48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
112 registered members (69GTX, amblerman, 28oz, ammolab, aba4430, 64bawagon, 14 invisible), 1,876 guests, and 37 spiders.
Topics295,213
Posts4,930,132
Members66,716
Most Online2,553
Oct 27th, 2018
Would you ever put an oil filter back after you #4503756
08/31/17 06:31 PM
08/31/17 06:31 PM
Albany, NY
ford46guy Offline OP
Albany, NY
took it off?
I took off the FL1A from the explorer to do the trans lines (they run behind it). The filter is perfectly vertical.
There was some crud on the outer edge that I took out but nothing in the oil. I put a bag over it.
The oil is close to its OCI (getting to 5K miles) and I'm thinking of putting it back. I don't like to drain cold oil.
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503768
08/31/17 06:39 PM
08/31/17 06:39 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
I just did it last week. Changed my oil but didn't want to change the filter (Fram Ultra) I change every other oil change. I took it off and dumped the old oil. Wouldn't do it again, too much of a mess. Why over think it? It's got threads and a gasket, put it back on.
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503769
08/31/17 06:39 PM
08/31/17 06:39 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
Not a problem, as long as there's no dirt in it and it wasn't due to be replaced for some other reason.
2011 Toyota Prius now at 95K
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503775
08/31/17 06:42 PM
08/31/17 06:42 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
It wont hurt a thing to put it back on if the gasket isn't deformed, which is most likely the case.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503788
08/31/17 06:51 PM
08/31/17 06:51 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Nope. If I go through the trouble of taking it off, a new one is going on. Not worth the possibility of a gasket leak (even though it may be small).
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503807
08/31/17 07:04 PM
08/31/17 07:04 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
I have done this as well. I would not do it again either. Might as well just replace the doggone thing at that point. I just leave the filter on and let it be if I use it more than once.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: Would you ever put an oil filter back after you [Re: jeepman3071] #4503811
08/31/17 07:07 PM
08/31/17 07:07 PM
USA
slacktide_bitog Offline
USA
approved
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503858
08/31/17 08:00 PM
08/31/17 08:00 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
Replacing things that aren't worn out is silly, unless you're in some special situation where you feel this is your Last Chance before some Big Event.
There is no going to trouble to take one off on an Explorer. It's putting on a rubber glove for grip and 20 seconds to do. You spend more time reading my post and writing one than that. Maybe you'll need to grab a filter wrench if you made the mistake of letting someone else change the oil and over-torque the filter last time.
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503866
08/31/17 08:09 PM
08/31/17 08:09 PM
Texas,USA
ATex7239 Offline
ATex7239  Offline
Texas,USA
I'd more worried about the old gasket than the cold drain...
All I do is cold drains, because handling hot oil isn't high up on my "like to do" list.
Haven't lost an engine yet.
'12 Buick Enclave 150,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 54,xxx
Oil � Don't know
Filter � Don't care
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503935
08/31/17 10:31 PM
08/31/17 10:31 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
I would have no problem either putting the filter back on or draining the oil cold.
1997 Maxima 190k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 193k, VWB 5w20 + SSS 10w40, MGL4967
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503945
08/31/17 10:56 PM
08/31/17 10:56 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have never had an oil filter leak after putting it back on. Ever.
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503953
08/31/17 11:09 PM
08/31/17 11:09 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
To save what, a few bucks? Id go new but thats me. Im sure ur fine to put it back tho.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4503964
08/31/17 11:47 PM
08/31/17 11:47 PM
Regina, Saskatchewan
sir1900 Offline
sir1900  Offline
I've put a premium oil filter back on before. Haven't had any issues. Dumping a 15k oil filter at 5k is just crazy.
2015 Infiniti Q50
VAS 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + FRAM XG6607
Re: Would you ever put an oil filter back after you [Re: ford46guy] #4504011
09/01/17 04:01 AM
09/01/17 04:01 AM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
I have a beautiful Bosch Distance Plus filter I ran for less than one tank of gas and one week of miles through, that I took off and stored when my Avalon started knocking. Knock turned out to be merely the timing belt slapping the timing cover when the tensioner failed. It was going to be used as a cut open specimen but will now be used for a quick 20 minutes deSludge cycle at the end of my current oil run... maybe?
too many cars and oil combinations to list in 150 characters or less
Re: Would you ever put an oil filter back after you [Re: L_Sludger] #4504074
09/01/17 05:57 AM
09/01/17 05:57 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I'm in the "Terrified of Creating an Oil Leak by Reusing a Crushed, Heat Deformed Rubber Gasket" camp.
If the filter was fitted with some sort of premium O-ring, perhaps.
