2019 Subaru Crosstrek FB20D - Oil choices
by cluster5. 03/26/19 09:31 PM
.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
94 registered members (4WD, 555, advocate, 2010Civic, 2002 Maxima SE, 928, 9 invisible), 1,890 guests, and 93 spiders.
Topics286,475
Posts4,909,129
Members67,635
Most Online2,967
Mar 10th, 2019
m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 #4503204
08/31/17 10:43 AM
08/31/17 10:43 AM
stl
pb Offline OP
pb  Offline OP
stl
con't from http://tinyurl.com/y8hmwkcw
2016 escape 2.0L ecoboost, 4th o/c, 75% highway, TG3614
8.8% fuel dilution, severity 4.
Code:
OIL             M1EP 5W30	M1 5W30
MILES IN USE    7370		7257
O&F CHANGED     Y		Y
MILES           24.2K		16.8K
MAKEUP OIL	0		0
EOLR		26%		27%
SAMPLE TAKEN    19-AUG-2017	1-MAR-2017
LAB             OAI		OAI
IRON		21		20
CHROMIUM        0		1
NICKEL		0		1
ALUMINIUM	8		7
COPPER          3		6
LEAD            0      		0
TIN             0       	0
CADMIUM		0		0
SILVER		0		0
VANADIUM	0		0
SILICON		16		18
SODIUM		1		3
POTASSIUM	16		23
TITANIUM	0		0
MOLYBDENUM      81		84
ANTIMONY        0		1
MANGANESE	0		0
LITHIUM		0		0
BORON		41		38
MAGNESIUM	719		667
CALCIUM		1017		1021
BARIUM		0		0
PHOSPHORUS	657		637
ZINC		794		759
WATER           0		0
cSt @ 212F     8.4		8.6
FUEL            8.8%		>5%
TAN		3.01		2.73
TBN             3.95		3.92
OXIDATION       13		14
NITRATION       13		15
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: pb] #4503214
08/31/17 10:55 AM
08/31/17 10:55 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
Rings aren't seating very fast. How long did you run the factory fill? What were the other two oil changes - oil type & miles? Even with all the fuel, the wear #'s are fine. I'd try some SuperTech dino for 5000 miles and then revisit.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: pb] #4503533
08/31/17 03:56 PM
08/31/17 03:56 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Wow. Don't know what to say.
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: bigt61] #4503574
08/31/17 04:57 PM
08/31/17 04:57 PM
NC
Vladiator Offline
Vladiator  Offline
NC
SuperTech dino in a direct injected turbo engine for 5000 miles??? Gosh at least a blend! Or 3000 miles at most! Mobil Super HM blend or Havoline HM blend will do 5k though. And do it cheaply. But I'd stay with synthetic only.
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: Vladiator] #4503610
08/31/17 05:29 PM
08/31/17 05:29 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Ford doesn't require anything special oil wise for an eco boost.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: CT8] #4503617
08/31/17 05:34 PM
08/31/17 05:34 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Only needs to last 60k for them ...
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: pb] #4503695
08/31/17 06:42 PM
08/31/17 06:42 PM
Danh Offline
Danh  Offline
Gosh, that's a lot of fuel dilution. On the other hand, look at the test/retest results Parisha reported on his 1.5T Civic: makes one wonder whether these results have value at all.
When did OAI start quantifying fuel dilution above 5%? That used to be the maximum.
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: Danh] #4503918
08/31/17 10:39 PM
08/31/17 10:39 PM
stl
pb Offline OP
pb  Offline OP
stl
the first report i received listed the component as a diesel. they've since amended and now the value is ">5%"
Re: m1ep 5w30 7.4k miles '16 escape 2L GTDI severity 4 [Re: pb] #4504158
09/01/17 08:35 AM
09/01/17 08:35 AM
Danh Offline
Danh  Offline
OP, did you notice an increase in crankcase level? Even 5% dilution would add 1/4 or 1/3 of a quart of volume to the sump. Wear metals look OK so maybe even this level of dilution is harmless though worrying.
