7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
96 registered members (Astro14, aquariuscsm, andyd, Alfred_B, atikovi, 2004tdigls, 2 invisible), 1,517 guests, and 36 spiders.
Topics295,011
Posts4,925,944
Members66,664
Most Online2,553
Oct 27th, 2018
Total tyranny fluid/filter change 03 Grand Marquis #4504135
09/01/17 07:13 AM
09/01/17 07:13 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
129,000 miles and unknown maintenance history.
I dropped pan and changed filter. The magnet was covered in a metal slurry. The fluid was dark red.
I pulled a trans cooler line and pump out a total of 14 nasty quarts.
It was actually easy to do except or a rounded out 10mm bolt on the pan in a bad location.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504157
09/01/17 07:32 AM
09/01/17 07:32 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Did you replace the rounded bolt ?
Best of luck , :-)
Wyr
God bless
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: WyrTwister] #4504162
09/01/17 07:41 AM
09/01/17 07:41 AM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
Let me guess. The rounded bolt was the sneaky little bugger that's partially blocked by the tranny crossmember?
A little trick I've found that helps is to use a shallow socket, slide it above the crossmember sideways and engage it on the bolt, then put an extension on the socket.
Which tranny cooler line did you pull? Top or bottom? I guess it probably doesn't matter, but I've been meaning to do a complete change on my town car at some point.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504168
09/01/17 07:48 AM
09/01/17 07:48 AM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
No drain plug on the torque converter?
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: Canadastang] #4504173
09/01/17 07:52 AM
09/01/17 07:52 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I pulled a rubber hose from under the car between the radiator and engine. Unfortunately the wrong one at first. Trans fluid all over the driveway.
Looking up from the bottom it was the hose on the right.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: The_Eric] #4504174
09/01/17 07:52 AM
09/01/17 07:52 AM
Ontario Canada
Canadastang Offline
Canadastang  Offline
Ontario Canada
Drain plug was eliminated on the 4R70 and perhaps all Ford tranny's in 2001
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: The_Eric] #4504175
09/01/17 07:52 AM
09/01/17 07:52 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I read they stopped that in 2001-2002. I never looked.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504181
09/01/17 08:01 AM
09/01/17 08:01 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
When I was a young pup in the 1970's , it was fairly common to have a drain plug on the torque converter .
I was thinking they stopped providing a drain plug some time there after , 1980's , maybe .
We have a 1991 Caprice , will look when I do a spill & fill on it .
Best of luck to you , :-)
Wyr
God bless
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504190
09/01/17 08:06 AM
09/01/17 08:06 AM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
My MGM was around his mileage when I got, it had the cherry in the pan.
Did filter and 5 qts.
At 150K did flush
Now at almost 180K its fine. Going to do 5 qts soon, I have the dorman pan with the plug.
I like pumping fluid thru the lines. 16qts for a Crown Vic. Goes very fast with a helper, about 1-2hrs with a pan drop on your own.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: Canadastang] #4504191
09/01/17 08:07 AM
09/01/17 08:07 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
It was a pain due to the cross member in the way. I finally hammered a slightly small socket on it.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504198
09/01/17 08:11 AM
09/01/17 08:11 AM
Michigan
ZZman Offline OP
ZZman  Offline OP
Michigan
I decided to try Supertech Mercon V for fluid as it was 2-3 dollars cheaper per qt.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504212
09/01/17 08:24 AM
09/01/17 08:24 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Good stuff. I have used their Dex 3 stuff before and it worked great
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504254
09/01/17 09:08 AM
09/01/17 09:08 AM
The land of USA-made Subies!
SubieRubyRoo Offline
$2-3 cheaper than what fluid? Valvoline MaxLife is still only $18/gal at WM. It's a great fluid as well.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: ZZman] #4504304
09/01/17 10:00 AM
09/01/17 10:00 AM
Albany, NY
ford46guy Offline
ford46guy  Offline
Albany, NY
If you have a local motorcraft distributor you may get it for less than the SuperTech. Look on the Ford site and you may see a non-dealer place come up.
Re: Total tyranny fluid/filter change 03 Grand Marquis [Re: SubieRubyRoo] #4504308
09/01/17 10:02 AM
09/01/17 10:02 AM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
$2-3 cheaper than "Total tyranny" brand ATF...
1997 Maxima 190k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 193k, VWB 5w20 + SSS 10w40, MGL4967
