Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
In praise of kludges...
by wings&wheels. 01/17/19 02:11 PM
Has Mobil 1 0w40 been discontinued?
by Doublehaul. 01/17/19 01:17 PM
Some questions for the home theater gurus
by grampi. 01/17/19 12:55 PM
Weird side problems after doing repairs
by mclasser. 01/17/19 12:31 PM
Shell Rotella Gasoline Truck.
by JHogan. 01/17/19 12:14 PM
Sears to stay open, for now
by addyguy. 01/17/19 11:35 AM
What Have I Gotten Myself Into?
by Gebo. 01/17/19 11:17 AM
Car stereo FM/ AM Reception Problems
by LazyDog. 01/17/19 11:13 AM
PPHM uoa requests
by aquariuscsm. 01/17/19 11:00 AM
Odd issue in Tacoma 3.5L V6 (2GR-FKS)
by 2019StingrayZ51. 01/17/19 10:58 AM
Alternative to Gillette Fusion razor
by gman2304. 01/17/19 10:55 AM
CAFE standards
by otis24. 01/17/19 10:01 AM
5w30 vs 5w40 Mercedes E220 BLUETEC
by Costas00. 01/17/19 09:56 AM
Moving mobility scooters
by supton. 01/17/19 08:59 AM
Car stumbling in idle
by dan765. 01/17/19 08:58 AM
Fiat 9.55535-GS1 Certification - Ravenol
by RamFan. 01/17/19 08:35 AM
Bigyetti83, Drava, supertrucker, neiltt, Drspel
66960 Registered Users
110 registered members (Andy636, anndel, addyguy, aquariuscsm, 28oz, AandPDan, 9 invisible), 2,223 guests, and 52 spiders.
Topics296,731
Posts4,957,830
Members66,960
Most Online2,577
Jan 14th, 2019
Why doesn't N America use Fleece filters? Advant #4499957
08/28/17 12:20 AM
08/28/17 12:20 AM
USA
Krieg Offline OP
Krieg  Offline OP
USA
What is the hype with fleece filters made in Germany? I read an article indicating the nano fleece is down to 5 microns. MB go 20 to 30 KM between oil changes. Why doesn't API ILSAC adopt these changes. I understand they regulate oil, but. Maybe I'm looking at in a simplistic form. Granted there are many variables. Could I be mistaken and synthetic filters are better? Just thinking late at night.
N�l an luach an maith ar a dtugtar go dt� go dt�ann s� tirim
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4499959
08/28/17 12:42 AM
08/28/17 12:42 AM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Originally Posted By: Krieg
What is the hype with fleece filters made in Germany? I read an article indicating the nano fleece is down to 5 microns. MB go 20 to 30 KM between oil changes,
"Down to 5 microns" can mean it simply catches some 5 micron particles. It's just marketing language.
20 to 30 km is 12400 to 18640 miles. Fram Ultra catches plenty of particles "down to 5 microns", and the new version of the Ultra is rated to 20000 miles. So comprible or maybe even better than a fleece filter.
API doesn't care about oil filters. Only way to compare performance is to look at ISO 4548-12 testing results to compare efficiency ratings.
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500008
08/28/17 04:11 AM
08/28/17 04:11 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
They seem to really push the fleece filters for duration, rather than efficiency. In the application guides I've seen, there are also paper filters available for most of those applications from the same manufacturer (i.e. a Mann fleece and an ordinary Mann for the same vehicle).
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500045
08/28/17 05:47 AM
08/28/17 05:47 AM
northern NY
Driz Offline
Driz  Offline
northern NY
The German testing organization TUV has likely massaged and rated those. If you can translate it they probably have some sort of ratings and test results on the net.
Re: Why doesn't N America use Fleece filters? Advant [Re: ZeeOSix] #4500070
08/28/17 06:21 AM
08/28/17 06:21 AM
NC
BigD1 Offline
BigD1  Offline
NC
A window/door screen can catch 5 micron particles, but, obviously, the efficiency would be terrible.
1992 Toyota Pickup--PYB 10W-30--Fram PH3614
Re: Why doesn't N America use Fleece filters? Advant [Re: BigD1] #4500099
08/28/17 07:04 AM
08/28/17 07:04 AM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
it can also be 99% efficient, at 100,000,000 passes.
Isn't there a point of diminishing returns of filtration? Are there clearances and areas that <20 microns is an issue and causing damage?
2018 Hyundai Santa Fe: Dealer oil, Mahle filter, 5k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: GTX HM 5w-20, EcoGard, 1yr
1994 Honda VT1100c: Peak 15w-40, PSL, 5k
Re: Why doesn't N America use Fleece filters? Advant [Re: blupupher] #4500150
08/28/17 08:06 AM
08/28/17 08:06 AM
MN
oil_film_movies Offline
MN
Returns do diminish as particles get smaller. They can lodge inside surface imperfections (aperities), yet they still are abrasive as oil film thickness fluctuates from none to substantial.
Much of an engine has to operate in near-zero oil film thicknesses. This is due to the limits of machine design. Not all of the inside of an engine has fully hydrodynamic surfing of oil films. It depends on where inside and engine and also how fast the parts are moving past each other, as well as the viscosity of the oil.
Bottom line: Oil film thickness ranges from ZERO to 200 microns or so.
That means ANY gritty particle scratches metal or Babbit surfaces.
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500155
08/28/17 08:10 AM
08/28/17 08:10 AM
Tennessee
goodtimes Offline
goodtimes  Offline
Tennessee
The Mann fleece filter elements are available in the American made Purolator Boss filter line. Comparing both, MB and Boss, they look the same, and Mann owns Purolator, pretty safe assumption. The efficiency on multi pass testing is 99+%. The micron value is 40 at that efficiency I believe.
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500249
08/28/17 09:43 AM
08/28/17 09:43 AM
MA
Wolf359 Offline
Wolf359  Offline
MA
Have you seen the prices on one of these filters? These aren't just $5 canister filters. They're usually like at least $15-$20 for a filter, at least for my car. It can be a pretty good deal on an oil change special where they throw in the filter, but not if they have language that says you pay the price difference instead of it just being free.
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500256
08/28/17 09:48 AM
08/28/17 09:48 AM
Johnny2Bad Offline
Johnny2Bad  Offline
The real question to ask is how do they flow.
Put another way, what is the oil pressure drop after installing this type of filter, and how does that value compare to a conventional filter? If you can't answer that, I'm not buying, period.
Any filter can perform down to 5 microns, or 1 micron for that matter. They just don't flow any oil.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: Why doesn't N America use Fleece filters? Advant [Re: goodtimes] #4500442
08/28/17 01:12 PM
08/28/17 01:12 PM
USA
Krieg Offline OP
Krieg  Offline OP
USA
Yes, I read your earlier post on it. Interesting!
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500478
08/28/17 02:38 PM
08/28/17 02:38 PM
Parts Unknown
UG_Passat Offline
UG_Passat  Offline
Parts Unknown
it's down to the automakers recommending them, not the oil companies and oil groups.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500578
08/28/17 05:02 PM
08/28/17 05:02 PM
USA
slacktide_bitog Offline
USA
Purolator is trying to promote them, with the Boss. Fleece media and plastic mesh.
But I remember something from Fram saying that the particles smaller than 10 microns aren't an issue, and that the 10-20 micron size particles are the ones to worry about.
Re: Why doesn't N America use Fleece filters? Advant [Re: Krieg] #4500786
08/28/17 08:29 PM
08/28/17 08:29 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
I think its for the same reason we don't like our women in fleece thongs!
2004 Corolla 128202
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
