OCI. With short trips. Nissan 4 liter
by Gawardawg
33 minutes 22 seconds ago
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
44 minutes 43 seconds ago
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
72 registered (advocate, 91camarosRS, AndyB, 1foxracing, 08z06, antik, 6 invisible), 1181 Guests and 39 Spiders online.
65265 Members
67 Forums
285582 Topics
Page 1 of 2 1 2 >
#4501296 - 08/29/17 01:04 PM Mobil1 Hi-Mi ?
Insertcoolname Offline
Loc: South Texas
Hi thanks for letting me join i been reading this blog for a while and I cant seem to find an answeer so I had to join. So I have an older camry, i put whatever I can get cheap in it. I found an awesome deal at advance $32-$12 rebate=$20-$10 gift card= $10/5 qt jug for Mobil1 High Mileage 10w30. I notice the donut in the back states API SN SAE 10w-30 and thats it. Also says API SN/SM and ACEA A3/B3. Ill try to post a pic. My manual asks for anything API xw-30 Resource Conserving or ILSAC multigrade oil. Should I be concerned at all that this oil is not resource conserving? I don't mind about loss of mpg but damage to emission system is possible I have read. Im sorry if this question has been asked before. I have another jug of Valvoline Maxlife Red bottle 10w-30 that is resource conserving just wondering if this may cause accelerated wear on other components.
TYIA
Edited by Insertcoolname (08/29/17 01:06 PM)
04 Camry 2az-fe 2.4L 200k M1 HiMi 10w30
Bosch D+ filter
#4501301 - 08/29/17 01:08 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
car51 Online   content
Loc: Southwest PA
It shouldn't. Resource conserving is with API SN spec.
2009 Toyota Camry LE
#4501303 - 08/29/17 01:10 PM Re: Mobil1 Hi-Mi ? [Re: car51]
Loc: South Texas
http://www.oilspecifications.org/articles/api-sn.php
My understanding is that API SN and SN RC are two different categories. I could be wrong?
Bosch D+ filter
#4501309 - 08/29/17 01:15 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
Quattro Pete Offline
Loc: Great Lakes
Because it's ACEA A3/B3 rated, it cannot be resource conserving. But I would not worry about damage to your emissions system.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (FF)
#4501310 - 08/29/17 01:15 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
bigt61 Offline
Loc: Virginia
If it's an older Camry w a typical RMS leak, I'd stick w the MaxLife Red bottle. M1 HM tends to pour out of those RMS cars - I've had 1st hand experience w a high mileage 96 Camry. If your car doesn't leak bad, then the M1 will be fine.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4501314 - 08/29/17 01:19 PM Re: Mobil1 Hi-Mi ? [Re: bigt61]
Loc: South Texas
No leaks at all and I only burn about half a quart when I use its favorite blends. It seems to like Quaker State products. Raised on PYB till 130k
Bosch D+ filter
#4501323 - 08/29/17 01:26 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
SilverFusion2010 Offline
Loc: Crawfordville FL
TYIA
Resource conserving is thin 30 HTHS 3.0-3.1
M1 HM 10W30 is thick 30 at HTHS 3.5
The additive packages are very similar with the HM having some extra seal conditioner and perhaps more detergent
2010 Ford Fusion SE 3.0L V6, 178k miles M1 HM 10w-30
#4501330 - 08/29/17 01:33 PM Re: Mobil1 Hi-Mi ? [Re: SilverFusion2010]
Oro_O Offline
Loc: Seattle-ish, WA
+1.
This would be an excellent oil for your car. The oil issues these engines are known for are not the same RMS issues he mentions above. Different powertrain, different issues. Walmart has it for $23 every day, and of course $13 when they run the biannual rebates (I buy two each time).
#4501336 - 08/29/17 01:39 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
Loc: South Texas
http://www.oilspecifications.org/acea.php
"ACEA A3/B3 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & Diesel Engines and/or for extended drain intervals where specified by the engine manufacturer, and/or for year-round use of Low Viscosity Oils, and/or for severe operating conditions as defined by the Engine Manufacturer"
This bottle of M1 does not bear the starburst for gasoline engines like manual shows.
Since this oil appears to be diesel compatible (B3?). assumed the ad pack was way different than what Toyota was asking for/designed for.
(I dont mean to be pointing this message at anyone in particular sorry )
Edited by Insertcoolname (08/29/17 01:39 PM)
Edit Reason: Add
Bosch D+ filter
#4501360 - 08/29/17 02:05 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
lawrencerd Offline
Loc: NC
I wouldn't use it if it's going to nag at you. It seems incredibly unlikely that Mobil 1 High Mileage would be in any way incompatible with a Camry especially without excessive consumption but you don't need to use any oil that you'll have second thoughts about if you have another option at the ready.
#4501362 - 08/29/17 02:09 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
Loc: Great Lakes
If it was "way different" it would not be carrying API sn rating. You are overthinking this, but if this is going to make you lose sleep at night, by all means return it.
#4501363 - 08/29/17 02:09 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
Jake777 Offline
Loc: FL
This is Mobil 1. It will not cause wear. This oil is great and perfect for an older car like yours that is not currently leaking oil. 10W-30 would not have been my choice I would have gone with 5w30 but honestly its still top of the line oil for your car. Tell you what. Call Mobil. They have world class technical support and they will take any fears you may have away and explain fully whats going on for you. I run M1 HM 5w30 in my Nissan Altima 10,000 miles and wouldnt change a thing.
#4501388 - 08/29/17 02:36 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
03s Offline
Loc: St. Catharines Ontario Canada
Ran it through the "Find the right oil for your car" at Mobil and it listed 8 different Mobil oils, obviously this was one of them. Your car will run on anything.
2005 Chevrolet Optra
Valvoline Full Synthetic High Mileage with Maxlife 5W-30
Fram Ultra XG3387A
#4501391 - 08/29/17 02:40 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
Loc: South Texas
Ok thanks. I just wasnt sure. Its my job to look at many fine details. Haha i have the service history since new and I havent used anything that wasnt RC. But at this mileage and price why not. Thank you all
Bosch D+ filter
#4501393 - 08/29/17 02:45 PM Re: Mobil1 Hi-Mi ? [Re: Insertcoolname]
kschachn Online   content
Loc: Upper Midwest
In general the starburst is a lot less important than the donut (which it has). The donut tells you the API grade and the API performance standard. As long as those are appropriate for your vehicle that is the most important thing.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
Page 1 of 2 1 2 >
