AAP 25% Off
by Egg_Head
06/22/18 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
06/22/18 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
06/22/18 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
06/22/18 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
06/21/18 10:41 PM
Chevy brought the blazer back
by WiskyBadger
06/21/18 10:07 PM
LC20 and uses in modern motor oil
by synman
06/21/18 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
06/21/18 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
06/21/18 08:37 PM
Fram SureGrip coating
by mobilaltima
06/21/18 08:24 PM
Manual transmissioned electric car
by mjoekingz28
06/21/18 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
06/21/18 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
06/21/18 06:02 PM
Traveller nlgi 2
by Spitter
06/21/18 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
06/21/18 05:08 PM
Any nano reefers here?
by RichardS
06/21/18 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
06/21/18 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
06/21/18 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
06/21/18 04:31 PM
help me choose...
by chaindrive
06/21/18 04:07 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
50 registered (BrewCityR, bullwinkle, ccs368, bmod305, Astro14, Astro_Guy, 6 invisible), 968 Guests and 22 Spiders online.
65294 Members
67 Forums
285754 Topics
Page 1 of 2 1 2 >
#4502111 - 08/30/17 09:06 AM High Mileage Synthetic Oils in Newer Cars?
knerml Offline
Loc: NE Ohio
Is there any reason not to use "High Mileage" type full synthetic oils (like Valvoline or M1) in newer cars?
I would think all engines, regardless of the mileage, would benefit from the improved seal conditioning, viscosity stability and cleaning properties.
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W20 & OEM/Mann W811/80 Filter
2018 Hyundai Santa Fe Sport 2.0T GDI Castrol Edge 5W40 & OEM/Mann W811/80 Filter
#4502134 - 08/30/17 09:31 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
MolaKule Offline
Loc: Iowegia - USA
There is no reason one cannot use HM oils in new engines.
However, the HM oils may not give you the fractional increase in fuel mileage since HM oils may not contain the same level of Friction Modification chemistry found in non-HM oils.
Edited by MolaKule (08/30/17 09:31 AM)
#4502139 - 08/30/17 09:35 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
skyactiv Offline
Loc: The Midwest
Don't believe everything you read, but.....?
Me: 13' VW GTI 3 door 6 speed manual
#4502142 - 08/30/17 09:37 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
tig1 Offline
Loc: Illinois
I wouldn't do it. I still use 0-20AFE in my 10 year old Fusion. Call Mobil tech and get their advise. 1-800-ASK-Mobil.
Edited by tig1 (08/30/17 09:37 AM)
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4502158 - 08/30/17 09:54 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
knerml Offline
Loc: NE Ohio
Thanks
#4502162 - 08/30/17 10:01 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
MolaKule Offline
Loc: Iowegia - USA
Goss is a mechanic, not an oil chemist.
He should use the term, "Seal Conditioning," which does more than just swell seals.
Also realize, HM oils only contain a very small fractional increase in cleaners and seal conditioners, so the oil does not over swell the seals.
Goss did not present any evidence that HM oils damage seals over the long haul.
Edited by MolaKule (08/30/17 10:04 AM)
#4502167 - 08/30/17 10:07 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
bigj_16 Offline
Loc: Douglas County, Colorado
I am not saying that Goss guy is wrong or right. But...does he have any data or testing to back up what he says? When someone makes a broad statement like that(i.e. use an HM oil and you will have to use it all the time) and no data to back it up... Is there even one test? It kind of reminds me of using oil and stretching the engine out.
Edited by bigj_16 (08/30/17 10:08 AM)
#4502174 - 08/30/17 10:17 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: bigj_16]
MolaKule Offline
Loc: Iowegia - USA
It's a Goss, "Hypothesis."
#4502175 - 08/30/17 10:18 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
bigj_16 Offline
M1 HM 10W-30 is a pretty stout oil, for a Run Of The Mill Walmart Jug Oil (ROTMWJO) . Seal conditioning etc., aside, it looks like it would make a good replacement for hard use when a 5 or 10W-30 is spec'ed.
#4502219 - 08/30/17 11:20 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
beanoil Offline
Loc: Midwest, Illinois
An HM oil is fine anytime.
Most blenders will recommend for 75,000 and above, but no time/space continuum has been interrupted or altered by running HM's at 74,999 or less.
Maxlife is one of the few that actually does what it says it will.
beanoil: Tough under heat, real dirty afterwards.
#4502240 - 08/30/17 11:56 AM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
Fasttimez Offline
Loc: East Coast
Most HM oils do have a stouter add pack & are usually higher in VIS for their grade. I'm guessing the reason most don't get the GF-5 certification is because they can't pass the fuel economy part because it's a more robust, less thin oil.
#4502249 - 08/30/17 12:11 PM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
OneEyeJack Offline
Loc: S California
Goss reads scripts supplied by sponsors. There's nothing at all wrong with what he says but his audience is not BITOG members.
He's like the doctor that says the operation we are about to perform on you is routine. He smiles and leaves the room.
Then, behind the scenes, there's a doctor that spent 10-15 years in higher education, internship, residency, state board exams, yearly continuing education credits, hospital certification with peer review of his every move, and a support team along with a specialized hospital facility that actually does the "routine operation".
#4502344 - 08/30/17 02:19 PM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
Insertcoolname Offline
Loc: South Texas
Hi. I can't help but notice Valvoline max life high mileage is gf-5 certified (current) a1/a5 API SN AND resource conserving in 5w-20, 5w-30 and 10w-30. This link I got off their website shows what weights meet what specs. Also meets the current Chrysler 6395
https://sharena21.springcm.com/Public/Do...10-ac162d889bd3
The new Quaker state high mileage is also API SN and GF-5 certified in 5w-20, 5w-30, and 10w-30
http://www.quakerstate.com/en_us/products/motor-oil/quaker-state-defy-high-mileage.html
As I recall QS Defy which recently went off the shelves was SL rated as was the old M1 high mileage. I think oil companies did this to get their products in newer cars which are now high mileage but still meet all new requirements.
One of the above mentioned companies claims you can use their formula to address symptoms of high mileage wear before they begin. Can't find the page anymore. But as they are both SN GF-5 rated I'm sure they are just fine. Just my opinion.
My car asks for API SL. If you have a new car requiring API SN or GF-5 there are a few Hi Mi options that still meet your modern requirements.
04 Camry 2az-fe 2.4L 200k M1 HiMi 10w30
Bosch D+ filter
#4502402 - 08/30/17 03:01 PM Re: High Mileage Synthetic Oils in Newer Cars? [Re: MolaKule]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I didn't even watch the video, considering I saw who it was. He's not that good of a mechanic, even.
Seeing 10w-40 versus 5w-20 on his little shelf didn't impress me, either. I'm also sure he doesn't know that there are ILSAC rated high mileage oils, too. Considering that MaxLife is dexos1 where appropriate, I'm sure GM isn't worried, either.
How much time did he spend shilling the collection of additives on the right side of the screen, or was that just there for the setting? whistle
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4502618 - 08/30/17 06:44 PM Re: High Mileage Synthetic Oils in Newer Cars? [Re: knerml]
tig1 Offline
Loc: Illinois
How do we really know Goss isn't a quality mechanic?
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Page 1 of 2 1 2 >
