Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
06/19/18 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
102 registered (2002 Maxima SE, addyguy, Aero540T, 2015_PSD, 9050lx, 2KBMW, 12 invisible), 1595 Guests and 30 Spiders online.
65273 Members
67 Forums
285621 Topics
#4503873 - 08/31/17 09:14 PM 1997 F-350 New Moog Tie Rod Issue
JimmyJohns Offline
Loc: Buffalo, New York
Hi all, as usual I come with problems....
Two months ago I installed Moog tie rods and a drag link on my truck. The passenger side tie rod came with a rubber bushing/spacer in place of a normal dust boot, I suspect this is to reduce/ stop tie rod roll, this is the part number "Moog DS1071 Tie Rod End".
Just two months later, this rubber spacer is torn and blown out, and it needs to be replaced, Here is what it looks like .
I'm trying to brainstorm to figure out what to replace it with, but I'm coming up empty handed. I have no issue fabbing something up if need be. The only idea I have it to buy "The Cure", and place that on the drag link where it meets the tie rod, and put a normal dust boot on the passenger knuckle. I would swip swap spots because that is a hard plastic, and the steering does need some give.
I'm open to ideas, any and all.
#4503900 - 08/31/17 09:47 PM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
Trav Offline
Loc: MA, Mittelfranken.de
#4503914 - 08/31/17 10:33 PM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
Merkava_4 Offline
Loc: Clovis, CA
I'm wondering why Moog put the rubber spacer on just the passenger side.
#4503976 - 09/01/17 01:49 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
Trav Offline
You may be able to find a two piece poly lower control arm bushing with a similar O.D. and cut it to the desired thickness then drill the center hole to fit.
I would look around the energy suspension stuff at AA for some ideas. Poly will outlive rubber many times over.
#4504021 - 09/01/17 05:31 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
Olas Offline
Loc: Manchester, England
Got a lathe? Buy delrin and trim to fit.
Cable ties should hold it
#4504026 - 09/01/17 05:37 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
dlundblad Offline
Loc: Indiana
The ones on my Jeep blew after 6 months.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4504032 - 09/01/17 05:55 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: Olas]
Trav Offline
I was thinking about that but would it have any sealing ability at all? I would think its too hard.
#4504059 - 09/01/17 06:37 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
Olas Offline
Depending on how close a fit you make it, it might seal or it might not.
I guess the worst case scenario is buying a universal boot/gaiter and trimming/gluing it to fit.
#4504103 - 09/01/17 07:41 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
BigD1 Offline
Loc: NC
Found a video on how to measure tie rods/ball joints to use the universal Energy Suspension boots.
https://www.youtube.com/watch?v=XxDWFntAdeA
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4507855 - 09/05/17 08:15 AM Re: 1997 F-350 New Moog Tie Rod Issue [Re: JimmyJohns]
WyrTwister Offline
Loc: Texas
I needed the rubber boot / cover for a Buick tie rod end , found one at NAPA . Might check with them ?
Best of luck , :-)
Edited by WyrTwister (09/05/17 08:15 AM)
Wyr
God bless
