White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
23 registered members (Char Baby, BretK, ChrisD46, billt460, c502cid, DaleRider, 4 invisible), 801 guests, and 35 spiders.
Topics296,866
Posts4,960,388
Members66,982
Most Online2,688
Jan 19th, 2019
Iridium Spark plug Gap #4502046
08/30/17 06:58 AM
08/30/17 06:58 AM
IL
DarylZero Offline OP
IL
Hi,
Do Laser Iridium spark plugs usually come pre-gapped correctly?
I got some for my 2009 Nissan Rogue. I got NGK DILKAR6A11 stock #9029.
The largest of my feeler gauge is .70mm and it fits between all of them. Mine are supposed to be .43mm per the field service manual.
I have also read you are not supposed to gap Iridium plugs as it ruins them...
Re: Iridium Spark plug Gap [Re: DarylZero] #4502054
08/30/17 07:08 AM
08/30/17 07:08 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Dont force a gapping tool between the electrodes. Its ok to lightly ck the gap.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Iridium Spark plug Gap [Re: DarylZero] #4502067
08/30/17 07:23 AM
08/30/17 07:23 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
Bend the electrode with a needle nose or the special tool. My Gen Coupe plugs come gapped at .044" or so, the car runs best gapped at .030".
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Iridium Spark plug Gap [Re: DarylZero] #4502072
08/30/17 07:27 AM
08/30/17 07:27 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Per NGK site info pre-gapped to 0.044. Shouldn't need to touch them.
Re: Iridium Spark plug Gap [Re: DarylZero] #4502089
08/30/17 07:46 AM
08/30/17 07:46 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
1mm (milimieter) is .039"
Are you sure you are not mixing inches and mm? .43mm is .017" which is very tight for a spark plug gap.
Re: Iridium Spark plug Gap [Re: DarylZero] #4502091
08/30/17 07:51 AM
08/30/17 07:51 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
That should be 1.1mm not .43mm !!!
See the 11 at the end of the part number.
that's .043 INCHES GAP.
I don't mean to be a Big Richard, but Are you sure you should be doing the plug job without help?
Maybe a bit gruff since I worked as an Engine Mechanic ( U call them master techs) for years and had to fix more than a few of amateur "Tune Downs"
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: Iridium Spark plug Gap [Re: DarylZero] #4502117
08/30/17 08:10 AM
08/30/17 08:10 AM
IL
IL
thanks for all the quick replys.
here is the info from the FSM
So yes I read it wrong tired
Re: Iridium Spark plug Gap [Re: DarylZero] #4502130
08/30/17 08:26 AM
08/30/17 08:26 AM
Canada
i_hate_autofraud Offline
Canada
For years I always gapped plugs .003" tighter then spec, reason being they do burn/wear
to a larger gap later and can misfire near the end of their lives when operated in extreme cold
or humid conditions, etc.
This still applies to Iridium plugs, they just take 80 to 100K miles to get to that point,
wear on the iridium is hard to see without a good magnifier!
But yeah, make sure you don't mix up metric and inch gaps! LOL
Re: Iridium Spark plug Gap [Re: DarylZero] #4502184
08/30/17 09:33 AM
08/30/17 09:33 AM
Virginia
mattwithcats Offline
Virginia
Funny, I just gapped some iridium plugs...
First, feather the edge on the feeler gauge with a little 600 grit wet/dry ssandpaper. I found mine to be curled up.
Note the shiny edge.
To open the gap, insert the tail into the hole (insert joke here), and hook the electrode on the lip.
Push gently on the tool, gap will open without touching the tip.
To close, push electrode gently against a hard surface...
Note that these are 8 heat range plugs, the OEM is 7, I went colder, less insulation, more heat is transferred to the head...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Iridium Spark plug Gap [Re: DarylZero] #4502311
08/30/17 12:47 PM
08/30/17 12:47 PM
NJ
Leo99 Offline
Leo99  Offline
NJ
I've only changed iridiums less than 10 times but I've never checked the gaps. Just inspect them for gross damage and install them. Buy the same ones as what came from the factory.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles (RIP)
2004 Corolla 125,000 miles
2004 Rav4 370,000 miles
2015 Camry 70,000 miles
