2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
106 registered members (240_Ed, 1foxracing, Bailes1992, bandito, Astro14, 11 invisible), 1,701 guests, and 38 spiders.
Topics295,211
Posts4,930,031
Members66,711
Most Online2,553
Oct 27th, 2018
Patio cover structural advice please. #4502375
08/30/17 01:47 PM
08/30/17 01:47 PM
Utah, USA
28oz Offline OP
28oz  Offline OP
Utah, USA
Just looking for some advice on a patio cover idea I'm tossing around and would appreciate comments by those in the know.
The amount of my patio to be covered is 16'x21'. This will be an attached (via ledger board) patio cover and extend away from the house to cover the 16' width. My plan is for 2x8x16s for the rafters on 16" centers. They will span 14' or 15' with a 1' or 2' overhang. Roofing will be thin enamel coated metal roofing panels - not OSB and shingles.
The snow load requirement is 30psf. I've talked with the city inspector and he indicated since it is not a habitable structure, the code requirements are sparse and even the snow load may or may not apply to it. He simply said to submit my plans and if they don't "look stupid or dangerous", then I should be good to go. This didn't really answer my concerns as I was looking for actual guidelines to follow with my rafter and spacing choice. It seems every online calculator I find is for habitable buildings.
Do you think 2x8x16s on 16 inch centers is sufficient to be safe/solid and not sag when spanning 15' or 16'? Is this overkill? Underkill?
Thanks!
1990 Nissan 300zx - Castrol Edge Euro 0W-40
2004 Nissan Quest - Pennzoil Platinum Euro 0W-40
2003 Ford Excursion 7.3 PSD - Mobil 1 TDT 5w-40
Re: Patio cover structural advice please. [Re: 28oz] #4502423
08/30/17 02:18 PM
08/30/17 02:18 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
I built nearly the same roof over my patio in NJ, mine being 20'x14' and connected with joist hangers to a 2x10 ledger board bolted into the house studs. The beam was two 2x8s lag bolted into four 4x4 posts spaced 6'8" apart. My joists were 14' lengths of 2x8s which overhung the beam by 1'. Joist spacing was 24", which was approved in the permit application and by the inspector. I used 3/8" plywood with shingles, but if I were to do it over again I would use 5/8" plywood so as to avoid the slight sponginess when walking on the roof.
My patio roof is still solid as a rock after 12 years, and even survived a direct hit from Super Storm Sandy, which blew two tall pine trees onto the roof. If anything it sounds like your plan for 2x8x16s rafters on 16" centers is overkill, but then the added expense and effort for a more solid structure is minimal.
If you have a program that can open a Lotus 123 file I can sent you my plan.
Tom NJ
Re: Patio cover structural advice please. [Re: 28oz] #4502537
08/30/17 03:57 PM
08/30/17 03:57 PM
Utah, USA
28oz Offline OP
28oz  Offline OP
Utah, USA
Thanks for the insight. I think Excel will open a Lotus 123 file, so I'd love to see your plan!
Re: Patio cover structural advice please. [Re: 28oz] #4502566
08/30/17 04:34 PM
08/30/17 04:34 PM
Northern Arizona
funflyer Offline
funflyer  Offline
Northern Arizona
2016 Prius 1.8L
2001 Tacoma 2.4L
1966 GTO 6.5L
2015 Cub Cadet
Honda CT70 (X6)
Re: Patio cover structural advice please. [Re: 28oz] #4503869
08/31/17 08:11 PM
08/31/17 08:11 PM
Virginia
Tom NJ Offline
Tom NJ  Offline
Virginia
No unfortunately Excel does not open a Lotus file. I can save it as an Excel file but it loses some features. Still it may be useful, so if you PM me your email address I'll send it along.
