What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
77 registered (andyd, 379KITTY, 2015_PSD, 330indy, 77GrandPrix, 6 invisible), 1292 Guests and 37 Spiders online.
65274 Members
67 Forums
285627 Topics
Page 1 of 2 1 2 >
#4501646 - 08/29/17 07:48 PM Brake Fluid Bleed 16' Lacrosse BIG Difference
TX_1821 Offline
Loc: Arlen Texas..... (Houston)
Hello Yalll!!
Just wanted to inform yall of a brake bleed I did on my vehicle(few weeks ago) that had AMAZING results.
Vehicle was not very old or had many miles either, 16' lacrosse with 30k miles.
Wasn't expecting it to be so effective
Brake pedal felt very soft/mushy and took a while to engage.
Initially thought it was just cheap GM pads.
Bled the rear and had clear fluid come out.
Was going to quit but said to he-ll with it and do front.
Fronts were full of milky water fluid that wasn't quite dirty but I guess absorbed moisture.
Took a while for it to be clear.
Results were Amazing, wouldn't have expected that on such a new car.
When in doubt of your brake pedal, Bleed your Brakes!!!!
Computers don't make mistakes...What they do they do on purpose"
-Dale Gribble
16' Lacrosse 3.6 LFX
Oil: QSUD 5w30 & Fram Ultra
ATF: Valvoline Dex 6
#4501669 - 08/29/17 08:08 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
Warstud Online   content
Loc: MIchigan
Air in the brake lines from the factory?
#4501722 - 08/29/17 08:40 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
Merkava_4 Offline
Loc: Clovis, CA
Oh I see! It's a 2016 LaCrosse. At first I thought it was a 16 foot long LaCrosse. grin2
#4501773 - 08/29/17 09:17 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: Merkava_4]
Nick1994 Offline
Loc: Phoenix, AZ
It's actually 16 feet 5 inches!
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4501860 - 08/29/17 10:54 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
Dave9 Offline
Loc: Cincinnati, USA
Something is not right. Brake fluid in a sealed system does not just absorb that much moisture in 1-2 years. Was this vehicle in a flood??
It can't be air in the lines from the factory, nobody would take delivery of a car in that state. Meaning if it started out with the air it would have had the severely mushy brakes brand new. There's no way that would go unnoticed.
I suspect there is still something wrong with the brake system, either that or your wife is trying to kill you sneakily by dumping water into your brake reservoir. eek
#4501916 - 08/30/17 01:11 AM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
Kibitoshin Offline
Loc: Kaiōshinkai
That's why most OEM's recommend replacing the brake fluid every two years.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L - 170k mi
02 Chevy Silverado C1500 V8 5.3L 154k mi
#4501940 - 08/30/17 02:50 AM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: Kibitoshin]
Dave9 Offline
No, it's not. They're just passing on the maintenance buck. You read something, completely misunderstood what you read, then went and made a mountain out of a mole hill.
No properly working brake system will have this happen within two years, usually not even 10 years to this extent, except during a rare event of extreme driving/braking where it heated up enough to vaporize what little water was in it . I don't recall reading that this situation is only when it happens.
Only people with more time and money than knowledge flush their brakes every 2 years unless they drive like they stole it and have worn out their master cylinder and calipers in that time instead of getting over triple the life out of them. You can in fact drive like that to prove this, lol.
It's a closed system. People who don't understand what that means say it absorbs moisture, unable to grasp that it needs exposure to moisture to absorb it. Closed seems to be a word they don't understand.
If this happened due to two years of not changing brake fluid, I guarantee you'd see it plastered all over the news, and massive lawsuits.
Edited by Dave9 (08/30/17 03:04 AM)
#4501978 - 08/30/17 06:24 AM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: Dave9]
itguy08 Offline
Loc: Somewhere
This may be the answer. Just the rear brakes on my F150 and I believe they were original (I'm the 2nd owner). It's a 2011 with 80k. I also flushed the fluid as we tow with it and the fluid came out a dark amber, almost like a light maple syrup color. No whiteness or anything like that. Seemed to help improve the pedal feel. But that's 6-7 year old fluid with 80k on it.
I think the OP should check for leaks or maybe a hose or fitting that's not right.
#4502030 - 08/30/17 07:34 AM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
E150GT Offline
Loc: San Antonio, TX
I don't think brake systems are sealed so well that moisture can't get in. In a very humid place like Houston I believe this could be possible.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 250k 5w30
2016 Mazda6 Touring 6MT - 56k 10w30
#4502108 - 08/30/17 09:05 AM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
The Critic Offline
Loc: CA
I agree with the others- fluid should not be visibly contaminated with water or moisture at this age/mileage. Was the master cyl cap left loose at some point?
Nissan has Brake Fluid Replacement listed as an annual service on their newer vehicles if operated under severe service. Nissan's definition of Severe Service pretty much encompasses most city driving conditions. For this reason, we recommend the brake fluid service annually and if we have no prior record of the service being performed.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4502248 - 08/30/17 12:10 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
TX_1821 Offline
Maybe it was flooded and just not reported in autocheck or carfax.
It's clear for literally everything, however we all know it's only for what was reported.
Rear was pretty clear but front end had water.
Would have thought if water went into master cyclinder, rear would have had some water as well.
Will check lines for any leaks soon as it stops raining.
Must have bleed at around 5-6 cars and there usually dirty colored, not milky water.
Definitely peaked my interest.
-Dale Gribble
#4502286 - 08/30/17 12:54 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: TX_1821]
Ram02 Offline
Loc: New York Queens
Can somebody please recommend me a good one man brake bleeder
2013 Malibu 2LT PG 0w20
2013 Accord Sport PG 0w20
#4502672 - 08/30/17 07:44 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: Dave9]
edyvw Offline
Loc: Colorado Springs
Do yourself (and family) a favor and buy measuring tool that: a) measures % of moisture, b): measure boiling point.
Let us know then how it works.
When you said "closed system" you forgot that that system is still exposed to moisture primarily thru reservoir in the engine compartment.
I see bunch of people like you here in Colorado, especially on the Pikes Peak, filling insurance claims (if they are lucky).
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
#4502733 - 08/30/17 08:19 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: Dave9]
philipp10 Offline
Loc: Minnesota
+1000.....I have been saying this for years. It's a SEALED system...
#4502736 - 08/30/17 08:22 PM Re: Brake Fluid Bleed 16' Lacrosse BIG Difference [Re: edyvw]
philipp10 Offline
Loc: Minnesota
I see bunch of people like you here in Colorado, especially on the Pikes Peak, filling insurance claims (if they are lucky). [/quote]
but Pikes Peak is an outlier. I live in the flat lands.....it's impossible to boil my brake fluid around here.
Page 1 of 2 1 2 >
