PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
122 registered members (2015_PSD, 01rangerxl, 2009Edge, 14 invisible), 2,018 guests, and 61 spiders.
Topics286,160
Posts4,903,335
Members67,569
Most Online2,967
Mar 10th, 2019
Phase Separated Gasoline #4502550
08/30/17 05:17 PM
08/30/17 05:17 PM
US
bunnspecial Offline OP
US
I've been having issues with my MG running very poorly for about two weeks. After I'd exhausted all the "usual" troubleshooting someone suggested that I check the fuel pump for proper flow. It flowed fine, but the gas that I pumped into a clear glass bottle immediately separated into two layers.
Short of draining the tank, is there anything that I can do to salvage the current tank? Driving the gas off isn't really an option-I've only dared venture onto neighborhood roads as 25mph is about the fastest I can get it to go(in 2nd gear) on a flat road and I've been near stalling when going up a hill.
BTW, my records show that I last filled up on 7/24-it was a top off of a half full tank. It was premium from a top tier station that sells a decent amount of gas.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
Re: Phase Separated Gasoline [Re: bunnspecial] #4502557
08/30/17 05:26 PM
08/30/17 05:26 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
If it's fuel related as your stating, drain the gas and start fresh. If your going to let the car sit around and not drive it much, go to a small airport with a few gas cans and buy some 100LL Av gas. Your pre 1975 ride will like it.
https://www.airnav.com/fuel/local.html
Me: 13' VW GTI 3 door 6 speed manual
Re: Phase Separated Gasoline [Re: bunnspecial] #4502559
08/30/17 05:29 PM
08/30/17 05:29 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Nothing can be done. Dump the gas, and change the filter.
You have to have a lot of water for phase separation. It's uncommon and almost always in boats.
2015 Ford F250 w/Powerstroke
Re: Phase Separated Gasoline [Re: bunnspecial] #4502563
08/30/17 05:31 PM
08/30/17 05:31 PM
Maryland
chemman Offline
chemman  Offline
Maryland
Without knowing the approximate percentages of the two layers, it's hard to say.
If you think one layer could be ethanol that separated out from the gas, and only about 10 - 20 % of the total volume, you might (repeat might) be able to make things somewhat better by adding the isopropanol version of gas line antifreeze, say around 1 - 2 quarts, and try that. I would go up and down a few hills or over a bumpy road in order to mix the contents of your gas tank better by getting it to slosh around.
Might not do anything, but then again, it just might.
92 Olds 88 Hav 5w30 PL/L24011
99 Buick Century Hav 5w30 PL/L24011
99 Silverado 5.3L Hav 5w30 PL/L25288
04 TrailBlazer 4.2L Hav 5w30 PL/L25288
Re: Phase Separated Gasoline [Re: bunnspecial] #4502565
08/30/17 05:33 PM
08/30/17 05:33 PM
US
US
Alright, I will drain it. That's what I was afraid of.
To be honest, I'm not sure how this happened. This is not a daily driver by any means and admittedly I didn't drive it a lot in July(busy with work and high humidity tends to make me want A/C) but in general I put 3K miles or so a year on it and also drive it to work once or twice a week. It was down most of May and June when a head swap turned into a lot more work than I expected, but I did put 200 miles or so on it toward the end of July.
Re: Phase Separated Gasoline [Re: bunnspecial] #4502568
08/30/17 05:34 PM
08/30/17 05:34 PM
US
US
BTW, in case anyone is wondering...
Re: Phase Separated Gasoline [Re: bunnspecial] #4502574
08/30/17 05:40 PM
08/30/17 05:40 PM
Maryland
chemman Offline
chemman  Offline
Maryland
That's not nice looking! Isopropanol won't be helpful there!!!!!
Re: Phase Separated Gasoline [Re: Donald] #4502592
08/30/17 06:09 PM
08/30/17 06:09 PM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
^This
I work on OPE and see this almost daily. Keep gas tank full when stored or if it will be sitting awhile. Temperature changes cause gas tanks to breath in moisture, reason for full tank. Use ethanol-free gas if possible. Use Sta-bil 360 Marine Formula.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Phase Separated Gasoline [Re: bunnspecial] #4502657
08/30/17 07:30 PM
08/30/17 07:30 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
In Canada we used to have a problem with gas lines freezing with the onset of winter. Presumably there was some water in the gas tank. I haven't seen a frozen gas line in more than 30 years so something has changed. Maybe sealed gas tanks? better distributors? something in the gas?
In any case if you had a frozen gas line, a few ounces of methyl alcohol would solve the problem almost immediately. I still carry a small bottle of methyl alcohol when going onto the prairie in winter.
I assume the alcohol would melt the ice and soak up any additional water and the compound would eventually burn off. It never seemed to hurt anything. Of course if there was a lot of water, it might not work at all or it would take a lot of methyl alcohol.
So I'd be tempted to add a bit of methyl alcohol and see if that helps.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Phase Separated Gasoline [Re: bunnspecial] #4502676
08/30/17 07:46 PM
08/30/17 07:46 PM
Minnesota
philipp10 Offline
philipp10  Offline
Minnesota
I would not call that "phase separation". Looks like water in your gas....period.
Re: Phase Separated Gasoline [Re: bunnspecial] #4502686
08/30/17 07:53 PM
08/30/17 07:53 PM
US
US
BTW, as far as using ethanol free goes:
The only local source I have only sells 87 octane. This engine is not stock(it has a 9.5:1 CR) and I find it difficult to tune out pinging without sacrificing performance with 87 octane. I actually should say that I have to pull the timing to the point where I do noticeably lose performance with 87 octane.
I have run 100LL in the past, but having just done a valve job(with hardened seats) I'm not inclined to lead up the engine again.
So, I'll get some gas cans lined up and proceed to drain. Fortunately, I can siphon it out easily enough either at the fuel filler or at the line going to the pump. I COULD let the fuel pump pull it out, but I also don't know what this junk might do to the diaphragm in my pump(this is a new production electronic SU pump, and it was not inexpensive). I have a new filter ready here.
BTW, I'm also considering just biting the bullet and putting a new tank in the car. There are no PRESSING issues with the current one aside from the bad tank of gas in it, but I figure a new tank once every 50 years can't hurt. I can get a new 13.5gal baffled stainless steel tank(the original is-I think-10 imperial gallons and is not baffled) for $150.
Re: Phase Separated Gasoline [Re: bunnspecial] #4502722
08/30/17 08:10 PM
08/30/17 08:10 PM
Virginia
mattwithcats Offline
Virginia
Drain the tank, put fresh in...
I would run Sunoco Optima race gas, 95 octane, expensive, but great for low miles...
http://www.sunocoracefuels.com/fuel/optima
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Phase Separated Gasoline [Re: bunnspecial] #4502761
08/30/17 08:41 PM
08/30/17 08:41 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
In boats we use a Fuel water separator inline with the fuel line. You might be able to cycle all your gas through one of these and recover some gas. BUT your octain rating would be way down. you might need an octane booster to get it up.
here's how this guy did it.
https://www.youtube.com/watch?v=_fND1JV4s6Q
Re: Phase Separated Gasoline [Re: bunnspecial] #4502781
08/30/17 09:03 PM
08/30/17 09:03 PM
Maryland USA
rubberchicken Offline
Maryland USA
So if I have a bunch of gas that suffered phase separation, could I reuse the lighter top portion of the fuel in something like a lawn mower, or something that is tolerant of poor quality gas ?
Re: Phase Separated Gasoline [Re: bunnspecial] #4502833
08/30/17 10:06 PM
08/30/17 10:06 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
I would flare it off somehow. Start a campfire with it maybe
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
