2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
103 registered members (64bawagon, 69GTX, 97f150, 97prizm, 65convertible, 9 invisible), 1,643 guests, and 63 spiders.
Topics286,228
Posts4,904,674
Members67,582
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Aftermarket turbo BRZ oil recommedations #4499838
08/27/17 09:25 PM
08/27/17 09:25 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
First post!
Came here researching for that "perfect oil"...
So I have a newly turbocharged BRZ (1k miles) currently running M1 5w30. I have the triple whammy of an oil only cooled turbo, short trips and hot FL weather. Right now I'm seeing 230F oil temps (200 coolant) which is ok but I'm sure the turbo is beating that oil to death with heat (its gives off whisps of smoke off the CHRA on shut down). As some may know the OEM fill is 0w20 which is far too thin for my app. It seems like Redline 5w30 might be good choice because of high HTHS and low Noack.
Any other recommendations for oil?
2014 Subaru BRZ, Turbo'ed @ 10psi, ~320hp
M1 HM 10w-30, Subaru filter
2014 Toyota Camry - M1 EP 5w-20
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499845
08/27/17 09:34 PM
08/27/17 09:34 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
At least 0W-40 qnd get a pyrometer to let you see the turbo temps and let the turbo cool to around 300*f before shut down. I bet the torque increase makes the BRZ super.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499852
08/27/17 09:42 PM
08/27/17 09:42 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
I think this would be a good time for that Redline 10w-60 whistle
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499854
08/27/17 09:42 PM
08/27/17 09:42 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Does it have a oil cooler set up?
2004 Corolla 130005
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Aftermarket turbo BRZ oil recommedations [Re: CT8] #4499856
08/27/17 09:45 PM
08/27/17 09:45 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
You think a 0w40 huh?.. that's way thicker than OEM spec. The '15+ WRX which uses the same engine (except lower comp pistons) specs 5w30 which is why I went with that. But yes the extra torque is nice it really is a top end rocket! The car has 255 dur. cams stock more of a revvy top end motor. Its sitting around 285whp and 230wtq on a low boost conservative tune to save the clutch.
The whole pyrometer seems really inconvenient would like to avoid that. I do let it idle after pulls but just driving to work and putting around town I don't.
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499857
08/27/17 09:47 PM
08/27/17 09:47 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
No oil cooler set up as I have no good place to mount. Looking into that but the temps are 230*F off the ECU not that crazy.
10w-60 sounds insane lol. I'm just street driving it...
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499859
08/27/17 09:50 PM
08/27/17 09:50 PM
bigj_16 Offline
bigj_16  Offline
In all honesty, I would give the Redline 5W-30 a shot. If you are still not comfortable, that Motul Sport 5w-40 might be the ticket.
Re: Aftermarket turbo BRZ oil recommedations [Re: bigj_16] #4499862
08/27/17 09:54 PM
08/27/17 09:54 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
No doubt. I think I need to get myself an oil pressure gauge as that is what really matters.
I have an air to air oil cooler I used to run NA on track but the intercooler takes all that space up now. The do have water to oil coolers might be easier to plumb.
Re: Aftermarket turbo BRZ oil recommedations [Re: bigj_16] #4499864
08/27/17 09:54 PM
08/27/17 09:54 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
Re: Aftermarket turbo BRZ oil recommedations [Re: bigj_16] #4499866
08/27/17 09:55 PM
08/27/17 09:55 PM
South La
passgas55 Offline
passgas55  Offline
South La
I would use a 10/30 A3/B3 spec oil like M1 HM 10/30.
Re: Aftermarket turbo BRZ oil recommedations [Re: passgas55] #4499868
08/27/17 09:56 PM
08/27/17 09:56 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
That is a high HTHS oil? I assume why you recommend?
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499873
08/27/17 09:59 PM
08/27/17 09:59 PM
bigj_16 Offline
bigj_16  Offline
Both M1 HM 5W-30 and 10W-30 have nice specs. I think you ought to go with an ester base for this application, though.
Re: Aftermarket turbo BRZ oil recommedations [Re: bigj_16] #4499877
08/27/17 10:10 PM
08/27/17 10:10 PM
Orlando, FL
stevo585 Offline OP
stevo585  Offline OP
Orlando, FL
Looking the specs the Redline 5w30 does seem a bit more robust than the M1 HM 10w30. More expensive though but not that bad.
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499882
08/27/17 10:16 PM
08/27/17 10:16 PM
bigj_16 Offline
bigj_16  Offline
If you look across the board, the Redline 5W-30 is the stoutest of the thinner Redline oils.
https://www.redlineoil.com/content/files/tech/Motor%20Oil%20PDS%205-13.pdf
Re: Aftermarket turbo BRZ oil recommedations [Re: stevo585] #4499887
08/27/17 10:31 PM
08/27/17 10:31 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Higher HTHS gives you more insurance that the oil film is thick enough to prevent metal to metal wear under high load. I like Edge 0w40
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Page 1 of 5 1 2 5
