New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
What vehicles are you using Maxlife ATF in?
by BlakeB. 09/20/18 11:10 PM
How a Power Steering Rack Works (Electronic)
by StevieC. 09/20/18 11:00 PM
How a Power Steering Rack Works (Hydraulic)
by StevieC. 09/20/18 10:58 PM
silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
30 registered members (BlakeB, Ablebody, Ag76, Bjornviken, 5 invisible), 855 guests, and 37 spiders.
Topics290,744
Posts4,849,441
Members66,033
Most Online3,590
Jan 24th, 2017
Adjusting Rear Drum/Parking Brakes 2002 4Runnner #4501726
08/29/17 08:42 PM
08/29/17 08:42 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Just finished installing my new shoes and drums on my '02 4Runner. I have read to adjust the brakes by turning the star wheel until you get a slight drag on the drums. I have read to go in reverse and pull up over and over on the Emergency Brake lever. I have read to just jerk up and down on Emergency brake while car is still. I have read that you need to adjust the Emergency Brake by removing the center console and tightening a bolt on the wire attached to the Emergency brake.
So, I went out in the street and did the going in reverse and pulling up on the handle about 15 times. My Emergency brake handle never got to the point it ever clicked. Still totally slack. Car stops fine. Pulled it back in my garage and decided to go to school on BITOG.
What am I supposed to do?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4501733
08/29/17 08:48 PM
08/29/17 08:48 PM
USA
mk378 Offline
mk378  Offline
USA
With the drum off, you should pre-set the adjuster screws out as far as you can, so that the drum just fits over the shoes. Put the drums and wheels on.
Then test drive and stop several times using the brake pedal while moving backwards. After the initial self-adjustment, seat the brake shoes by stopping a few times moderately hard from 30-40 mph going forward. Then a few more reverse stops.
The parking brake cable should not need adjustment if it was working OK before shoe replacement.
It is very easy to put drum brakes together wrong so the self-adjusting feature doesn't work. Especially if you switch parts from left to right. The adjusters are left hand threaded on one side and right hand threaded on the other.
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4501850
08/29/17 10:41 PM
08/29/17 10:41 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
As far as I know, the star drum adjuster and the parking brake cable adjuster are supposed to be adjusted separately. This is the first time I've ever heard of adjusting them simultaneously. Seems like the star adjustment would throw off the parking cable adjustment and visa-versa.
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4501855
08/29/17 10:46 PM
08/29/17 10:46 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Dont mess with any cables yet. Gotta set the drum to shoe first.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Chris142] #4501871
08/29/17 11:12 PM
08/29/17 11:12 PM
VA
Gebo Offline OP
Gebo  Offline OP
VA
Ok. How would you do this?
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'09 Lex IS350 85K
'07 Lex GX470 58K
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4502015
08/30/17 07:13 AM
08/30/17 07:13 AM
Chris142 Offline
Chris142  Offline
remove the drums and adjust the star adjuster.
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4502032
08/30/17 07:36 AM
08/30/17 07:36 AM
NC
BigD1 Offline
BigD1  Offline
NC
If it has a rubber plug on the backing plate, remove it, and then adjust the star wheel with a flat blade screw driver or adjusting tool.
1992 Toyota Pickup--Formula Shell 10W-30--Fram PH3614
Re: Adjusting Rear Drum/Parking Brakes 2002 4Runnner [Re: Gebo] #4502120
08/30/17 09:12 AM
08/30/17 09:12 AM
CA
The Critic Offline
The Critic  Offline
CA
I think your rear brake shoes are still too loose. Make sure the drum is on and then apply the brake pedal several times to center the shoes. Then adjust the starwheel until the brake shoes move outward (away from each other) until the drum can barely fit. Install the drum, step on the brake pedal several times to center the shoes and then recheck/confirm that there's a moderate drag. Reduce slightly if needed. Once this is complete, do the other side. At this point, once all drums are re-installed, apply the brake pedal a few more times (to re-center the shoes) and test the parking brake - it should now be within 5-8 clicks.
Always adjust the cable as a last resort. Make sure your brake shoes are in adjustment first.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
