Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
68 registered members (AZjeff, andyd, AdditiveOCD, atikovi, A_A_G, AdmdeVilleneuve, 8 invisible), 1,466 guests, and 39 spiders.
Topics295,007
Posts4,925,827
Members66,664
Most Online2,553
Oct 27th, 2018
Protecting steel tubing #4503216
08/31/17 09:57 AM
08/31/17 09:57 AM
Albany, NY
ford46guy Offline OP
Albany, NY
The transmission lines on the explorer were weeping (and the ps too, replaced those).
I got a nice set of cooler lines from Dorman, all prebent and the price was very decent. Ford actually sells them too, a bit more, they interchange to the 11 Rangers. A local shop said they keep a few sets in stock.
My ex don't have a cooler, and I reach over 200 sometimes on hills. and these lines allow you to install one. So for under 100 I got a Hayden 679 and all the lines. An OEM ranger/Explorer cooler is pretty large, probably equal to the largest Hayden I got.
Anyway they are bare steel lines, and I'm thinking of 3/4 1:3 ratio shrink wrap to protect them. The shrink wrap also has an adhesive to further protect.
The areas they pass thru are hot, and fluid film will probably burn off. Hot can only make it shrink more I guess...
Then again they will probably outlast the truck no matter what I do :lol:
95 Tbird V8 240K PP SYNTH ULTRA 5W30
98 MGM 160K M1 HM 5W20
96 Explorer EB V6 159K PP SYNTH HM 5W30
95 Conti 155K MC 5W20
11 GS350 90K PP HM 5W30
Re: Protecting steel tubing [Re: ford46guy] #4503224
08/31/17 10:06 AM
08/31/17 10:06 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I just used rubber hose when I replaced mine. The high temp split loom would work if you want the steel lines.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Protecting steel tubing [Re: ford46guy] #4503239
08/31/17 10:16 AM
08/31/17 10:16 AM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
The problem with rubber hose or split loom around steel tubing is that they trap moisture and salt and actually promote corrosion, you will be better off not using them.
The heat shrink will work what they cover but there will be a gap where they end near the fittings and the exposed steel tubing will rust there.
I use NiCopp wherever possible and keep steel lines wet with rustproofing oil.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Protecting steel tubing [Re: George7941] #4503253
08/31/17 10:26 AM
08/31/17 10:26 AM
Albany, NY
Albany, NY
True, I had coated lines fail around the fitting. I'm thinking rtv could be a solution. That + shrinkwrap.
Re: Protecting steel tubing [Re: ford46guy] #4503256
08/31/17 10:28 AM
08/31/17 10:28 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
You guys in the rust / salt belt certainly have my best wishes & sympathy .
I would never even think about something like that .
Wyr
God bless
Re: Protecting steel tubing [Re: ford46guy] #4503279
08/31/17 10:48 AM
08/31/17 10:48 AM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
BTW, it is shrink tubing, not shrink wrap. Shrink wrap comes in film form and you wrap it around an object.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Protecting steel tubing [Re: George7941] #4503295
08/31/17 10:59 AM
08/31/17 10:59 AM
Albany, NY
Albany, NY
Good point, I am considering the polyolefin stuff for wires.
Says good till 275.
Re: Protecting steel tubing [Re: ford46guy] #4503373
08/31/17 12:10 PM
08/31/17 12:10 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I have just used rubber tranny line or even fuel line.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Protecting steel tubing [Re: ford46guy] #4503697
08/31/17 05:42 PM
08/31/17 05:42 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
This. Unless it's a built up show truck you can only put so much into one before some texting teenager comes along and plows into it. Some insurance companies allow to insure vehicle above their bluebook value (at extra cost of course) but I doubt you're carrying comp insurance on it as is since the book is probably under $1500 by now.
Re: Protecting steel tubing [Re: Dave9] #4503735
08/31/17 06:17 PM
08/31/17 06:17 PM
Albany, NY
Albany, NY
I do carry comp insurance, it cost less than an AAA membership and they include towing. I have a $100 deductible too. I guess they know what it is worth. Collision isn't much more, for all I did to the truck it is worth it. Both of them are under 50 bucks a year.
Getting that crazy shaped tube in wasn't pretty and I think whatever coating would scrape off. Flare fittings on trans lines are also a horrible idea. Getting them off in that tight area was nearly impossible. One came off with a 5/8" flare from the bottom, another I was fortunate to be able to hammer on a 15mm crowfoot thru the wheel well. I soaked it for a week in every penetrant too, and it took a bit of force. The tube split as soon as the nut moved, probably ready to dump the fluid any minute.
Almost 5 hours to do the job. I got labor quotes of 5-600 bucks, some places said they may have to drop the tranny. I was considering rubber splices and a ferrule but the flare end was weeping.
Ford changed to quick connects on later models, I'm sure there are corrosion issues but it can't be as bad as a flare. Getting it in to line up with the new tube is terrible too. The prebent tube also bends a bit when you install so it has to be rebent slightly. At one point I was tempted to cut and flare it in the center.
Re: Protecting steel tubing [Re: ford46guy] #4503752
08/31/17 06:29 PM
08/31/17 06:29 PM
Chicago, IL
tomcat27 Offline
tomcat27  Offline
Chicago, IL
the first set lasted over 20 years, correct? shouldn't that be good enough? stainless steel tubing next time.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: Protecting steel tubing [Re: ford46guy] #4503854
08/31/17 07:57 PM
08/31/17 07:57 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
BUT, their valuation of it only considers a median vehicle, not the better state of one for an owner that takes the amount of time you do to consider repairs to this extent. I'm in the same boat, also own a 2nd gen Explorer and cannot buy an equivalent vehicle with what my insurance company valuation is on it, and that disparity grows larger every year because I don't put many miles on that vehicle these days, yet not depending on it as anyone's daily driver, allows for more refurbishment and upgrades than if it were.
Re: Protecting steel tubing [Re: ford46guy] #4503860
08/31/17 08:03 PM
08/31/17 08:03 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
Gear oil would coat it. Smelly though
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Protecting steel tubing [Re: ford46guy] #4503861
08/31/17 08:06 PM
08/31/17 08:06 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
You could paint it with POR-15. or maybe Plasti Dip ?
Re: Protecting steel tubing [Re: SilverFusion2010] #4504164
09/01/17 07:45 AM
09/01/17 07:45 AM
Albany, NY
Albany, NY
My front axle vent sat on the old lines, and these axles throw out some gear oil by design (I think there is some baffle they could install). About 2 feet of the lines looked brand new! I'm going to brush some on. Gear oil isn't going anywhere, especially when it gets a layer of crud.
Painting isn't an option really because the paint would have been scratched on install, and now they are all greasy anyway, in very hard to reach areas.
