It shouldn't be a problem, and likely won't but it could be. If you're trying to optimise for cold starts, it's best to let the formulators handle the issue.
In your current mix, do note that you're also not right now anywhere approaching the limits of MRV. With ambients right now, you're not even coming close to stressing a monograde's starting limits. A thinner lube will crank easier, sure, and adding a 20 to a 30 thins it out. What happens at MRV limits is a little less predictable.
If one is looking for something with shear stability and still being suitable for the winter, there are all kinds of A3/B4, A5/B5, and HDEO options in viscosities including 0w-30, 5w-30, 0w-40, and 5w-40, none of which will compromise cold weather performance.
As I've said many times, if someone sees a problem with an ILSAC 5w-30 conventional (and I'm not convinced there is a problem in most cases), then an ILSAC 10w-30 isn't the solution. Right near the 10w-30 on the Canadian Tire shelf (Saskatchewan Canadian Tires actually have very few 10w-30 synthetics; they've been cleared out and haven't been replaced) are things like M1 0w-40, GC 0w-30 and 0w-40, and Pennzoil Platinum 5w-40 A3/B4.
