oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Poles19, HinaMach, Horsehaulin, JLew, bmrk1100
66666 Registered Users
99 registered members (4WD, anndel, aba4430, aquariuscsm, 2004tdigls, 240_Ed, 15 invisible), 1,821 guests, and 39 spiders.
Topics295,018
Posts4,926,060
Members66,666
Most Online2,553
Oct 27th, 2018
Reliable substitute T-case oil #4501081
08/29/17 07:51 AM
08/29/17 07:51 AM
Western usa
Ammofirst Offline OP
Western usa
GM recommends this fluid http://www.ebay.com/itm/292158504164?_mwBanner=1&redirect=mobile for use in my transfer case 2014 Buick Regal AWD : Price seems a bit steep. Are there any safe alternatives? Thanks
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501105
08/29/17 08:09 AM
08/29/17 08:09 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Maybe try to figure out who makes the transfer case, and perhaps another brand uses the same one. Then you can see what they recommend? If its also some "special" specific gear oil maybe the transfer case needs it.
Sometimes I give up and just buy the manufacturers bottle, as the small savings isn't significant and it gets me into the dealer once in a while so I'm not a stranger if I have some questions or major problems...
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: Reliable substitute T-case oil [Re: IndyIan] #4501113
08/29/17 08:19 AM
08/29/17 08:19 AM
maple ridge, bc
2004tdigls Online content
2004tdigls  Online Content
maple ridge, bc
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501122
08/29/17 08:31 AM
08/29/17 08:31 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Redline synthetic gear lube is about $16/qt, so I don't think this is to expensive ...
Re: Reliable substitute T-case oil [Re: 2004tdigls] #4501125
08/29/17 08:32 AM
08/29/17 08:32 AM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Originally Posted By: 2004tdigls
Helpful, link says: "transfer case, no recommendation"
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Reliable substitute T-case oil [Re: IndyIan] #4501127
08/29/17 08:33 AM
08/29/17 08:33 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
+1 I had an older Equninox which had versatrak fluid and Royal purple "recommended" one of theirs but it never felt right unless it had the Delco stuff. Considering a transfercase for a sedan shouldn't hold much and doesn't need to be drained too often I would get the OEM stuff. That being said, Valvoline and Castrol if I remember correctly make a transfer case fluid. Worth looking into to see if they mention a cross reference to the GM number
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501144
08/29/17 08:55 AM
08/29/17 08:55 AM
TX, USA
JMJNet Online content
JMJNet  Online Content
TX, USA
Why do you think it needs changing? T-Case is a close system.
  • 2017 Toyota Sienna
Re: Reliable substitute T-case oil [Re: ammolab] #4501159
08/29/17 09:14 AM
08/29/17 09:14 AM
maple ridge, bc
maple ridge, bc
ya, sorry about that
I was trying to point out that it appears only the OEM fluid is recommended
Re: Reliable substitute T-case oil [Re: JMJNet] #4501185
08/29/17 09:36 AM
08/29/17 09:36 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Well, the fluid is accumulating particles from wear with no filter system, so changing it never hurts. Have you never drained a diff or transmission? Lots of ugly stuff comes out on the initial draining, or is stuck to the magnet.
I was always surprised how dark my Trackers front diff fluid got over 30-40k miles even though its just coasting along 90% of the time.
Lifetime fills means the manufacturer is pretty sure the dirty fluid won't cause a failure within the warranty period, but if you want to go triple that far without having a problem, changing the fluid is the way to do it.
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501208
08/29/17 10:23 AM
08/29/17 10:23 AM
KY
MCompact Offline
MCompact  Offline
KY
Some transfer cases are electronically monitored and will set a fault when a fluid change is required. Unfortunately, it usually doesn't display on the IP- the car needs to be interrogated by the appropriate diagnostic software.
Mine:
2014 M235i
2009 Cooper Clubman
1999 Wrangler Sahara
1995 318ti Club Sport
Wife's:
2015 X1 xDrive28i
Son's
2009 328i
Buy what makes you smile...
Re: Reliable substitute T-case oil [Re: IndyIan] #4501241
08/29/17 11:21 AM
08/29/17 11:21 AM
TX, USA
TX, USA
I am asking specifically to the OP for his specific case, I know about no lifetime fluid, etc.
Look at my signature, I have a 4WD Suburban Diesel.
I changed the t-case fluid but it was more than 10 years old when I changed it after I purchased it with no history (fire chief truck).
The t-case fluid was not that bad and it is spec'ed for trans fluid not too difficult to find.
The diff was worst but it is a RWD truck.
OP's car is barely 3-4 years old and he/she did not post the mileage of the car.
Just curious to see if he perceived any issue or is it because of mileage accumulation.
I will change the trans fluid more often than the t-case fluid unless it is abused or bought used cars with no history.
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501398
08/29/17 01:50 PM
08/29/17 01:50 PM
Indiana
nascarnation Offline
Indiana
The advert for the GM recommended fluid says "full synthetic 75W-90 hypoid gear lubricant."
I'd think the Mobil or Castrol equivalents would be fine.
And yes 45 bucks a quart is way too high.
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501428
08/29/17 02:24 PM
08/29/17 02:24 PM
The land of USA-made Subies!
SubieRubyRoo Offline
Redline 75W-90 Hypoid Gear Lube
That's the recommended lube using Redline's Advisor.
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501893
08/29/17 10:56 PM
08/29/17 10:56 PM
Western usa
Western usa
Car is a 2014 Buick Regal 2.0T 6spd auto AWD. 40k. Features a Haldex 4 AWD system : Knowing nothing about this AWD system I thought it might be wise to get fresh fluids in all the lubrication points. The Regal owners manual leaves me high and dry. Thankfully GM BOY here at bobs is helping me out. 3 AWD spots take lube. 1. Rear axle : 2. T-Case : 3. Rear differential Clutch : What's weird is that they are all 75w-90 gear oils : T -case > http://www.ebay.com/itm/292158504164 : Differential clutch fluid > http://www.ebay.com/itm/152671208296 : Rear axle > http://www.ebay.com/itm/322503550408. I think I'm safe using Amsoil S.V. + Limited Slip additive in the rear axle. The other two have me worried, I'd rather use redline for the $$ but oem is safer. Btw if anyone has a Regal / Lacrosse or Cadillac XTS AWD they share the same haldex unit. Although info on it is scarce to say the least. Thanks
Re: Reliable substitute T-case oil [Re: Ammofirst] #4501974
08/30/17 05:07 AM
08/30/17 05:07 AM
Vancouver, Canada
dubber09 Offline
dubber09  Offline
Vancouver, Canada
I had similar dilemma a little while ago before I changed fluids in front and rear on my '14 Kia Sportage.
First - I read what User Manual recommended so I know minimum requirements; then did my own research and ended up buying and using Schaeffer Manufacturing 2937590-012S Supreme Gear Lube SAE 75W-90 that I got from Amazon at $13.58 a quart with free shipping.
IMHO, this Schaeffer oil beats Amsoil and RedLine by a good margin and I'm very happy with it so far.
Kia Sportage 2014 GDI 2.4L
Kia Forte 2014 MPI 1.8L
