Recommendation for Acura Differential Fluid?
Berks County/Pa.
Just rolled over the 100,000 mile interval on Acura in signature. Would like recommendations on what fluid to use for changing out my differential fluids for front & rear.
thorromig, you wont find a aftermarket fluid recommend for an Acura/Honda differential. just go to dealer and pickup its not very expensive. i paid less than $10 a quart for mine.
Joe
Joe
I concur.
Had the same problem with nissan cvt oil
However what you might be able to do, is save a few bucks ordering through ebay.
EX
cvt nissan oil at dealer 12$/quart ; ebay like $7/quart
yep. you must use the acura fluid. the rear gear unit is NOT a differential. It is a spool with 2 electric clutches. It needs the right fluid.
There's an Acura AWD fluid. Be sure to replace it more often than every 100k - typical change intervals are in the 30-45k range as dictated by the Maintenance Minder system.
I believe the first is listed at 50k and then every 30k from there.
