A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
10 minutes 59 seconds ago
2003 Honda power steering problem
by hogpops
17 minutes 48 seconds ago
Public Service Announcement: Flush Your HW Heater
by gathermewool
21 minutes 54 seconds ago
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
25 minutes 36 seconds ago
Castrol 0W40 vs 5W40??
by Realfine69
44 minutes 43 seconds ago
Paint impurities on a new car
by Quattro Pete
57 minutes 45 seconds ago
2014 Ram wheel FIT on a 2005 Ram?
by SumpChump
Today at 02:41 PM
Do people buy from telemarketers?
by Chris142
Today at 02:06 PM
TGMO 0W20, 8100km/5mo, 2013 Lexus GS350AWD 118K KM
by David_Corbett
Today at 01:54 PM
Sonoma Raceway
by Warstud
Today at 01:51 PM
Zipcode error
by aquariuscsm
Today at 01:36 PM
NHRA drag racing Racing question??
by daddi
Today at 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
Today at 01:20 PM
Removing Broken Bathtub Drain
by Warstud
Today at 01:15 PM
Buffer Pads
by TheLawnRanger
Today at 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
Today at 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
Today at 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
Today at 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
Today at 12:34 PM
Grit guard wash board
by JC1
Today at 12:22 PM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
90 registered (87sammy, BAJA_05, 1JZ_E46, Artem, Astro14, AZjeff, 5 invisible), 1537 Guests and 41 Spiders online.
65312 Members
67 Forums
285926 Topics
#4500950 - 08/29/17 04:31 AM HTHS of a couple of OTC engine oils
Shannow Offline
Loc: 'Stralia
#4501044 - 08/29/17 08:11 AM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
bigj_16 Offline
Loc: Douglas County, Colorado
Thanx. This paper has some interesting data.
#4501050 - 08/29/17 08:22 AM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
merconvvv Offline
Loc: il usa
So gm 5w30 has hths of around 3.5 ?
Gm 5w30 and mobil 5w40 have almost similar hths?
Am i reading the chart correctly ?
1988 Mazda RX7 na PP 10w30 Noack 4.7
1994 Chrysler Concorde 3.3
1999 Ford Expedition 4.6 QSUD 10W30 NOACK 5.0
#4501063 - 08/29/17 08:37 AM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
ARCOgraphite Offline
Loc: N.H, U.S.A.
xxx
Sorry, posted in wrong place somehow and cant delete after 3 mins?!
Edited by ARCOgraphite (08/29/17 08:41 AM)
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4501163 - 08/29/17 10:20 AM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
69GTX Offline
Loc: Connecticut
Somewhat confusing to me trying to pull the 5w-30 info out of those charts. I assume they're using Mobil Super Syn. 5w-30. Can we be certain they're using Grp 3+ synthetics for all of the 5w-30's?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4501195 - 08/29/17 10:59 AM Re: HTHS of a couple of OTC engine oils [Re: 69GTX]
kschachn Offline
Loc: Upper Midwest
Why would that matter?
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4501240 - 08/29/17 12:19 PM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
merconvvv Offline
Loc: il usa
What is the weight of shell helix in the figures.
I dont see any weight listing.
#4501400 - 08/29/17 02:51 PM Re: HTHS of a couple of OTC engine oils [Re: kschachn]
69GTX Offline
Loc: Connecticut
Because the 5w-40 and 5w-50 oils tested are very likely to be synthetics. In the case of Mobil, I don't see them offering a 5w-40 conventional. Wouldn't you want to compare apples to apples (ie synthetics vs synthetics). 5w-30 grade on the surface can be just as easily conv or syn.
1969 Ply GTX/RRs
#4501403 - 08/29/17 02:57 PM Re: HTHS of a couple of OTC engine oils [Re: 69GTX]
kschachn Offline
Loc: Upper Midwest
Not really, the abstract states "The article presents the results of experimental studies of HTHS viscosity of modern motor oils belonging to different viscosity classes" which to me would be agnostic to the base stock composition of the finished oil.
1994 BMW 530i, 227K
#4501601 - 08/29/17 06:55 PM Re: HTHS of a couple of OTC engine oils [Re: merconvvv]
Shannow Offline
Loc: 'Stralia
Yep,
it gets back to what I've been saying forever...they knew that when they went to multigrades across the board that the kinematics on J300 stopped accuratelt defining what an oil can do. So they tested and proved that HTHS was the answer, THEN set a bunch of minimums for each grade, and initially gave the 0W, 5W, and 10W40s the same minimum as a 30.
The grading should be xW-HTHS, with the kinematics as the secondary factor.
Per the apparent cofusion on the GM oil...the Delco 5W30 on the shelves locally is Dexos 2, i.e. above 3.5 HTHS.
#4502019 - 08/30/17 07:20 AM Re: HTHS of a couple of OTC engine oils [Re: Shannow]
merconvvv Offline
Loc: il usa
Yep,
gm ac delco 5w30 is good stuff.
Agreed they should list hths ccs mrv and noack on every can of oil. Not that difficult ! I am going to thicken up my 10w30s with a hint of 20w50 to bring hths around 3.5
enjoy the new property !
