a bit for the basic oils, is Pennzoil doing the same with PYB? (side question, would that mean Pennzoil HM is too)?
Just curious...couldn't find any more recent threads.
Thanks!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4504197 - 09/01/17 09:11 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
CT8 Offline
Loc: Idaho
Define synthetic. There will be what is needed to meet the spec.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4504207 - 09/01/17 09:18 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
fenixguy Offline
Loc: NC
The more time I spend on this forum, the less I know about conventional vs. synthetic. grin I've determined that it's mostly marketing.
Anyway, just dropping by to follow. popcorn2
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4504215 - 09/01/17 09:27 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
Loc: WI
So let's take Maxlife blend for example...that's Group II+, correct? And it's 30% "synthetic" oil IIRC. So are VWB and PYB Group II+ as well? And does that imply they have a similar amount of "synthetic" in them?
Trying to get on to PQIA's site but it's not loading for me.
#4504229 - 09/01/17 09:36 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
Bgallagher Offline
Loc: Boston, MA
I believe that for the SN rating it would require some synthetic base but what % is one of life's mysteries
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4504234 - 09/01/17 09:45 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
SilverFusion2010 Offline
Loc: Crawfordville FL
People get too hung up on synthetic vs non. Unless you're running extended oci it just doesn't matter. The fuel diluting DI engines have a lot of people changing at 5k anyway when the oil itself could go to 7500-10k if it wasn't diluted.
It just doesn't matter. Particularly if it meets dexos1.
If you have a warranty you should follow the OLM which seems to have many people dumping around 7500 miles.
SN rated Merlin's Unicorn Lube, will perform just like Penzoil conventional, which is also an SN rated lube
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4504266 - 09/01/17 10:20 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: SilverFusion2010]
Bottom_Feeder Offline
Loc: Occupied Virginia
Does Walmart carry that?
#4504273 - 09/01/17 10:30 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
In the other universe yeah
#4504303 - 09/01/17 11:00 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
Virtus_Probi Offline
Loc: New England
A lot of us were guessing that this sample of PYB 10W30 must have had a significant synthetic content with those NOACK loss results...
http://www.pqiadata.org/Pennzoil10W30.html
2014 Forester XT, 80500 miles
Last Change;
Valvoline Full Synthetic 5W30 d1G2
Tokyo Roki 15208AA170 filter
#4504351 - 09/01/17 11:40 AM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
beanoil Offline
Loc: Midwest, Illinois
Man ya gotta watch what you say...
Someone doesn't know what Unicorn Lube really is.
beanoil: Tough under heat, real dirty afterwards.
#4504376 - 09/01/17 12:05 PM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: beanoil]
Loc: New England
Merlin used his Unicorn Lube to help Arthur get the sword out of the stone...
Last Change;
#4504385 - 09/01/17 12:24 PM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
Char Baby Offline
Loc: ROCHESTER, NY
With most brands of conventional motor oil, 5w30 & 5w30 do have some GrpIII synthetic oil blended in. Less so w/ 10w30 & 10w40 etc. however they may as well, such as is suspected with the PQIA sample of PYB 10W30 that was mentioned.
Edited by Char Baby (09/01/17 12:29 PM)
"Retired"
'06 Mazda 3i 2.0L
'15 Nissan Altima 2.5 SV
#4504389 - 09/01/17 12:32 PM Re: VWB vs PYB vs Castrol GTX: Synthetic content? [Re: HoosierJeeper]
bbhero Offline
Loc: Virginia
I have postulated that it is somewhere between 10-30%. Enough to drop the volatility below the limit of 15%. Sometimes it likely is a much higher percentage like when Pennzoil 5w20 was at 6.8% for a "conventional" oil when tested by PQIA. The latest Castrol GTX Ultraclean 5w20 was around 12.6% and the PDS for the 5w30 states about the same. Which could possibly mean the percentage of group three is in the higher end of my guess. Valvoline Maxlife red bottle is at 40-50% full synthetic and it's NOACK is usually around 12% or a bit lower. So based upon that it would seem to be reasonable to hypothesize that their VWB is around 10-20% for a NOACK result of around 14%.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
