The front passenger side front brake line broke in half this weekend while driving to the store. It broke where the steel tube is connected to the rubber hose under the thick rubber sleeve.
the rubber sleeve was all swelled up at the connection point. Got the jeep home and replaced the brake line, then I thought I should check the drivers side.
It was also swelled up. I pulled it with little force and it snapped in two.
Please check your front brake lines or have them inspected by a dealer.
New brake lines are $28.00 each at NAPA.
2008 Rubicon, 76,000 miles.
