Borescope who has one and what is a good one
by Rat407. 12/19/18 09:13 AM
Lubsoil Universal Synthetic Trans Fluid
by GMBoy. 12/19/18 09:00 AM
1994 Civic LX, 1.5L hard to start
by Gito. 12/19/18 08:01 AM
Observation of Mechanics and their tools...
by ToadU. 12/19/18 07:56 AM
Toshiba Laptop HDD Replacement
by Ifixyawata. 12/19/18 07:49 AM
Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
Canadian Uber
by StevieC. 12/18/18 08:13 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
94 registered members (beanoil, 66Monza, aquariuscsm, Alfred_B, Bailes1992, barkingspider, 8 invisible), 1,800 guests, and 42 spiders.
Topics295,259
Posts4,931,070
Members66,721
Most Online2,553
Oct 27th, 2018
2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours #4503868
08/31/17 08:10 PM
08/31/17 08:10 PM
USA
AITG Offline OP
AITG  Offline OP
USA
This is the first change on this gen set. The oil is actually the factory fill. It's an air cooled single cylinder engine and is not equipped with an oil filter.
Code:
Hours    Hrs.
on unit  on oil
24.9       24.9
Fe           27
Cr            1
Ni            0
Al            9
Cu            3
Pb            0
Sn            0
Cd            0
Ag            0
V             0
Si            9
Na           18
K             0
Ti           27
Mo           41
Sb            0
Mn            0
Li            1
B             6
Mg          861
Ca         1228
Ba            4
P          1019
Zn         1170
Fuel dil    2.2
Soot        <.1
Water       <.1
Vis 100 C  12.5
I added about a pint of Kendall as make-up oil. That accounts for the Titanium.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: AITG] #4503904
08/31/17 09:06 PM
08/31/17 09:06 PM
Planet Earth
2015_PSD Offline
2015_PSD  Offline
Planet Earth
Kendall Super-Dxa is a great oil. I ran it in my PSD with good results and would do it again anytime. Thanks for the UOA.
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: AITG] #4503911
08/31/17 09:22 PM
08/31/17 09:22 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
is it normal to use 16oz in 25 hours on a new engine?
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: AITG] #4503949
08/31/17 11:02 PM
08/31/17 11:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
That's a lot of fuel dilution. I have never liked how "lazy" the automatic choke is on Onans.
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: Rand] #4504088
09/01/17 06:18 AM
09/01/17 06:18 AM
USA
AITG Offline OP
AITG  Offline OP
USA
It used about 8 ounces. I have no idea of what's considered normal use but Onan does tell you that switching to 30 wt. will give you minimal consumption. I have a couple of gallons of 15W-40 left over from my Duramax so I will continue to use it.
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: AITG] #4504171
09/01/17 07:50 AM
09/01/17 07:50 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Thanks for posting. Wear metals look good despite the fuel thinning it a bit.
I have the same gen set in my motorhome with roughly the same amount of hours on it.
Are you planning to stick with the 25 hour intervals or just did a shorter run because new? I know onan recommends 50 hour intervals.
Re: 2017 Onan QG4000-Kendall SuperD XA 15W-40-24 hours [Re: AITG] #4505555
09/02/17 02:26 PM
09/02/17 02:26 PM
USA
AITG Offline OP
AITG  Offline OP
USA
I'll probably run it no longer than 50-75 hours this time and see what I've got. It's a difficult call because it doesn't get much use. OTOH, arbitrarily changing it once a year seems like a waste. The annual oil change issue has been re-hashed ad nauseum here at BITOG. The most logical answer for justifying it is the life of the oil filter can in salt environments. No filter=no problem.
If I see moisture in the UOA or I get bored I'll shorten the drain interval. At a quart and a half I have enough oil on hand for the next 10 changes.
