4.3 vortec issues
by mobilaltima. 03/18/19 09:17 PM
Recommendation for filter for Alfa Romeo 4C?
by phaphaphooey. 03/18/19 09:17 PM
What's the new wonder elixir?
by Yuk. 03/18/19 08:32 PM
Direct Injection Engines
by Al. 03/18/19 08:31 PM
Which mobil 1 for 19 versa?
by jahwarrior1423. 03/18/19 08:07 PM
RIP Dick Dale
by Donald. 03/18/19 08:06 PM
Found some rust on the roof of my car
by DreamerGT. 03/18/19 07:37 PM
What coolant would you run in a 1997 Dodge Ram?
by zfasts03. 03/18/19 07:11 PM
Is 10k miles too long for tire rotations?
by Nicasio. 03/18/19 06:47 PM
S-Oil Seven $14.88 on Amazon
by Nickdfresh. 03/18/19 06:41 PM
Power Steering Fluid - 07 Tahoe
by Plimbob. 03/18/19 06:38 PM
Oil / filter change 2015 Chevy Sonic 1.8l Automatic
by WyrTwister. 03/18/19 06:36 PM
Is this a battery issue or starter issue or ?
by simple_gifts. 03/18/19 06:24 PM
f250 - Friction modifier needed... which brand
by NattyBoh. 03/18/19 05:35 PM
Michelin's New All-Weather Tire for HD Pickups
by SubLGT. 03/18/19 04:36 PM
drsoils, Gbear, MadMikesMech, Indyfordfan, toplscuda
67551 Registered Users
78 registered members (4WD, 2010Civic, Agnosto, AlaskaMike, AdditiveOCD, 8 invisible), 1,482 guests, and 68 spiders.
Topics286,042
Posts4,901,388
Members67,551
Most Online2,967
Mar 10th, 2019
Update Powerstroke 6.7 Upper Oil Pan Fix #4501331
08/29/17 01:35 PM
08/29/17 01:35 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
I wanted to give an update on my upper oil pan reinstall. I purposely took my truck to a Ford truck center with the assumption they were more equipped to do this job...boy was I disappointed. Service writer didn't have a clue nor was communicating accurate information. Suffice it to say I will not be returning during any lifetime. Sorry for the rant.
Here is a picture of the lower oil pan freshly resealed and installed. Cannot see upper pan, but hoping it is good to go. The service manager said he was done more than 18 of these, but mine was the first one using the silicon for the upper oil pan. My wonderful service writer told me they ordered a new upper and lower oil pans, but my paperwork doesn't show that. Service manager is looking into it for confirmation. Other than that, hope no new leaks on the cardboard. Hope everyone is well.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501352
08/29/17 01:55 PM
08/29/17 01:55 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
If they cleaned the surfaces well it should last the life of the truck.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501377
08/29/17 02:25 PM
08/29/17 02:25 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Was this covered under warranty?
2015 Ford F250 w/Powerstroke
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501385
08/29/17 02:34 PM
08/29/17 02:34 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Yes, thankfully, the bill was around $2,200...parts and labor.
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501399
08/29/17 02:50 PM
08/29/17 02:50 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501401
08/29/17 02:55 PM
08/29/17 02:55 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
That's the most expensive tube of goop I've ever seen.
too many cars and oil combinations to list in 150 characters or less
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: L_Sludger] #4501413
08/29/17 03:10 PM
08/29/17 03:10 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Yep American car dealerships are imploding themselves!
2004 Corolla 129892
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: L_Sludger] #4501420
08/29/17 03:19 PM
08/29/17 03:19 PM
San Diego, California
Jim_Truett Offline
Jim_Truett  Offline
That is mostly the lower oil pan in his photo. The upper oil pan is basically the bottom third of the engine block. Quite a bit more than a tube of goop.
2008 F250 6.4 PowerStroke 51k
2005 Honda Pilot 249k
1963 Nova SS 84k
2008 GMC Yukon Denali 182k
2013 Mahindra 3016HST 108hrs
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501442
08/29/17 03:41 PM
08/29/17 03:41 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
My mistake. It was $2,697. Glad it was under warranty for sure.
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501496
08/29/17 04:49 PM
08/29/17 04:49 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
One very expensive leak. Being in California it probably wouldn't pass inspection?
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501514
08/29/17 05:08 PM
08/29/17 05:08 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Not sure on that bioburner. It is not a commercial vehicle...rather a RV. Very expensive leak...had to remove transmission to get to the upper oil pan. Ford covered everything. Very fortunate it happened while under warranty.
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501542
08/29/17 05:51 PM
08/29/17 05:51 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Some states require all vehicles to pass some sort of inspection. MN had one years ago to address air pollution and lasted about 3 years. Texas requires a pretty loose inspection that I will have to go through this fall on the F350 and the little Transit.
Glad to hear that Ford stood behind it and resolved it.
13 Scion Xb
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501584
08/29/17 06:36 PM
08/29/17 06:36 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
What was the symptom? Oil dripping?
This was in your 2014 F450?
Wonder if my 2015 could have same issue?
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: bioburner] #4501632
08/29/17 07:35 PM
08/29/17 07:35 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
We don't have state inspections for that here. Now you can fail a smog inspection if there is an excessive enough leak to where the person doing the inspection feel it is unsafe to test.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Update Powerstroke 6.7 Upper Oil Pan Fix [Re: mbacfp] #4501809
08/29/17 09:48 PM
08/29/17 09:48 PM
California
mbacfp Offline OP
mbacfp  Offline OP
California
Donald, yes it was on my F550 6.7. It appeared to be leaking from my lower oil pan. It would slowly drip along one side and when level would drip along the bolts of the lower pan. Initially was small drip or 2 over weeks. Lately got worse thus prompting me to take to dealer. Where is yours leaking from?
