Which Lubegard?
HUdson Valley, NY
Hello folks,
I have been changing transmission fluid for my 2006 Sentra. I have already changed it using Nissan Matic Type D ATF. I am going to change 3rd and last time in a week. Haven't gotten around going to the dealership to get the ATF. I was advised in the past to use red Lubegard.
Since my transmission (RE4F03B) is not listed in the pdf file on Lubegard's website, I wrote them to make sure. They replied saying I could use either, the red one or gray bottle Platinum variant. I don't know how these two differ. Hence I am back with the question, Which one do I use,
Lubegard Automatic Transmission Fluid Protectant #60902 or
Lubegard Platinum Universal #63010
Its not that I don't trust previous recommendations. Their reply just made me think more, hence the questions.
Thanks for your suggestions.
I would ask why you are using either one. Is there a problem you're trying to cure? Or is there something wrong with the Matic Type D?
I'm very happy with LG Red in my Matic-D application. It softened up the harsh 1-2 shift Nissan/Infiniti A/T's are known for.
Use LG Red when using the correct ATF (to enhance the ATFs ability to take heat).
Use LG Platinum to convert an ATF to your application.
I personally will only use LG Red with a correct (or 'suitable for') ATF.....I'm not a believer in converting lesser fluids....
+1 Same here.
This is exactly the reason I am asking.
1-2 shift of my sentra was HARD as if the whole car was shaking. Since I am changing ATF its gone. This 3rd change got a bit delayed and yesterday I felt that shift again. Can't explain how annoyed I was.
I will go with LG Red.
Thanks, folks.
How many miles on the tranny and how often have you changed the fluid in the past?
I would only use LubeGard Red if I suspected valve and or actuator varnishing. I would never use any of the other LubeGard ATF supplement products under any circumstances.
Your transmission may need an overhaul with some new internal components.
I never use Nissan lubricant products for various reasons.
Try a refill with Redline D4 or Amsoil ATF.
Apologies for the delay in replying. I didn't notice the comment.
I have ~105,000 miles on this transmission. I have never serviced the transmission since I acquired the car in 2010, per-owned. When I changed the ATF for the first time in May, it was still pink/red as the new one. Since the 1->2 shift was hard, which I was royally annoyed of, I decided to change ATF irrespective of its color.
On various Nissan boards, the users claim that Nissan transmissions are very particular about which ATF to use. I was strongly discouraged from using any of the all-in-one type ATFs and suggested to use Matic type D recommended for the vehicle. That is the primary reason I went with Matic-D at $10/qt. I will give a try to red LubeGard and see how it goes. Will update if this shift comes back.
The people on those boards are highly misinformed.
The NissanMatic D is simply a DexronIII/Mercon knockoff, which is why I suggested Redline D4 or Amsoil ATF.
Thanks, folks.
You should be pleased with the result MoneyJohn.
Thanks, folks.
Yes.
