Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
39 registered members (alcyon, berniedd, avi1777, 928, 555, aleneros, 1 invisible), 593 guests, and 65 spiders.
Topics286,097
Posts4,902,483
Members67,560
Most Online2,967
Mar 10th, 2019
Page 1 of 6 1 2 6
Oil for 2017 Honda Civic Type-R #4502314
08/30/17 01:51 PM
08/30/17 01:51 PM
Queens, NY
iLovePho Offline OP
iLovePho  Offline OP
Queens, NY
Just purchased a CTR a month ago and still got some ways to go until I'll need an oil change (currently at 1500 miles and change) but want to get an idea of what oil to use when the time comes (~6,000 miles, typically when the maintenance minder light comes on). I've always used Mobil 1 Full Synthetic on my previous Hondas, but this being my first turbocharged one (and highest performing), only the best will do grin
1. What kind of vehicle you have: 2017 Honda Civic Type R
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well: API Premium-grade 0W-20 detergent oil; no set change interval but from online research, maintenance minder light will come on at ~6,000 miles to change oil
3. Where you live: Queens, New York
4. How you drive (easy? hard? fast? slow?): Normal to fast daily driving; weekend spirited driving
5. What your daily drive is like (short trips? long trips? city? highway?): ~20 miles a day; Mix of city and highway
6. Whether your car has any known problems: No problems
I prefer to use full synthetic and an interval in line with the maintenance minder (~6,000 miles). Not sure if a huge difference maker, but aside from daily driver duties and spirited weekend drives, I might also do some HPDE track days.
Thanks in advance!
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502322
08/30/17 01:57 PM
08/30/17 01:57 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
I am surprised it calls for 0W20. I would be tempted to use a good full synthetic 0W30, 5W30 or even 0W40 like Pennzoil Ultra or Castrol Edge, especially with a turbo that will be really hard on the oil. I use Castrol Edge 0W40 in my K20 Civic.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502326
08/30/17 02:02 PM
08/30/17 02:02 PM
MN
oil_film_movies Offline
MN
Mobil just came out with a dexos1 Gen2-quality 0w20 in their "Annual Protection" oil at Walmart (cheapest with $10 e-Gift card rebate; other online rebates from Mobil might be available too). That uses the latest set of base oils and additives Mobil can produce right now. Change at normal intervals, and its tough stuff for that, plenty of performance margin.
There is one higher spec (maybe slightly higher spec) than dexos1 Gen2 to look for: BMW and/or Mini: dealership or eBay or Amazon(?) oil, their 0w20, which should perform at a very high level.
Oil filter: Look for a Fram Ultra or Royal Purple oil filter for the highest performance and tough construction possible. The Fram Ultra's are not too expensive at Walmart either.
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502333
08/30/17 02:09 PM
08/30/17 02:09 PM
TX
parshisa Offline
parshisa  Offline
TX
If you are planning to run 0w20 you better be ready to change oil every 2-3K. These turbo engines are hard on oil and proved themselves as an awesome fuel diltuters. With my 1.5T Civic it dilutes oil badly with mostly highway cruising. With track/spirited driving it will be like water by the time MM will tell you it is time to change. With that said, next OC I'll go up to 0w30. I'd suggest you go higher on the weight as well. Unless you don't plan to keep the car long term.
Re: Oil for 2017 Honda Civic Type-R [Re: mightymousetech] #4502335
08/30/17 02:13 PM
08/30/17 02:13 PM
MN
MN
The big fear is fuel dilution in these turbos. It does happen.
Maybe a good idea is to use a 0w20 from Redline (https://www.redlineoil.com/product.aspx?pid=124&pcid=21), which is practically a street oil and a racing oil too. Stands up to extreme HTHS conditions, with HTHS=2.9, qualifies in HTHS as a 30-weight.
Redline has a great reputaion on and off the track. Lots of moly in there too.
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502342
08/30/17 02:18 PM
08/30/17 02:18 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
How about a good 5W20 over the 0W20?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502343
08/30/17 02:19 PM
08/30/17 02:19 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
I'd use the M1 AFE 0W-30. I'd also change that oil right now, and get a UOA to see where your viscosity and fuel dilution are at.
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502351
08/30/17 02:25 PM
08/30/17 02:25 PM
PA,US
HemiHawk Offline
HemiHawk  Offline
PA,US
This is tough. For warranty reason I'd say go with what they say you need. Sounds like 0w20. That said, as others are saying I would think this car needs some 0w30. I'm not normally one to jump on the higher visc wagon, but this car is pushing roughly 153 horsepower per liter. I've seen some reports of the coolant spiking during track use as well. If the coolant temp is getting hot, the oil certainly is. I've kept a pretty close eye on this car as I've thought for awhile about getting one. I loved my Civic Si and regretted selling it.
I'd also be surprised if the built in mileage minder calculates all that different from a standard civic, but its possible. My Si would say 10% remaining at 6k miles like you mentioned.
Post some pics of that beast!
2016 Nissan Frontier Pro4x
2017 VW GTI sport
1995 Mustang GTS
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502356
08/30/17 02:29 PM
08/30/17 02:29 PM
Ontario, Canada
Ontario, Canada
Would be interesting to see what oil is spec'd in other countries like the UK.
Mighty Mouse Tech
Re: Oil for 2017 Honda Civic Type-R [Re: HemiHawk] #4502358
08/30/17 02:30 PM
08/30/17 02:30 PM
TX
parshisa Offline
parshisa  Offline
TX
There are multiple ways you can attain receipts with proper grade and keep them for your records and warranty purposes. Keep 0w20 receipts and use heavier oil. Problem solved.
As far as the track goes I'd imagine you need to change oil after it anyways...
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502359
08/30/17 02:32 PM
08/30/17 02:32 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
In my opinion, I'd rather go with an oil that's not API certified than go out of grade should an issue come up that required warranty coverage. Personally, I'd just run a thicker 0W-20 like Red Line. Just my .02 cents though.
Re: Oil for 2017 Honda Civic Type-R [Re: JustN89] #4502363
08/30/17 02:36 PM
08/30/17 02:36 PM
TX
parshisa Offline
parshisa  Offline
TX
Fuel dilution doesn't care whether the oil is API certified or not. I ran Amsoil SS which is on a heavy side and POA/Ester based and it still diluted badly just in 5K. another 2c
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502368
08/30/17 02:43 PM
08/30/17 02:43 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
I just can't wrap my head around ever needing a 0W anything unless you live in the middle of Antarctica on the East Antarctic Plateau. The 0W is coming out of my Honda next oil change and being replaced with 5W20.
Re: Oil for 2017 Honda Civic Type-R [Re: parshisa] #4502376
08/30/17 02:47 PM
08/30/17 02:47 PM
bigj_16 Offline
bigj_16  Offline
What vehicle?
Re: Oil for 2017 Honda Civic Type-R [Re: iLovePho] #4502386
08/30/17 02:51 PM
08/30/17 02:51 PM
Oregon
1JZ_E46 Offline
1JZ_E46  Offline
Oregon
If you're sticking with 0W-20, I would run only the best: Redline, Amsoil, M1 EP, PUP, Motul 8100. And I would definitely consider running a 5W-30 at the track. I also wouldn't recommend anything past 5k miles with the fuel dilution that is likely to ensue.
If I had to pick an oil to run in that engine, it would be Redline 0W-30.
2007 X5 4.8i: M1 HM 10W-30
2016 Countryman S: Castrol 0W-40
Page 1 of 6 1 2 6
