The rear diff clutch fluid procedure:
xTooltipElement
Service Information Home Publications Number Search New Bulletins Bulletin Search Feedback TIS2Web Help
2014 Buick Regal | Regal North America VIN G Service Manual 5475358 | Driveline/Axle | Rear Drive Axle | Repair Instructions | Document ID: 2364449
Differential Clutch Oil Replacement
Removal Procedure
Warning: The hydraulic pressure in the differential clutch is very high. To prevent personal injury, wait for at least 10 minutes before removing any parts from the differential clutch.
Note: The vehicle should be as level as possible when performing this procedure.
Note: To adjust the differential clutch fluid to the proper level without draining, go to step 12 of installation.
1. Raise the vehicle and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Caution: It is very important to observe maximum cleanliness when working on the differential clutch. Dirt particles can seriously damage the function and service life of the differential clutch.
2. Remove the differential clutch cover to drain the differential clutch.
Object ID: 2512995Click here for detailed picture of the image.
3. Remove the vent hose fitting (2) and the hose (1) from the differential clutch cover.
Installation Procedure
Note: Both the fluid level and clutch motor current parameter requirements must be met to ensure the differential is filled to specifications.
1. Install the differential clutch cover.
Caution: Refer to Fastener Caution.
Note: The following tighten procedure MUST BE PERFORMED TWICE to ensure the proper sealing around the accumulator and the filter.
2. Install the differential cover bolts and tighten to 6 Y (53 lb in) in a star pattern and repeat this torque sequence twice to ensure proper sealing around the accumulator and the filter.
Caution: Fluids for the differential clutch and the rear axle are different. The fluids must never be mixed or interchanged or vehicle damage will result.
Note: When filling the differential clutch fluid use a fill tube , small enough to allow pressure to escape from the differential clutch housing.
3. Fill the differential clutch with 350 ml (12 ounces) of the proper differential fluid through the vent hose fitting hole. Refer to Adhesives, Fluids, Lubricants, and Sealers.
4. Remove the supports and lower the vehicle.
5. To stabilize the oil level, let the vehicle rest for 10 minutes with the ignition off.
6. Start the engine and allow to run for 5 minutes at idle.
7. In park, cycle the throttle to wide open briefly 5 times to cycle solenoids to purge air.
8. Shut the vehicle off.
9. Raise the vehicle.
Object ID: 2019182Click here for detailed picture of the image.
10. Remove the differential clutch level inspection plug (1).
11. The differential clutch fluid should be level with the bottom of the differential clutch fluid level inspection plug hole.
12. If needed, install the differential clutch level inspection plug and add 50 ml (1.7 ounce) through the vent fitting hole. Repeat step 4 through 11.
13. Install the vent hose fitting (2) and tighten to 14 Y (10 lb ft).
14. Install then vent hose (1).
15. Lower the vehicle.
16. Install the scan tool.
Note: When the clutch pump motor cycles from OFF to ON the current will also cycle from 0 mA to 2500–3500 mA. DTC C0407 64 is set when the pump current is CONSTANTLY BELOW 2500 mA.
17. With engine running, observe the scan tool Rear Differential Clutch Pump Motor Current parameter. The parameter display should be between 2500–3500 mA when the pump is on. If the parameter is below 2500 mA, repeat step 12.
18. Once desired parameter is reached check to ensure proper differential clutch fluid level. Remove fluid level inspection plug and allow any excess fluid to drain level with plug opening.
19. Install the fill plug and tighten to 14 Y (10 lb ft).
You are about to leave the website of General Motors and view the content of an external website. That website is not owned or controlled by, or affiliated with General Motors or its subsidiaries, and it is subject to its separate terms and conditions and other agreements, as well as its privacy policies. General Motors cannot be held responsible for the content of external websites.OKCancelWarning© 2017 General Motors. All rights reserved.
