Nasty looking oil filter
by atikovi. 09/21/18 12:43 PM
Laughing hard.
by StevieC. 09/21/18 12:26 PM
Apologies
by Drew99GT. 09/21/18 12:15 PM
Would Like the Manual Transmission to Make a Comeback?
by Speak2Mountain. 09/21/18 11:39 AM
Leaf Mulcher
by kwijibo. 09/21/18 11:32 AM
Pizza dough too crusty
by zorobabel. 09/21/18 11:26 AM
Lubegard Red or Platinum
by diyjake. 09/21/18 11:01 AM
Storing Car Outside
by Delta. 09/21/18 10:47 AM
Looking at a cheap commuter!
by ryan2022. 09/21/18 09:46 AM
Does Your 3.5EB Make Oil
by Gene K. 09/21/18 09:07 AM
F150 Front Differential
by hatt. 09/21/18 08:45 AM
EU version of Subaru 2.5 FB engine
by IMPALA08. 09/21/18 08:40 AM
New “rules” changing your choice of car?
by daves87rs. 09/21/18 06:04 AM
WIX51334XP Oil Filters
by CB900F2. 09/21/18 05:14 AM
Signal Oil Company radio advertising
by 21Rouge. 09/21/18 04:07 AM
Anyone "Wim Hof"ing ?
by Shannow. 09/21/18 02:35 AM
New R1250GS and R1250RT
by 02SE. 09/21/18 12:55 AM
Inside Break Booster & Master Cylinder
by StevieC. 09/20/18 11:22 PM
Inside an Alternator
by StevieC. 09/20/18 11:18 PM
ScottRousell, Direct_Rejection, donatom, Sylent_Snyper, Ajizzle
66034 Registered Users
102 registered members (2010Civic, 77GrandPrix, 65convertible, Ablebody, Astro14, 7 invisible), 1,742 guests, and 47 spiders.
Topics290,762
Posts4,849,873
Members66,034
Most Online3,590
Jan 24th, 2017
John Deere 5210 two-part question #4500774
08/28/17 09:13 PM
08/28/17 09:13 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
I picked up a John Deere 5210 (2.9 3cyl, NA) last year. It is a 1998 model with just under 3,000 hours. It appeared to have been well maintained and the previous owner said that he had always used JD filters and 15w-40 JD Plus 50 II oil. Mechanically sound. No leaks. It's given me great service.
The tractor is used for moving round bales/mowing/baling and general utility. In the spring and summer it is used for hours at a time, in the winter it is used long enough to move a few bales (but I always let it get up to temp).
I have followed the previous owner and run 15w-40 JD Plus 50 II and had no issues whatsoever, but a few cold starts last winter had me wondering. It has no block heater and I don't really want to install one (I'm off site from the farm, so it's hard to plug in/set a timer).
It rarely gets below 10F where I am, but there are usually plenty of 15-20F mornings.
Here's where I'm looking for guidance:
1) Would I be better off with a 5w-40 for winter/all-season use?
2) Would you switch a 3,000 hour tractor from conventional to synthetic?
Since the JD oil is a Chevron product (I think) I was leaning heavily toward Delo 5w-40.
Thanks
Re: John Deere 5210 two-part question [Re: MVFarms] #4500781
08/28/17 09:21 PM
08/28/17 09:21 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Since you get few hours in the winter.. I'd probably use 5w40 for the cold seasons.. then when it is time to change put 15w40 back in for the warmer months just for $$$ savings
Re: John Deere 5210 two-part question [Re: MVFarms] #4500809
08/28/17 10:04 PM
08/28/17 10:04 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
Run the 5w40 year round for even better savings.
2006 Trailblazer LT. Castrol Edge with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. It has oil and still runs
Re: John Deere 5210 two-part question [Re: MVFarms] #4500933
08/29/17 02:17 AM
08/29/17 02:17 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
1) Yes
2) Yes
Oh?? It used to be Shell... guess I'm out of date
Re: John Deere 5210 two-part question [Re: MVFarms] #4501031
08/29/17 07:43 AM
08/29/17 07:43 AM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
Thanks for ideas . . . it could be Shell. I can't remember where I read Chevron. I could definitely go T6 as it's probably a little easier to find.
Re: John Deere 5210 two-part question [Re: MVFarms] #4501065
08/29/17 08:38 AM
08/29/17 08:38 AM
BC Canada
Farmer Offline
Farmer  Offline
BC Canada
Shell Rotella T5 is a good choice for this as well. Any 15W-40 would be suitable, these 2.9L engines are impossible to kill. They just keep going. Have one that's almost 6,000 hours and I have no issues with it.
Re: John Deere 5210 two-part question [Re: MVFarms] #4501128
08/29/17 09:38 AM
08/29/17 09:38 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
15W is good down to freezing, so why switch ... If the battery is good and the cable ends are clean, it should go OK. JD Plus 50 oil is superb. Prolly better than the run-of-mill HDEO ...
NA motors can start a bit quicker on a shot of starting fluid. I wouldn't change unless the winter is expected to get nastier ...
Re: John Deere 5210 two-part question [Re: MVFarms] #4503516
08/31/17 03:38 PM
08/31/17 03:38 PM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
It never had any trouble starting (these engines have a cold start solenoid that advances pump timing . . . which has a tendency to short and blow fuses, so it is deleted per guidance from JD . . . still no problem).
I just wondered if I would be better off with 5w. Or if I was being overcautious about an 'old' machine.
I guess I can give the T6 a try this winter and compare.
Re: John Deere 5210 two-part question [Re: BrianF] #4506248
09/03/17 12:24 PM
09/03/17 12:24 PM
Michigan, USA
Bighorn2500 Offline
Bighorn2500  Offline
Michigan, USA
What he said....
2012 Ram 2500 SLT 6.7L Cummins 4x4
2015 Jeep Cherokee 3.2L Latitude 4x4
Re: John Deere 5210 two-part question [Re: MVFarms] #4551735
10/23/17 08:15 AM
10/23/17 08:15 AM
Virginia
MVFarms Offline OP
MVFarms  Offline OP
Virginia
Update . . .
Changed oil to T6 this weekend and ran it for a few hours doing some brush hogging.
I had one interesting observation: I had never noticed blowby from the crankcase vent tube before, but noticed a little after oil change. It was barely visable, but oddly enough, I was prompted to look for it by smell, because the new T6 has a fairly strong odor.
My thoughts . . . It has an 'acceptable' amount of blowby for a 3000 hour engine and the new smell made me realize it (I tend to by hyper-conscious looking for leaks/at gauges/smelling things.)
With the 15w-40 JD Plus 50 II, I had less than 1 quart consumption over 50 hours of moderate/hard use. I found that acceptable and can use it as a baseline for the T6.
Any thoughts from those in the know?
Re: John Deere 5210 two-part question [Re: MVFarms] #4551800
10/23/17 09:57 AM
10/23/17 09:57 AM
Illinois
RubiDia Offline
RubiDia  Offline
Illinois
The tractor is used for moving round bales/mowing/baling and general utility. In the spring and summer it is used for hours at a time checking leaks, in the winter it is used long enough to move a few bales (but I always let it get up to temp).
Now you know what you can use that extra time for... whistle
