It's AMSOILŪ, not Amsoil
by Rat407
32 minutes 58 seconds ago
VW Passat 2007
by madRiver
54 minutes 16 seconds ago
Review: CVJ Remanufactured CV Axles
by The Critic
Today at 03:40 AM
Towing without 85w140?
by OilFilters
Today at 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
Yesterday at 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
Yesterday at 11:13 PM
Darn dogs
by AZjeff
Yesterday at 10:21 PM
New GC?
by Bullwinkle007
Yesterday at 10:04 PM
The guy with the plexiglass head on you tube
by andyd
Yesterday at 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
Yesterday at 09:10 PM
SAE 90 v 85/140
by Knuckle078
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
Yesterday at 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
Yesterday at 07:41 PM
Decent MP3 player
by Ed_T
Yesterday at 07:08 PM
Letgo
by Donald
Yesterday at 06:52 PM
Tire buying advice
by supton
Yesterday at 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
Yesterday at 06:21 PM
No older cars in New York State?
by Oldtom
Yesterday at 06:19 PM
2009 Taurus strut mount noise
by terry274
Yesterday at 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
Yesterday at 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
70 registered (2009Edge, 63Marauder, 2015_PSD, aquariuscsm, 10 invisible), 1165 Guests and 35 Spiders online.
65319 Members
67 Forums
285956 Topics
Page 1 of 2 1 2 >
#4503840 - 08/31/17 08:31 PM Plastic/Nylon Oil Drain Plug Gasket??
Kevinmcc2 Offline
Loc: Pennsylvania
So I recently just noticed my drain plug gasket is finally leaking. Its the OE from 03 so its to be expected.
So I went to Advance and got a replacement but instead of a metal one like OEM, they gave me a nylon/plastic version? Are these pretty reliable?
https://shop.advanceautoparts.com/p/felp...ain+plug+gasket
#4503871 - 08/31/17 09:12 PM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
Dave9 Offline
Loc: Cincinnati, USA
Huh? Oil plug gaskets typically last for the life of the vehicle, failure is not expected. You didn't put some kind of oil flush chemical in that ate up the original gasket did you?
Regardless, yes it should be fairly reliable, but don't over-torque and crush it.
#4503891 - 08/31/17 09:28 PM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Dave9]
Kevinmcc2 Offline
Loc: Pennsylvania
The gasket on the plug atm is pretty much non existent after 13 years and many many oil changes.
#4503922 - 08/31/17 10:45 PM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
Dave9 Offline
^ No. I have never had to change one and most of my repairs were on 10+ year old vehicles. Wherever you're getting this misinformation, you should avoid that source.
It is not, at, all, expected. Just no... unless as I already wrote, someone dumped some chemical cleaner in that ate it up.
Edited by Dave9 (08/31/17 10:46 PM)
#4503947 - 08/31/17 11:59 PM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
Kevinmcc2 Offline
Loc: Pennsylvania
Not saying I doubt you but, ive owned the car the whole time never had anything else but oil in it. The drain plug has been leaking for a while now and it is torqued to the correct spec. Not sure what else to say.
#4503948 - 09/01/17 12:00 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
rooflessVW Online   content
Loc: North Carolina
Oil drain plug gaskets should be changed every time.
Copper, aluminum, plastic, nylon - buy a bag of them for your and you don't have to worry about it.
"Zed's dead baby, Zed's dead."
#4503954 - 09/01/17 12:11 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: rooflessVW]
Rolla07 Offline
Loc: MTL, CANADA
+1
Never heard of someone re-using it for life of vehicle. They arent expensive.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4503974 - 09/01/17 01:39 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Rolla07]
Kevinmcc2 Offline
Loc: Pennsylvania
I understand they arent expensive, but my concern is should I get a metal gasket for next change or will nylon be fine?
#4503985 - 09/01/17 02:27 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
Loc: North Carolina
You're fine for this change.
You should get a new washer for the next change. And the next change. Metal or nylon, doesn't matter if you change it every time.
#4504008 - 09/01/17 04:55 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
bugeye Offline
Loc: Pennsylvania
Back in the 1070's, I used a plastic/nylon/poly for many oil changes. Don't know the material, but lasted for many oil changes over the years I owned the car. AMC Javelin.
#4504013 - 09/01/17 05:09 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Rolla07]
L_Sludger Offline
Loc: Ohio
+1
the cost isnt a factor usually-its just having one around when the oil change happens that sucks! Most people don't plan as far as the gasket when they pick up their favorite oil and ecore at Walmart
too many cars and oil combinations to list in 150 characters or less
#4504015 - 09/01/17 05:13 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Dave9]
Delta Online   happy
Loc: South Central PA
Not exactly. We've had several vehicles that used a drain plug with a rubber gasket built in, after a while they loose their thickness and leak. Recently changed the plug on the Liberty because it was seeping, and it wasn't cause it was loose (fact that thing was tight!), the rubber was just shot. It was the first change for us anyway and that's a mandatory item for me. Also had a vehicle with the nylon, no issues with them as I changed them out every couple oil changes.
Now the GTI on the other hand has a goofy plastic plug and rubber o-ring. I replace those every time contrary to people saying they can be reused.
'17 VW GTI 2.0T - 6MT - 7K
'15 Camry SE - 2.5 - 19K
'99 S10 - 2.2 5MT - 153K
#4504102 - 09/01/17 07:38 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
bigt61 Offline
Loc: Virginia
Drain plug gasket is one part where I always go OEM. Cheap and certain to work. Changing the gasket every time is a waste. Change it when they start to leak - the leaks always start small so you're not going to lose much by waiting until the next OCI.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4504126 - 09/01/17 08:08 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
zrxkawboy Offline
Loc: SD
I can't remember the last time I have replaced a drain plug washer, though I can see it being necessary if a previous owner over-tightened the plug. I don't understand these people who replace it every time they change the oil! My FSM actually says to inspect it and replace if damaged.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#4504177 - 09/01/17 08:55 AM Re: Plastic/Nylon Oil Drain Plug Gasket?? [Re: Kevinmcc2]
bubbatime Offline
Loc: South Florida
Toyota and Honda use a one time use only crush washer. I like doing things the correct way, so I always have a stock of these in my garage. Continuing to reuse a one time use only crush washer is pretty retarded. The oil pans are aluminum, and they are designed to crush at the correct torque level. If you reuse a crush washer, you have to tighten them more and more each time, which could strip out your threads, as you have to tighten them more than they are designed typically to prevent leaks.
My GM has a rubber gasket built into the drain plug that can be reused over and over again until the rubber breaks down.
I have also found that the Toyota crush washers work perfect on my motorcycles, so I use them for that application as well.
What car is the OP talking about?
To the OP, I wouldnt use those junk universal gaskets from AA. I would buy an OEM drain plug, and OEM gaskets, for the next oil change.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Page 1 of 2 1 2 >
