AutoSense drying not drying
by Ifixyawata. 09/24/18 08:23 AM
Time for a new Generator... Wisdom desired!
by webfors. 09/24/18 06:36 AM
flat roof weight bearing support
by henni. 09/24/18 06:29 AM
ADD A MARBLE - Make Life Easier
by MasterSolenoid. 09/24/18 06:17 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
69 registered members (bmwpowere36m3, 2010Civic, Astro14, Bear, Brian123, ArrestMeRedZ, 11 invisible), 1,446 guests, and 38 spiders.
Topics290,929
Posts4,852,641
Members66,055
Most Online3,590
Jan 24th, 2017
Bluetooth OBD II scan tool on Amazon for $8.49 #4502583
08/30/17 05:54 PM
08/30/17 05:54 PM
The Midwest
skyactiv Offline OP
skyactiv  Offline OP
The Midwest
They are going quick. The deal ends at 8:30 PM Eastern time or until they are sold out, whichever comes first.
https://www.amazon.com/KOBRA-Scanner-Blu...3NDVA6NB2KPBBFE
Me: 13' VW GTI 3 door 6 speed manual
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4502590
08/30/17 06:07 PM
08/30/17 06:07 PM
ME
eljefino Offline
eljefino  Offline
ME
And if you miss this sale you'll have to go on ebay and pay $3.58 or so.
random link-- you could do better
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4502737
08/30/17 08:22 PM
08/30/17 08:22 PM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
These things are pretty neat I been looking at them like to get one to check codes quick when buying a used car instead of dragging my big corded scanner along with me.
Any idea eBay has many different ones are some better then others? or covers more parameters, etc? witch one should a guy get or doesn't it matter?
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4502803
08/30/17 09:25 PM
08/30/17 09:25 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
That's not all that unusual a price for a generic. The problem is that despite many if not all claiming they can do ALL OBDII vehicles from '96 and newer, that is not true.
Many cannot do J1850 VPW or PWM protocol which is on most older Fords, GMs, and maybe others. Most if not all (that aren't defective) can do canbus which most switched to around the mid-2000's. It was regulated to model year 2001 for Europe and 2008 for US but manufacturers may have switched earlier.
If you know you have canbus and it's all you'd ever need, I'd get one of the tiny blue translucent types on Amazon or eBay. If you know you want to be able to read ALL OBDII '96 and newer, get a BAFX. The plastic casing may look the same but there's different circuit boards in them. $22.
https://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4503687
08/31/17 06:36 PM
08/31/17 06:36 PM
Bad Axe, MI
daman Offline
daman  Offline
Bad Axe, MI
Thanks for the tip and link Dave yea I knew there was a catch to them cheap ones. I need one that covers everything.
"Always"....Mobil 1
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4503836
08/31/17 08:28 PM
08/31/17 08:28 PM
ME
eljefino Offline
eljefino  Offline
ME
https://www.elmelectronics.com/products/ics/obd/
This chart says the ELM-327 can do just about everything. Unless there are counterfeits?
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: eljefino] #4504259
09/01/17 10:10 AM
09/01/17 10:10 AM
TX
mooferz Offline
mooferz  Offline
TX
There are lots of counterfeits out there.
I use a vGate scan tool I found in a wrecked IS300 at the junkyard. It has an "ELM327" that reports V1.5 of the firmware (which isn't a valid version number) and when checked with the ELM327 Identifier App, doesn't support the more advanced features.
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
Re: Bluetooth OBD II scan tool on Amazon for $8.49 [Re: skyactiv] #4504297
09/01/17 10:55 AM
09/01/17 10:55 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
I've read anything over ver. 1.1 is a clone . Had a lot of cheap ones. many didn't work with Torque and they didn't even want them back, just refunded the money.
Finally got a good one, ScanTool 427201 OBDLink LX. It much, much faster and you can leave it connected too as it has a sleep mode.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
